Make a code and test the c++ code that will use a function and pointer/s that will input an integers (three) and display in ascending order.
    Brigadier General:
  • 10,406 Answers
Nice try! Find an upper-class student to give you one-on-one tutoring with your homework.
Posted on Dec 02, 2009
I am using the TI Nspire Cas Graphics Calculator. I have calculated a linear regression that has been copied to f1. When I go to graph the function it is displayed in f1 as 100.x+2000. when the function...
Scientific mode is a display mode. It concerns the display of results. If the number are too small or too large they will be displayed in Scientific mode, because the screen does not have an unlimited number of digit positions.
Regarding the dots. A number followed by a radix mark (decimal mark) is considered to be a floating number, while the same number without a decimal mark is considered an integer (whole number).
The CAS is able to do symbolic and exact calculations, so that distinction between floting and integer numbers is important. Sometimes, to force a result to be displayed in its decimal representation all it takes is to append a decimal mark at the end of an integer.
Hope it answers your queation.
Apr 23, 2011 | Texas Instruments TI-Nspire Graphic...
How do you graph a greatest integer problem
To graph a greatest integer function, follow these steps:
1.) Press Y= 2.) Press MATH, then scroll to the right one column and select "int(" 3.) Enter your function inside of the parentheses, and make sure to put a closing parentheses at the end of the function you are inputting. 4.) After you have closed the parentheses to the "int(" command, add 1 to the end of the equation. This is because the "int(" command tells the calculator to take the lowest integer of the value inside of it. If you add one, then instead of .68 becoming 0, it becomes 1, and 1.724 becomes 2, etc.
Feb 27, 2011 | Texas Instruments TI-83 Plus Calculator
My cabrio wtw6200sw2 has F50 code and won't spin I can't seem to find out what the code means. Could it be the motor coupler or controller board?
The F50 code for the Whirlpool Cabrio is most commonly a Motor Control Board failure.
Motor Stalled
F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation.
? Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction.
? If basket turns freely, see TEST #3, page 4 of the Diagnostics and Repair manual.
The Diagnostics and Repair manual can be downloaded as a PDF document file here:
http://www.mediafire.com/?np4yufblj33c0xm
DIAGNOSTIC TESTS
There are three diagnostic test modes available: Automatic, Manual and Console. These tests allow the factory or service personnel to test and verify all inputs to the machine/motor control. You may want to allow the automatic test cycle to complete prior to going into specific troubleshooting tests.
ACTIVATION OF AUTOMATIC DIAGNOSTIC TEST MODE
  1. Be sure the washer is in standby mode (plugged in with all indicators off; or with only the Clothes Clean or Done indicator on).
  2. Select any one button (except POWER, START, STOP and PAUSE/CANCEL) and follow the steps below, using the same button (remember the button):
  • Press/hold 3 seconds.
  • Release for 3 seconds.
  • If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display.
  • If indicators do not display as described above, the press/hold/release procedure above may not have been performed within the time frame necessary for successful entry. Repeat step 2 to ensure this was not the cause.
  • If still unsuccessful, see Diagnostic: Unsuccessful Entry.
  1. The program then checks for saved fault codes:
? If there are no saved fault codes, all indicators on the console will momentarily turn off, then
turn back on with 88 displayed. After 5 seconds, the Automatic test, below, begins.
DIAGNOSTIC: Automatic
Performs a five-minute automatic test with water functions to check major washer functions (door can be open). Press the same button used in step 2 above to advance through automatic test steps.
NOTE: Basket must be floating in order to agitate.
Feb 01, 2011 | Whirlpool WTW6400SW Cabrio Washer
Confusion on creating a prograM
"Input" is a command, which inputs a value. Try this:
Input X:tan^-1(1/X)
Apr 14, 2010 | Texas Instruments TI-84 Plus Silver...
Asking for the PKU Code Where do i get this number
Finding a PUK (Personal Unblocking Key) number is not tough job. To find a PUK code all you have to do is call up on the customer care number and ask them to help you with the issue. Before they provide you the PUK code, they will ask you several questions. You need to give them the appropriate information. Customer care of your service provider are the only source from which can give you the PUK code.
At the time when you enter a wrong pin number three times. The phone asks you for a PUK number. The PUK code is generally eight digit number This PUK number is an unlocking code which helps you to unlock the phone and use it. If you enter a wrong PUK number 10 times than you simcard gets rejected. Then you will have to but a new simcard. It might happen that your phone might ask you for PUK2 after you enter your PUK number.
Aug 15, 2009 | LG Vu CU920 Cellular Phone
Aks the user to input words and arrange them in ascending order
I HAVE SONY VAIO VGN-CR354
OPERATING SYS. IS VISTA
MY PROBLEM IS THAT THE SOUND THAT COMES FROM THE SPAEAKERS IS VERY LOW EVEN WHEN I INCREAS THE VOLUME.
Mar 27, 2009 | Apple Computers & Internet
Please Solve this C++ Program
Write a program to prompt the user to input several lines of input. A line of inputs is terminated by '*'. For each readline of input the program should output:(use pointer notation for the array) . The total # of words . The lenght of the longest word in the line At the end the program should output: . The total number of words read in all lines of input . The lenght of the longest word read in all lines of input
Jan 19, 2009 | Computers & Internet
C++ problem
I guess this can be done quite easily with stl sort function:
http://www.sgi.com/tech/stl/sort.html
You can also code a sorting algorithm like quicksort or bubblesort yourself. This is quite fun!
Nov 28, 2008 | Computers & Internet
Pls. help me
Q.2#  Dim n, sum as Double
Dim i as Integer
n=100
sum=0
for i=1 to n
sum=sum+1/n
next i
Q.3#  Dim sum as Double
sum=0
for i=1 to 99
if i%2 <> 0 then sum=sum+i end if
next i
Sep 16, 2008 | Microsoft AccRepair DS2 2004 for Fr...
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
