Question about BenQ Televison & Video
Power supply circuit board
Suply problem
    Top Expert:
  • BenQ Master
  • 75,571 Answers
What is the problem you faces with power supply? No switch ON? Low output voltage? Provide more details please. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window.
Posted on Apr 24, 2013
STR3BR1065 NOT WORK POWER SUPLY IS DEAD
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Aug 19, 2014 | Televison & Video
My panasonic th-42ph11uk isnt powering up.. One day it was working and the next dead. Can pushing the power button too hard make it not power up. Like some electronic equip does. I also used the remote to...
Maybe the power supply is the problem of your television.Either it is loose connection in power supply circuit.Its need to resolder the loose connection and cold solder of the power suply circuit..
Jul 11, 2011 | Panasonic TH42PH11UK 42 in. Plasma TV
I have VIZIO Model # VP50HDTV20A. While we were watching it shut off, then i call VIZIO about what happen, they told me to unblock the power then hold it the power switch for a min then try to block in...
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jul 06, 2017 | Vizio P50HDTV10A 50 in. Plasma HDTV
Power suply
If the power supply fried, it is likely one of the power amp channels, usually the rearmost one has fried. There is a weak insulation thing between layers of the multi-layer circuit board that shorts.
DO NOT replace a fuse in a failed unit till problem is fixed as you will LIKELY do more damage!!!!
Nov 16, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Tv doesn't power up
Check ur power source with other devices?Yes.than ur tv power supply board is dead.Replaced the power suply board will solved this problems.Tries wesites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 27, 2010 | Vizio VW32L 32 in. LCD HDTV
I have an old Zenith L30W36 that wont show anything.
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 29, 2009 | Zenith L30W36 30 in. LCD Television
I Need a power suply
These units don't have a separate "power suppy" per se. There is a power transformer and a separate board that contains the standby power supply components. The main power supply components are on the main board.
Rather than looking for a "power supply", what is the problem with the unit? Is there a standby light?
Dan
Mar 13, 2009 | Sony Audio Players & Recorders
Power board
power suply boards can range in price. The most i've seen was $289.00. I've seen cheaper. Are you sure you need a power supply?
May 10, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Tv no go
the circuit board will be damage as well , new tv is needed
Apr 12, 2008 | Sony KV-27S20 27" TV
Televison & Video Logo
Top BenQ Televison & Video Experts
Lawrence Oravetz
Are you a BenQ Televison and Video Expert? Answer questions, earn points and help others
