Question about Dishwashers
Miele dishwasher cleans most items, leaves pans dirty
Our Miele dishwasher cleans glasses, crockery and cutlery very well, but often leaves pans dirty; there is a film of residue round the inside, at about the water level when the pan was used to cook vegetables.
  • austin_green Mar 16, 2009
    Took temp of water part way through cycle, it was 52 deg Celsius (126 Fahrenheit) The manual says 55 C (131 F) so I gues that's as close as we can expect. But - there is another program which gives 75 C (167 F) so I guess that is the one to try! Many thanks for the suggestion.
    Genius:
  • 1,066 Answers
Water may not be hot enough...check thermostat in waterheater.
Posted on Mar 13, 2009
Where can i get a bottom tray for a nobel dishwasher NBFS4 S/S model
nobel dishwasher cutlery tray - Compare Cheap ... - GetPrice
www.getprice.com.au/buy-best-nobel-dishwasher-cutlery-tray_pn9.htm
Results 321 - 342 of 342 - Compare Nobel dishwasher cutlery tray price and readNobel dishwasher cutlery tray reviews before you buy. ... Bottom... more info.
I have a Nobel Dishwasher, model NBFSDEC. I have ... - Fixya
www.fixya.com/support/t24625480-nobel_dishwasher_model_nbfsdec
Jun 13, 2014 - I have a Nobel Dishwasher, model NBFSDEC. I have cleaned the filters ... Dirt left on dishes on top tray; bottom tray washes fine. Apr 03, 2009 ' ...
Household Cleaning Urban Myths: Do They Actually Work ...
www.apartmenttherapy.com/household-cleaning-urb...
Apartment TherapyJan 31, 2011 - com1Line the bottom of a pan with aluminum foil with the shiny side up. .... To get baked-on crud off of broiler pans, oven racks, roasting pans, glass baking .... Burnt pans, if you don't believe in Easy Off (a Nobel Prize for the ...
dishwasher in Scarborough, WA ' Dishwashers ' Gumtree ...
www.gumtree.com.au > Home & Garden
Jan 04, 2016 | Dishwashers
Whirlpoo l
Probably because the locked up setting needs to be removed or changed. I have never owned a dishwasher. My advice is to remove the dishwasher and sell it. Then soak your dirty cutlery and crockery in hot soapy water in your sink for about twenty minutes, then wash them yourself. Don't be lazy. You have to load and unload a dishwasher anyway.
Aug 19, 2014 | Whirlpool DU1055XTS Built-in Dishwasher
I have tried EVERY piece of advise offered...clean both arms, filter at bottom, rinse all crockery/cutlery before placing it in Bosch, use a dishwater-cleanser on weekly base, check the water pressure, got...
If it is just glasses and coffee mugs that it refuses to wash maybe you should stop trying to wash these items in this dishwasher.
Could it have to do with the location where you put them? Maybe the direct water jet has a blind spot there while the reflected dirty water concentrates there. That may have to do with the shape of the vessel. I am just trying to make sense out of this unusual behavior. (I am thinking of some remarkable properties of parabolic and elliptic surfaces.)
Dec 22, 2013 | Audiovox Bosch 718 World Cellular Phone
Glasses and frying pans not clean at end of cycle. Residue on glasses and cups,food particles on frying pans.
it's generally not a good idea to put really greasy items in a dishwasher along with relatively clean items such as glassware and plates and cutlery, as most recent good quality dishwashers come with a soil sensor that ends the wash cycle once the dishes appear clean, and all the grease from your frying pan will cause the soil sensor to take longer to detect clean water.
Jun 29, 2011 | Dishwashers
My bosch dishwasher has suddenly started leaving everything cloudy, particularly the glasses. The salt is topped up, the rinse aid full, filters cleaned out.
You can experiment with different tablets/powders and check that the salt and rinse aid dispensers are correctly adjusted, but all dishwashers eventually cause glass to go cloudy and although it's a gradual process there's a point at which it suddenly seems to become noticeable. Any lead crystal glass will cloud very quickly indeed so must be handwashed if you want to avoid this. The cloudiness in glass is irreversible as it's caused by millions of microscopic cracks in the glass surface. Some crockery items are glazed with a process which can also turn cloudy over time in a dishwasher, white plates won't really show it but coloured ones do (especially blue and red). There are some tablets/powders which claim to have a glass protection additive, but this just slows down the process. The best way to slow the process is to wash at the lowest temperature you can.
Aug 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dirty cutlery, glass wear getting a dull film
WHAT IS THE TEMPERATURE OF YOUR WATER, SHOULD BE AROUND 140 DEGREES.
Feb 26, 2010 | Dishwashers
Lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Dec 14, 2009 | Siemens Dishwashers
Dishes not clean
hi friend,HOW TO GET THE BEST FROM YOUR DISHWASHER
Always follow the manufacturer's instructions and read the directions carefully on detergent, rinse aid and salt packaging.
Cleaning your machine about once a month will remove any grease and lime scale deposits which can build up on the inside of the machine. Special dishwasher cleaning detergents are available which are used when the machine is empty. These cleaners will often leave a fresh smell in the dishwasher too. If you want to have that fresh smell all the time, use a dishwasher freshener. These are usually supplied as hanging tags, which should be carefully positioned away from any moving arms. A freshener is essential if you load during the day and then run the machine at night.
