SONY LBT-ZX991 STEREO WONT TURN ON AND RED LIGHT KEEP BLINKING
WON'T TURN ON AN RED LIGHT FLASHING
SOURCE: hello
Un Plug It for like 10 to 20 seconds and plug it in it should work it happens to me all the time if it contionuls check the speaker wires and see if the wires are toching together that will be the problem to
Posted on Nov 13, 2007
  • 4234 Answers
SOURCE: Red blinking light, SONY KV-32FS13
The 4 blinks usually mean a vertical deflection problem. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Posted on Oct 02, 2008
SOURCE: TV Wont turn on - Red Blinking Light under Lamp
The lamp is shot. Port is on the right side of set - just remove and take a look. Check VISA limit.
Posted on Apr 16, 2009
logosc75
  • 625 Answers
SOURCE: stereo wont turn on only red light is blinking
It sounds as if you are lacking accessory power to the unit. Insure that the red wire of the Pioneer unit is receiving 12 volts with the key in the accessory and on position.
Posted on May 06, 2011
dunnbiker
  • 8546 Answers
SOURCE: Can somebody please help me.
Resolve the cause.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Posted on Jun 29, 2011
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
TV Won't turn on, Has flashing red light.
Flashes of standby light is fault indication. Count it and confirm the number of flashes occurs at one time switch ON. If you wish to get more details about these blinking codes to Toshiba sets, check this link. Pull up older posts there.
Mar 02, 2013 | Toshiba TP50F60/61 TV
My sony wega KDP57WS655 tv wont turn on...makes noise like it is coming on, clicks then turns back off and standby light is flashing
If the red light is blinking in front that sasy lamp. Your lamp needs to be replaced. They cost about $100.00 at your TV Fix It shop. Very easy to replace yourself
Nov 20, 2012 | Sony Grand WEGA KDP-57WS655 57" Rear...
Tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Jul 18, 2012 | Sony Grand WEGA KF-42SX300 42" LCD TV
My ps3 won't turn on and red light keeps blinking,
Read this:
http://www.prlog.org/10506996-ps3-red-flashing-light-causes-and-solution-revive-your-ps3-by-fixing-red-lights-blinking-yourself.html
May 15, 2012 | Sony Video Game Consoles & Games
Sony Trinitron won't turn on red light blinks 9 times
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not re-solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Apr 29, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
Wont turn on has blinking red light wont stayed powered
Hello, I'm sorry to say this but the blinking red light is = the light of Doom. Your PS3 is dead. This is somewhat like the XBOX Red ring of death.Yellow lights and blinking red lights indicates general hardware failure on ps3. If your ps3 is still under warranty call Sony and they will send you a new or refurbshed one. Your ps3 is one in a billion (according to Sony). North America: 1-800-345-SONY (7669) United Kingdom: 08705 998877
Now you could try doing a few things (hey it's worth a try!)
1. Turn off the switch in the back and wait a few minutes. Turn it back on and try it again. If that doesn't work it may be dead.
2. You could try this article, if you choose to, it's a long shot but might work for you in your case. http://ps3.qj.net/Possible-PS3-flashing-red-light-fix-from-MXACE/pg/49/aid/75721
Nov 21, 2009 | Sony Playstation 3 (PS3) Console
Console wont turn on has blinking red light wont stayed powered on and can't get game out
Finding an Instruction Manual for Sony stereo system
How do I remove the protect mode from my Sony LBT-LX5 Stereo?
Dec 04, 2007 | Audio Players & Recorders
61 people viewed this question
 Grubhead
Grubhead
