Question about Akai CFTD2083 20 in. TV/VCR/DVD Combo
Akai cftd15298 movie gets stuck in the tv-dvd
    Genius:
  • 1,139 Answers
What you can do with the set turned off is to open the back of the set and find the DVD load and unload motor, manually turn the load and unload gear on the motor and this should eject the DVD.
Posted on Sep 19, 2007
Need replacement remote control 5.1 Akai HHT-006
This company or eBay
AKAI TV Remote Controls ' AKAI Replacement Remotes for TV, DVD ...
https://www.replacementremotes.com/AKAI/Remote-Controls/
  1. Cached
ReplacementRemotes.com offers AKAI remote controls for sale online including remote controls for TV, DVD Player, TV/DVD Combo and many more. Missing: 5.1
Akai TV Remote Controls ' eBay
www.ebay.com > ... > Akai TV Remote Controls
  1. Cached
  2. Similar
AKAI KC02-A2 OEM Replacement TV Remote (LCT3701AD,LCT3201TD,LCT2701AD) ... Akai Samsung TV Remote Control Replacement BP59-00069A. $9.99. Missing: 5.1
replacement remote control 5 1 Akai HHT 006 Google Search
Apr 14, 2017 | Akai Televison & Video
Tv stuck in dvd mode
There should be an input button on the tv to allow you to switch between dvd, tv and any other device you have connected.
Aug 22, 2014 | Akai LCT3201TD 32 in. LCD Television
Need wiring diagram for DVD PLAYER ASSY DL-06LS-M1
i'm trying to hook up a dvd player to my lcd tv.i can play a movie through the tv but i cant record tv on to the dvd player.i only have antenna tv can you please solve this problem for me.
Jan 15, 2010 | Akai LCT3201TD 32 in. LCD Television
Tv will not come back on,inserted a DVD and tv went blank, no sound, no picture
prob your choice of dvd movie, tv's pouting right now, just a temp prob, will turn its self on when finished with tantrum
Nov 26, 2009 | Akai LCT3201TD 32 in. LCD Television
Volume is stuck on 0
Akai TV's are knwon for various issues, this is one of the ones i have had to deal with repairs for many times now, first jsut pwoer reset it, unplug it for 3-5 minutes and try another outlet, try a dvd player as well jsut o insure there is no sound, akai has no tech support as they ahve gone out of bussiness, i suggest calling the local television repair center or returning it
Jan 24, 2009 | Akai LCT3285TA 32 in. LCD Television
Akai hd projection tv pt4299hd won't turn on
Sounds like a power supply issue. Does the power indicator light up? Can you hear a click when the power button is pressed?
May 31, 2008 | Akai PT4298HD Rear Projection Television
DVD Volume
Could be the audio format for some movies to enhance surround sound, but could also be a mixer problem on the audio portion of the TV input...accordianman
Feb 27, 2008 | Akai LCT2701TD Television
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
Dvd connection
probably either the tv or the DVD are in the PAL system check if they are, if yes then change to NTSC.if that does not work then you check your connections.if not you will have to call in a tech to look at your set.good luck.
Apr 26, 2007 | Akai LCT3215/26 32 in. LCD Television
Akai CFTD2083 20 in. TV/VCR/DVD Combo Logo
168 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
