Question about JVC AV-32D305 32" TV
My RCA F31672ET is messed up, what can it be?
I go this tv from some old lady who said she had bought a new tv and didnt need this one anymore but whenever you have the tv on and you tap it on the side or top, the picture goes haywire. I figured it was just a bad or old fuse, can that be it?
  • 89 Answers
These unit are notorious for bad solder joints in the tuner unit. If you unplug the tv and remove the large PC board, flip ot over and you will see a large silver oblong with 3 solder points. de-solder theses and removed the cover from the tuner. Re-solder the connections along each of the sides of the oblong shaped case.and you will also see some ground pins which also need re-soldering.
put the cover back on and you should be good to go.
As always, exercise caution , Televisions can hold a charge on some of the capacitors for quite a time and can shock you even after it has been unplugged for a few mins
Posted on Mar 13, 2009
Can i use my RCA F31672ET TV as projecter for my computer? I cant find any HDMI port.
Not possible as model listed is composite video only with two additional inputs for audio--no way I know you could do this.
Mar 20, 2012 | RCA F31672ET TV
I have an RCA F31672ET TV. It was working fine for many years. Then all of the sudden it will not turn on with either the remote or the power button. I thought of using a universal remote to try and turn...
Hi - pretty common problem. Not worth fixing, I'm afraid. It is caused by a defective circuit which became defective with old age. the "EEPROM."
Feb 27, 2011 | RCA F31672ET TV
Im trying to hook up s-video to my old RCA tv and I cant get a picture. Can you help me.
Make sure you are selecting the correct input channel, and also make sure the yellow video cable is disconnected from both items. The two cables do not need to be connected in fact disrupt signal when they are.
Feb 04, 2011 | RCA F31672ET TV
I need to get the remote control for my tv. rca model F31672ET
An exact replacement remote may not be available. However, a substitute remote with the functions of the original is here: . Most universal remotes programmed 6 months after the TV was released should have a code for this RCA TV. However, it might take a bit of searching to find the right code. You might not get all of the features from the original remote with the cheapest of the universal remotes (pip, input changes, etc). The universal remotes that can be programmed via a USB connection with a computer will do all of the features but are much more expensive.
I hope this helps.
Dec 23, 2010 | RCA F31672ET TV
I have a rca tv model F31672ET. I do not have the
Check with the channel 00 good luck
Jun 05, 2009 | RCA F31672ET TV
No sound
Clip R1915 and the sound will return. But you still have a Tuner to rework. See my solution with the power problem. just before this answer!
Oct 14, 2008 | RCA F31672ET TV
use tv/video switch
May 03, 2008 | RCA F31672ET TV
Input/Output Wii System
do you need the remote, or do you have the menu button on the tv? if you dont have neither, then you could try to get a new remote.. hope it helps!
Dec 26, 2007 | RCA F31672ET TV
RCA F31672ET No Power only a whining noise when plugged in Please help
Most likely you have a bad flyback transformer and shorted horizontal output transistor. The whistling sound that you hear is the power supply telling you that it has a short in one of the circuits it powers. Most likely the circuit mentioned above. Stargazer
Mar 06, 2007 | RCA F31672ET TV
JVC AV-32D305 32" TV Logo
60 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
