Question about Seagate FreeAgent Pro 1TB External USB 2.0/eSATA Hard Drive
Seagate 1tb hard disk not recognized
Hi. I have a seagate 1 TB external hard drive which is not been recognized by my PC. When I plug it in the green light at the front just flashes and the motor inside doen't even seem to be running. I have checked in disk management but it doesn't appear in there either. I have also tried to use my hard drive on other computers but it still does not work. Any help would be great cheers, Satya
    Habit-Forming:
    New Friend:
  • 72 Answers
This is a hardware problem but since you can't access to the removable you have to order a new one making sure the warranty of your product is still valid
Posted on Aug 05, 2017
zzptichka
  • 95 Answers
SOURCE: My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Posted on Dec 30, 2008
  • 265 Answers
SOURCE: USB port broken in 1TB seagate Freeagent external hard drive
Yes you can just take the hard drive out of the case, can use it with any other case, you can also just put it inside your computer and connect it to the sata cable :)
Heres a case you could use for your drive... Click Here
Please rate
Many thanks
Posted on Feb 20, 2009
  • 29 Answers
SOURCE: Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
Posted on Jul 09, 2009
SOURCE: I cannot see my free agent external drive
Thanks for your responses...
I've pretty much decided that it must be a hardware problem within the harddrive itself...Can anyone lead me in the right direction to maybe take out the harddrive to put into another external shell in order to hopefully recover my data? Again I'm using a Seagate Freeagent Desktop 500GB external harddrive.
Posted on Jul 24, 2009
bob_computer
  • 3153 Answers
SOURCE: seagate 1tb external hd just beeps
You may want to open the drive and check the internal connections first to make sure none came loose after you have powered it down.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care. this is a real hard drive and knocks and bumps can quite literally kill them.
If a drive is CLICKING after an accident there is a very strong possibility that it is dead or dying. This is known as the "click of death".
Posted on Sep 07, 2009
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate Expansion 1TB external Desktop Hard Drive (9sf2A4-500) not detected.em?
Sounds like driver problem to me. Re install the driver by using installation disc, or if you have lost your CD, than use this Driver Update Software to update. I hope this helped.
Brian
Oct 24, 2012 | Seagate Expansion 1 TB USB 2.0 Portable...
My Seagate 1TB FreeAgent external Harddrive is not working on my laptop which is running on XP. In Manage Hardware section this device is shoing as unknown hardware.
go here
And download for windows. You see most companies like you to download the software from their website for older operating systems for your computer to recognize it.
Thanks, Cody
Sep 11, 2012 | Seagate Freeagent Go 1 TB Hard Drive
Have a 1.5. TB "Sea gate Free Agent - Desk". Used
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jun 28, 2011 | Seagate FreeAgent Pro 1TB External USB...
I purchased a seagate expansion 1tb in 3.5". initially when i plugged it into an usb port,(LED lit) it doesn't recognized by my Vista home premium 64-bit. i plugged it and waited for several...
> I purchased
Brand-new, I presume?
> is it a failed HDD
Yes. Take it back to where you purchased it, and get them to replace it, under warranty.
> software problem
No. It shows-up in "disk-management" as a recognized, but not-yet-initialized, device.
Thus, all the software to support it has been correctly loaded.
Exercise the warranty.
Feb 17, 2011 | Seagate Expansion 1 TB USB 2.0 Portable...
My 1Tb Seagate FreeAgent Go portable drive stopped being recognized. When plugged in the lights blink but I can't see it to recognize it.
Connect it to a different computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Oct 27, 2010 | Seagate FreeAgent Go (ST910004FAA2E1RK) 1...
I/o error in external hard
make sure all the connections USB, sata and electrical are secure and working properly
Jul 20, 2010 | Seagate FreeAgent Pro 1TB External USB...
Jun 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Dec 30, 2008 | Seagate FreeAgent Pro 1TB External USB...
Seagate FreeAgent Pro 1TB External USB 2.0/eSATA Hard Drive Logo
155 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
