Question about Kenmore 64902 Electric Dryer
G.E. electric dryer terminal block and wires are burnt. I took the dryer apart to clean the inside of dust and lint. I put it back together and plugged it in. The breaker tripped,and I looked at the terminal block to find a meltted mess. What may have caused this?
  • darkspark1 Mar 14, 2009
    I thank you so much for your quick response. I am not sure how old the dryer is. My guess would be between 8 and 12 years old. Wether it makes a diffrence or not,the power cord is 3 prong, not 4. If your first answer is you're only answer,please respond anyway because I am trying to give you a good name on this site. Thanks again for your help.
  • Anonymous Mar 23, 2014
    Have had periodic problem with dryer starting. This time is tripped breaker and melted the plug end of the cord. We have cleaned lint from where we can get to but not sure how to get inside to see motor
  • 63 Answers
You did not say how old? but I find that all it takes is one wire to get old, and starts to heat up because electric cant flow through it, then it gets worse and worse fast, then heats up the whole block, till the whole thing gets melted...bad thing is its happens slow enough that the standard 30 amp breaker won't trip during this slow melt down!
Posted on Mar 13, 2009
  • John Hartsek Apr 10, 2009
    sorry so long to respone to this...I'm new on this site , and did not relize that I got feedback on my e-mail...leaning! I wish I had a better answer for you but ....do not , if you want to keep the old dryer going I would cut back the burnt ends and replace! the ends are hard to find because of there size (#8 wire) good luck
How do you take off toe panel from he3 electric kenmore dryer to clean plugged lint
Hello;
My name is Peter. I am a retired field service appliance technician.
There are two spring clips, one on each side of the bottom toe plate panel.
Dec 02, 2014 | Kenmore Dryers
Message constant check screening. screening is clean how do i fix model 110-82822-102
There is a pressure switch or an electric eye that is plugged with lint or burnt out. Who makes that machine?
Dec 01, 2014 | Dryers
Lint screen to be clean .so I cleaned the lint box
Not sure how far down you took apart your dryer to clean it out, but I've found that I sometimes forget to re-hook up the door switch connector when I'm working on dryers. So, my advice would be to first check all your connectors. Then, check to see if you might have accidentally pulled a wire off of a terminal somewhere along the way.
Oct 18, 2014 | Dryers
I have a 20 year old electric dryer that normally works great. All at once the dryer stopped heating, but otherwise works normally. I took the dryer apart, checked continuity of the heat coil, hi limit...
The problem is the terminal block, Vibration with the cord not being fastened to the block tight enough caused overheating at the block and it failed. Replace it.
Jul 19, 2013 | Dryers
My whirlpool dryer model LER4634EQ2 sometimes takes really long to dry a load of wash
most likely it's blocked with lint.all a dryer does is move air,if something is blocked the air can't move and it takes longer and longer to dry clothes.your lint filter is on top,unplug the dryer ,pull it away from the wall, disconnect the vent line,remove the back panel,on the left side you'll see a metal duct that the lint filter slides into,take that off and clean it out,first remove the lint filter and the two phillips screws that are in front of it on the top panel.now go in the back and remove the four screws that hold the duct in,clean out the duct and if you have a shop vac vac up any dust you see bakc there and then set it up to blow and blow through the blower wheel until it's clean,put the duct back into place,now if the vent line is long you can blow that out with a leaf blower,first go outside and make sure nothing is blocking the outside vent,if there's a cage or anything outside that's blocking the air from blowing out remove it and don't put it back,go back inside and blow out the vent line,put the dryer back together except the two screws in front of the filter on top,with a screw driver pop up the top lid,you'll see two 5 1/16 screws one on each side of the front panel around 2 inches down from the top,remove them disconnect the wire harness on the right side and then pull up one side at a time to remove the front panel,if you don't want to pull the drum use the shop vac to blow all the lint from in the back forwards and vac it up,put it back together and do a load,you should see a big change in the time it takes to dry the clothes.go here to see how to take dryer apart
http://www.youtube.com/watch?v=xGIG8Wo5-N4
good luck and i hope this helps,i can't see it being a part because if a part goes bad it will work or it won't,the only other thing i can think of is the cycling thermostat could be bad or if you use cling free sheets lint could be stuck on the back of the t-stat,when you're in the back and have the duct off,look to the right down low,you'll see the t-stat with four wires on it,just remove the screws,don't have to disconnect any wires and look at the back of it,clean it off if you see any white film or lint on it,i've seen this happen before.hope this helps.
Mar 09, 2013 | Whirlpool LER4634J Electric Dryer
How to clean
Simply blowing out the duct may not remove all the lint because if you use fabric softener the exhausted lint tends to stick in the duct. Thorough cleaning with a brush will be more successful
Mar 06, 2013 | Dryers
Help - problems with screaching/grinding sound - small smell of burning
Did you remove the filter chute? My dryer was making a heck of a racket and I found a wire inside the blower housing:
Service manual and more
Nov 14, 2011 | Kenmore 659 Electric Dryer
All the clothes in my dryer dry at a normal time, but the smell burnt! After a dry cycle, the inside of the dryer smells like something is melting, but everything seems to be working correctly. We have had...
Remove the vent duct at the back and clean out all of the lint. Next, find the air inlet to the heater elements and make sure there is no lint accumulated there. Inspect the back of the drum (inside) for any plastic debris (something left in a pocket?) that might have melted and stuck on there. Last resort: remove the dryer cabinet and drum, and inspect the heater and its wiring. If the insulation on the wires appears burned or is broken off, cut off the damaged part of the wiring and replace its terminals, then polish the heater terminals before reattaching the wires (a tarnished connection will cause the wire to overheat). Clean out the heater if necessary, but be careful not to stress the heater element. Used heater wire is brittle and cracks or breaks easily.
Jul 04, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
I have a roper dryer. I took it apart today
Remove all duct work connected to this dryer. Clean thoroughly. You will find amass of lint inside of it causing your problem. If not the moister sensor is not working properly and needs to be replaced.
I do hope you will find a clogged vent tube for it is easier to clean the tube than to replace the sensor. The sensor is a fail safe part. It keeps the dryer from catching on fire when the lint tube is clogged up
Apr 27, 2010 | Roper REX4634KQ Electric Dryer
Not heating good
If replacing the control thermostat does not remedy the problema, then timer replacement is nessesary.If it was me I would replace the thermostat first.What I really suspect is a burnt contact inside the timer at the RH terminal. Yours is not totally fried but well on the way.
If you are careful you can clean the contacts inside the timer. You must remove the small retainer ring before removing the plate or the timer will never go back together correctly(that is the secret,Shh!)
Nov 21, 2008 | Roper REX4634KQ Electric Dryer
Kenmore 64902 Electric Dryer Logo
369 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
