Question about Whirlpool Duet GHW9150P Front Load Washer
The duet washing machine fills up with water in between loads. What is Causing This?
My Whirlpool Duet washing machine fills up with water in between loads...usually 1/2 full. It starts smelling musty too. What could be causing this? Please advise :)
  • 2 more comments
  • JDM-MN Nov 11, 2007
    Same problem. Will likely look for a $10 replacement valve and see if that sovles the problem. Only steps I have taken so far is to read web sites.
  • Hal2 Nov 11, 2007
    Ours only fill a few inches after using the delicate cycle. Did anyone ever solve the problem?
  • Anonymous Mar 13, 2014
    only one year and 3 months
  • Anonymous Mar 14, 2014
    whirlpool cabrio washing machine starts to fill with water then quits not fill tub all the way
Dont want to endorse a commercial site, but you can by a generic part for a bit over $10 for this problem, so do some seraching for a reasonable site (other sites are charging 40-50 dollars for a fill valve.
Posted on Aug 09, 2007
Bad fill valve (where hoses connect at washer)
Posted on Aug 05, 2007
SOURCE:
Duet whirpool front loader is filling with water on its own
The washer fill valve is defective and will need to be replaced. The fill valve is right under the main top at the back the fill hoses attach to the valve.
Oct 07, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool front load keeps cycling without the water filling.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool duet washing machine is collecting water in the tub after laundry is long done
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Kind of the opposite of these tips... your fill solenoid has dirt in it and it won't shut off...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code F 33 on whirlpool duet waher. Sevice guy
i think that has to do with not filling .. does water enter machine. is it filling slow?
Apr 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Canyou adjust the water level on a whirlpool duet front loading washing machine model ghw9150pw3?
no and if you fill by hand and attempt to start an wash cyc it should pump out the water first
Aug 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer fills up with water
Jamesbestor,
The water fill selenoid had junk in it holding the valve open or the seat in the valve is damaged.
Turn off the power and water, remove two screws on the back of the machine and remove the lid.
On the back left top corner are the water fill selenoids. Remove these and disassemble by undoing the 6 or 8 screws ( depending upon model ) holding the unit together. Clean and reassemble, it should take care of the problem. If not, replace the selenoid.
Feb 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loading washer
your inlet water valve is not closing and needs replacing, in mean time turn water off between washings.
Apr 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
712 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
