Question about Splendide ARWXF129W - Washer 24" Whit ARWXF129W
I have a Splndide washer Mod. ARWXF129W.It stopped before the spin and drain cycle and flashes H20 trouble code.
    Top Expert:
  • Splendide Master
  • 7,897 Answers
Bad water pump
Posted on Oct 29, 2017
2 Suggested Answers
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it.  Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
Posted on Jun 02, 2008
How to put into test mode arwxf129w
if you put dial on start should fill then turn to spin then to rinse then to drain
Jun 10, 2014 | Splendide ARWXF129W - Washer 24" Whit...
H20 fault code splendide washer
Hello!
Seems that a fill valve is broken.
Usually in such cases, a valve replacement is required.
Nov 19, 2013 | Splendide ARWXF129W - Washer 24" Whit...
Indesit Evolution W16s washing machine H20 error code
if there a advance cycle button push it an see if the timer will advance to spin if not turn the power off to washer an wait a couple mintue an the door will open
Apr 24, 2010 | Washing Machines
Washer stop and flashes 20 F
this sounds like the hose to drain is cloged or the pump is blocked up in back of washer were drain hose is at remove back the hose that drains from tub to drain needs to be checked remove clamps and flush hoses,than look in pump and remove debri,and put back together take cloths out and sanitize machine remember use bleach and hot water or use pool shock a eighth of a cup and add in detergent desp. and let it sit his well be more powerful and get rid of meldew,i hope this helps
Dec 22, 2009 | Kenmore HE3T Washer
F9 Code
Pump is most likely clogged .... take front panel off and pump is right there ......
Jul 22, 2009 | Kenmore Elite 45986 Front Load Washer
The machine fills and drains on wash cycle but willnot spin
C1. Your motor was stopped due to overloading, inbuilt device, reduce weight of clothes (put less clothes). Press 'stop' & 'cancel' to clear the display.
How abt a good rating? Thanks
Mar 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
GE WASHER WJRR4170G0WW-SPIN Cycle does not work- just make sound.
My washer is 2 years old and this is 1/2 the cost I paid for it new. My review of this product after 35 years of technical experience; GE products (Hotpoint)aren't worth buying any longer.
The problem is the Motor. There is an electronic PC Board attached to the top of the motor and under the drip protector, which protects the PC Board. On this board, there is a green flashing light which displays trouble codes by flashing. Unplug the washer, remove the 3 screws from behind the control panel. Slowly pull the control panel toward you and slide it to the right to release. Inside the washer, there is a diagram with the trouble codes printed in the lower right hand corner. Everything else is self explained. Flashes indicate the problem and the solution is all written. Since I have the same problem and a technician, this is a defective product GE has discontinued and re-manufactured. After phoning GE the motor # Normal 0 WH20X10051 cost $252.25 to ship to my location.
Jan 09, 2009 | Washing Machines
Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
Splendide ARWXF129W - Washer 24" Whit ARWXF129W Logo
61 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
