Question about Ovens
Technika B59FTI/1 GRILL WORKS BUT OVEN WON'T WHEN ON FAN FORCED POSITION
  • 1462 Answers
SOURCE: Grill element stopped working in
there is no fuse actually in the oven
take rear panel off oven and use a multimeter to check continuity across the grill element. can also be the grill regulator if fitted
Posted on Jun 29, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 1214 Answers
    SOURCE: bottom oven not working
    A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
    If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
    A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
    Posted on Jan 14, 2009
    SOURCE: I need a user manual for my tecnogas oven and
    how to operate tecnogas built in oven
    Posted on Nov 06, 2009
    • 69 Answers
    SOURCE: my omega europa oven is not heating up .grill fan
    Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
    Posted on Mar 18, 2010
    Technika bf59fti
    Model: B59FTI/1
    Type: B600
    Cod: HDEV2NAI
    Vac: 240 V
    Hz: 50
    Watt: 2300 w
    Jul 01, 2014 | Ovens
    Technika bellissimo oven
    Have a Bellisimo Technika free standing oven. Cannot get oven to heat on fan force setting but it works on all others. Please help
    May 19, 2013 | Ovens
    Technika oven manual - mod B50STIP/1
    I have a Technika B50 STIP /1 Oven and the Oven Function Selections have warn off. I mostly use the conventional cooking ) at 7.00 oclock on the dial) I cannot remember what is on the dial at 5.00 oclock? as it has worn away.
    Help please
    Liz
    Aug 05, 2012 | Ovens
    NEW WORLD - NW601FP Electric Oven
    i believe after buying this oven that the left knob at turning clockwise position 1 is defrost which works by just blowing room temp air around, position 2 is oven on, position 3 is conventional grill must be used with door open and position 4 is fan grill can be used with door closed ,and the knob on the left is for setting oven temp and and turn fully round when using the grill to heat the grill
    Jan 17, 2012 | New World Ovens
    All oven grill and fan elements dead
    The oven will not warm if the clock is not set as the main oven is directly linked to it. You may want to check your wiring to the element you have changed as all elements use the same neutral path, meaning if you missed a wire off (especially if you pulled it out through the oven cavity) or have put them on the wrong tab it won't work. It could also be a duff element (the new one).Let me know if you need any further help.
    Dec 07, 2011 | Neff Ovens
    I have a cooker model venezia FE 8622EX and i dont have a manual for it and cant work out with knob does what as the writing is rubbed off through use...please help!
    The 3 knobs each have 6 positions corresponding to clock-face positions 2,4,5,7,8,10 o'clock.
    Left - Grill Temperature 1-6. (Note Oven Temp needs to also be turned on before grill will work.)
    Centre - Function
    1 - Lamp
    2 - Defrost (fan only)
    3 - Fan Assisted Oven
    4 - Grill
    5 - Grill with Fan
    6 - Fan & Bottom Element
    Right - Oven Temp 50,100,150,200,250,Max (celsius)
    Sep 12, 2011 | Ovens
    Omega Europa 20-1 oven. What do the symbols mean?
    Fan symbol - defrost (fan only - does not use thermostat)
    Fan symbol within a circle - fan forced oven
    3 little triangles - static grill (keep oven door open)
    3 triangles above the fan symbol - fan grill (keep door closed)
    Oct 03, 2009 | Ovens
    Not heating in fan forced mode
    Possibly your fan element has blown. Try and take the cover off that coves the fan inside the oven itself and use a torch to look at the element to see if it looks out of shape etc.
    Jun 15, 2009 | Fisher and Paykel OS302SS, Stainless Steel...
    Ovens Logo
    167 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
