Zanussi 1600 The washing machine is put on a regular cycle and finishes half way through, and the play/pause button is flashing. The clothes are half washed/half spun... Checked the water filter and it is full of water (repeated this twice and same result) - any ideas?
    President:
  • Washing Mach... Master
  • 662 Answers
There is a difference between the water filter and the machine filter. Obviously your machine filter (check manual) is clogged with lint or muck. Usually it is in the front, a small trap like door. Inside you will find a screw-able white knob. Keep some towels or tray to collect water. (Machine shd be off the wall mains). You might find a closed hose in here, it may be to drain out excess water. Or adjust the knob according to the water flow. Take out filter to clean under sink tap. Refit as you dismantled and you are ready to go.
Beyond the filter you may feel for the pump blades - these shd turn freely - to tell you that your pump is fine.
Click if helped.
Posted on Apr 24, 2013
  • 1 more comment
  • prem mathew Apr 24, 2013
    Actually your filter cover is at the bottom front right of washer behind a drop down cover or flap.
  • Lucia Sheehan Apr 24, 2013
    Thank you - this is the filter I was talking about - we did clear that out and it was full with water both times.
    Keep searching the internet, for the moment i hv to run, till later then
  • 1294 Answers
SOURCE: zanussi jet system 1200
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Press "end of cycle" to finish the mid stoppage..
Rate me pl.....if helped.
Posted on Jan 02, 2008
  • 1294 Answers
SOURCE: washing machine stops mid-cycle and full of water
Posted on Jan 06, 2008
yalmer
  • 549 Answers
SOURCE: My siemens XL 1600 washing
If it is out of balance this can occur.
Try leveling and then make sure the load is not lop sided.
Posted on May 27, 2008
  • 3 Answers
SOURCE: GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Posted on Nov 30, 2009
SOURCE: Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Posted on Nov 20, 2010
Problems with programme (washing cycle) how to reset
Her indoors did this on a regular basis, I just held in the power button until the display flashed and it reset itself. Good luck
Jun 30, 2014 | Zanussi ZWD12270 Front Load Washer / Dryer
Zanussi washing machine pause button flashing machine wont work iz141s
Disconnecting the wires from the main PCB helped resolve half the problem, but the machine still does not rinse and spin. Unless programmed manually. Still, that's easily done at the end of a wash cycle. Is liveble.
Jul 24, 2012 | Zanussi ZWF1440 Front Load Washer
Essential 1600 washing machine - after pressing start washing button machine will work for 5 minutes then green 'end' button starts flashing and machine beeps - this repeats until cycle is finished and a ...
(try this!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 25, 2011 | Zanussi Washing Machines
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
ZWD1480W - the cycle will not complete when i programme it for a wash. Half way through the cycle it stops. The drum remains full of half washed clothes and will not even respond to spin or rinse. I have...
Thanks for replying. I was able to solve the problem by clearing the filter and draining the samll tube beside it. I was unaware that the filter needs to be cleared regularly.
Jan 11, 2010 | Zanussi ZWD1480W Front Load Washer / Dryer
Hi - I have a Zanussi ZWF16070W.When set for 1600 spin, it intermittently finishs the cycle and clothes are far from dry/spun. I have checked obvious filter for clogs etc. When I reset to spin cycle only...
Check the motor controller, and also the lid switch for proper operation.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Zanussi Washing Machines
WASHING CYCLE STOPS AFTER A MINUTE
Can you skip through the programme to drain? Press pause button. then press start to move the lights down to the empty cycle. leave to finish.
If you have already tried this, I can explain how to put machine into engineer test mode, which will then give out a fault code to identify problem.
Apr 04, 2009 | Zanussi FJD1266W Front Load Washer
Zanussi washer
Press "end of cycle" button to clear.........................
Jan 04, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi jet system 1200
Jan 02, 2008 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
