Question about Brother MFC 9600 All-In-One Laser Printer
Prints light but OK from computer/but light or faded from copier
I have a relatively new cartridge. When I print out something from my computer the contrast is relatively light but the printing is consistent over the entire page. I have tried increasing the contrast to no avail.
When I try to make a copy from the scanner, the result is light but uneven contrast with some parts of the copy page so light as to be unreadable.
  • 583 Answers
The laser beam inside the optics assembly of your printer has fog or dust on it and is not able to put up a dark beam on the drum to provide dark copies.clean the internal optics by opening the printer to solve this problem completely.
Posted on Mar 13, 2009
    Sergeant:
  • 320 Answers
Its the problem of inner laser beam in your printer.that has to be cleaned.the printer needs servicing that will solve the issue.
    Genius:
  • 1,550 Answers
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
Yellow ink faded on one side of copy
Ink News - How To Correct Faded Prints From Toner ...
www.inkpal.com/ink.../tips-to-correct-faded-prints-from-toner-cartridges...
Rating: 3 - ‎12 votes
Mar 30, 2012 - You should particularly suspect this if the prints are faded on only one side and if the printer is not telling you to replace the toner cartridge.Missing: yellow
HP Officejet 6500 Printers - Fixing Print Quality Problems ...
support.hp.com/us-en/document/c01641184
Jan 16, 2016 | Office Equipment & Supplies
Prints pictures faded
On the pixma printer each time you remove a cartridge. you will need to do a clean of the nozles and print head. you can find instructions in your online operators manual. You hold down the wi-fi button and watch the
Home Click Here to Search
MG3500 series > Overview of the Machine > Maintenance > When Printing Becomes Faint or Colors Are Incorrect
Maintenance Procedure
Printing the Nozzle Check Pattern
Examining the Nozzle Check Pattern
Cleaning the Print Head
Cleaning the Print Head Deeply
Aligning the Print Head
Page top
error light flash. 1 flash release prints all saturation levels2 flashes prints the head alignment chart. 3 cleaning 4 flashes deep clean and so on. or its a transfer problem and this case do a transfer belt clean, and a head alignment.
Feb 28, 2014 | Canon Ink Cartridge for Pixma MP252
CANON PIXMA COLORS ARE LIGHT
I would manually clean out the printhead, I believe for your model it is a separate unit form the ink cartridge. Please follow these steps bellow.
First you will need to remove the cartridges, then remove the printhead assembly then mix some water and isopropyl alcohol in a 50/50 mixture. You can either use a cotton swab to rub the water and alcohol on the printhead or you can soak the inkjet printhead for around 2 to 5 minutes. This should loosen the dried ink. It may take a few attempts and requires patience. Dry it on a folded paper towel and reinstall it. Print a test page to check quality. If the documents are still printing with poor quality, repeat and soak the printheads for longer.
Let me know if that helped. I had the same issue and this resolved it for me.
Thanks
Bloomfield Connecticut Computers (BCC)
Jan 13, 2014 | Canon PIXMA MX700 All-In-One InkJet...
Fading prints and new cartridge error, will not aliegn
It's possible it is the new cartridge, but it sounds more like the print heads. I had the same printer and same problems until I changed the print heads. You are better off buying American Made Printer Ink Cartridges Even If They Cost A Little Less Than Name Brands. I get mine from www.officeinks.com with a 1 year quality and satisfaction guarantee with free return shipping. I have used it once and had no hassle.
Oct 16, 2009 | HP Officejet 5610 All-In-One InkJet...
PRINT FADING ON RIGHT HAND SIDE WHILE BLACK CARTRIDGE SHOWS FULL.
your cartridge is third party toner insert new hp original cartridge before cleaning
Jun 23, 2009 | HP Color LaserJet 2600n Printer
I have changed all the ink cartridges on my Brother MFC5440CN it
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Jun 03, 2009 | Brother MFC-5440CN All-In-One InkJet...
Samsung CLX-2160, keep getting faded toner stripe down page. changed toner numerousof times The same problem occurred for me after only 300 pages. The black color on the all prints is faded out on the...
Everyone will tell you that it's the Imaging Unit - happy to say that's not true. If it was the imaging unit the colors would not come out right either. I bet if you print a test page that all the colors come out fine across the page. It's only the black.
Also - if you replace the black toner cartridge, or reinstall your printer and drivers like some people will tell you - still no results.
The problem is in the black toner cartridge PATH inside the printer. Something has jammed it up a bit. Try taking out the black cartridge and blowing firmly into the small hole at the bottom of the spout that looks to have a sponge inside. Use a straw and make sure your air blown is dry. Then lightly tap the cartridge a few times. Then use the straw and once again blow very firmly inside the receiving path (inside the printer) for the spout on the cartridge. Make sure you are blowing into the spout path at the bottom - not the gear drive path in the middle - as that will not do any good.
Replace the cartridge, warm up and print another black and white page. You should see that the faded out section is gone or diminished in size. If it is not gone, simply repeat the above steps until it is gone. You will see that the faded out strip gets smaller and smaller each time until it's gone. I had to repeat five times, but eventually got it corrected. Now prints like brand new so don't get discouraged.
Loki
May 18, 2009 | Samsung CLX-2160N All-In-One Printer
HP 2820 CLJ, ONLY PRINTS DOWN ONE SIDE
ok typical carousel misalignment
http://www.fixya.com/support/t400576-printing_right_side_only#SameProblemContinued
just take a big screwdriver and check for stuck cartridges
Nov 05, 2008 | HP LaserJet 2820 Printer
Print problem
Have you tried replacing the ink cartridge?
May 01, 2007 | Minolta magicolor 2200 DeskLaser Printer
Brother MFC 9600 All-In-One Laser Printer Logo
35 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