WHAT ELSE CAN I DO TO GET THE MOST FROM MY DISHWASHER?
Cleaning your machine about once a month will remove any grease and lime scale deposits which can build up on the inside of the machine. Special dishwasher cleaners are available which are used when the machine is empty. These cleaners will often leave a fresh smell in the dishwasher too. If you want to have that fresh smell all the time, use a dishwasher freshener. These are usually supplied as hanging tags, which should be carefully positioned away from any moving arms. A freshener is essential if you load during the day and then run the machine at night.
LOADING
These items can be washed in a dishwasher, with the following guidelines:
Glassware - Any ordinary glassware and ovenware such as Pyrex. Do not wash lead crystal glasses unless they carry a "dishwasher safe" label.
Tableware - Most everyday crockery is safe. Bone china usually has under-glaze decoration and should be safe. Avoid antique or hand-painted and over-glaze decorated items. If in doubt, check with the manufacturer.
Cutlery - Stainless steel and silver cutlery are normally suitable for machine washing, but it pays to rinse off any acidic food before loading to prevent any corrosion and, if possible remove the cutlery immediately after the cycle, to avoid prolonged exposure in a humid atmosphere. Do not mix steel and silver cutlery in the same basket and wash bone or wooden-handled items by hand.
Plastics - Check whether they are dishwasher safe and do not place in the lower rack, where the heating element may affect the plastic during drying.
Pans - Stainless steel is ideal for dishwashers. aluminium can be washed in the machine, but may discolour during the rinsing. If in doubt, remove aluminium pans before the rinse cycle.
Always wash cast iron and wooden handled items by hand
WHY DOES MY MACHINE HAVE A WATER SOFTENER?
If the water is soft (i.e. does not contain calcium particles), the detergent will work more effectively and there will be less streaking on dishes. Hard water can also block the washer jets with lime scale and cause deposits on heating elements, which will reduce the cleaning efficiency, increase electricity costs and shorten the life of the machine. All dishwasher manufacturers (Bosch, Miele, Siemens) and detergent suppliers want you to get the best results from the machine - and soft water is one of the most important factors in achieving this. The way to ensure water remains soft is to regularly top up the reservoir with granular salt.
Three in one salt tablets do not activate the water softener.
HOW MUCH SALT DO I NEED TO ADD?
Your machine may have a float indicator or a warning light to tell you when salt needs adding to the water softener. Often float indicators are difficult to see, and there is no accurate guide as to how much salt you need to add. Quite simply, just add granular salt to the reservoir until it won't take any more!
The softener will use the salt to replenish itself each time you wash. As an approximate guide, you should do a full top up about once a month. If your machine doesn't have a warning light, a good way to remember to check and / or top up is to do it on a regular day of the month (e.g. the first Saturday or the 15th)
CAN I USE ORDINARY TABLE SALT?
No. Table, cooking, rock and sea salts may contain additives that can actually increase water hardness. Also, the fine consistency of some of these salts mean they are likely to clog when wet. Always use granular dishwasher salt because it is very pure and is the right consistency for use in your machine.
Granular salt is the ONLY type of salt that should be used to regenerate the softener. Be aware that some varieties of ‘dishwasher salt’ use Dead Sea salt. This variety may contain minute insoluble organic matter that may adversely affect the resin within your softener over time. If you are in doubt about the origins of the salt, ask the retailer or manufacturer.
WHAT DETERGENT SHOULD I USE?
All modern dishwasher detergents are formulated to work specifically in dishwashers. On no occasion should ordinary washing up liquid be used, as it will cause excess foam, which can result in a leak. If it is accidentally used, sprinkle ordinary salt into the chamber to disperse the resulting suds. Then rinse away the excess salt before using.
There are 3 main types of dishwasher detergent - Powder, liquid or gel and tablets. Which one you choose will be down to personal preference, but most people find tablets very convenient, although using powder is usually more economical and liquids are less abrasive on more delicate items.
WHAT IS RINSE AID?
Rinse Aid is added to a special compartment in the machine and a very small amount is released during the final hot rinse cycle, to reduce the formation of water droplets on crockery etc and so ensures that the water dries away properly and evenly to avoid leaving smears.
Dual action detergent usually contains rinse aid, which is released at a different rate to the cleaning agent and so helps reduce smearing etc without the need to add separate rinse aid. Some 3-in-1 tablets contain an ingredient, which has a 'salt action', which also helps to improve cleaning, but NOTE this is not a substitute for adding salt to the water softener.
The salt action takes place in the cleaning chamber of the machine, but does not actually replenish the water softener. Research has shown that whilst 3-in-1 detergents do clean dishes effectively, their performance is improved by adding salt to the water softener reservoir.
As the performance of machines can vary, as can local water conditions, it is always best to follow your manufacturer’s advice. Some manufacturers advise that if you have unsatisfactory cleaning performance eg white powder residue, poor drying or dirty dishes, then you should return to using three separate products ie detergent, rinse aid and granular salt. Be aware that if you have not been filling the salt reservoir and relying on the salt in 3-in-1 tablets, then it may take a few cycles to re-generate the softener.
hope this helps u
please rate me..................
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Dishwashers
Dirty glasses
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Sep 29, 2007 | Tricity Bendix 24 in. BDW53 Free-standing...
Dishwashers Logo
190 people viewed this question
Top Dishwashers Experts
