Question about Mtd Garden
T205 manual please - Mtd Garden
FinePix T200 won't connect to computer via USB
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 16, 2013 | FUJIFILM FinePix T200 / T205 Digital...
Tip
Motorola Secret Codes
<span>Motorola L6:<br />-----------------<br />hold * 65512890 for reset<br />hold * 5806 sw version<br />hold * 487989 NS lock menu<br />hold * 482896 CP<br />hold * 574243 NS<br />hold * 967678 SP<br />hold * 362628 IMSI<br />hold * 787090 Lock net level<br />hold * 787292 Lock net level<br /><br /><br /><br />Reset L7 security code without any cable<br />------------------------------------------------<br />press menu button enter 6 time 0 and then press ok<br /><br />*#06# IMEI<br />in permament test mode<br />(* hold 2 sec)<br />***113*1*[OK] net monitor<br />T205/T19x (ACER)<br />*#300# OK List the Software and Hardware version<br />*#301# OK Full Keypads functional Test<br />*#303# OK Set Default Language to English<br />*#304# OK Set OFF engineering mode<br />#304*19980722# OK Set ON engineering mode<br />*#305# OK Location: 1 OK<br />*#307# OK Engineering Test Mode<br />*#311# OK Phone code changed to default code<br />*#400# OK ADC, Cal val*<br />*#402# OK Adjust Display Intensity / Contrast<br />*#403# OK List the Manufacturing Informations<br />19980722 OK Master Unlock code for Phone and Sim Lock<br />*#302# OK Acoustic test*<br />7.1 Greeting<br />7.2 Main VlmGain<br />7.3 Input Cal<br />7.4 Output Cal<br />7.5 Side In Gain<br />7.6 Vox Gain<br />7.7 Min Mic Engy<br />7.8 More<br />(a) In Vlm Gain<br />(b) Aux Vlm Gain<br />(c) Silence Prd<br />(d) Supp Prd<br />(e) In Volume<br />(f) Out Volume<br />(g) Icon<br />(h) Image<br />(i) Animation<br />*3370# EFR ON (enhanced full rate)<br />#3370# ERF OFF<br />*#72837726# OK Confirm ?, Data saver<br />1234 OK Phone code default<br />*#0000# OK Setting saved, restore set phone do default language<br />*#0048# OK Fast change polish langpack<br />*#0007# OK Fast change russian langpack<br /><br /><br /><br />MOTOROLA 3xx<br />------------------------<br />*#06# and quick 'menu-key' and 048263* (Push the key quickly!)<br />and entering at field "OPTCODE" you must try several times.<br />If not working try with MOTO TEST CARD inserted.<br />Security code - 32*118*1*0*0<br />Model - 32*279*1*0*8<br />Flex ver - 32*383*1*0*0<br />Master Reset - 18*0<br />Master Clear - 18*1<br />Set band GSM 900 - 10*0*3<br />Set band DCS 1800 - 10*0*4<br />Set band PCS 1900 - 10*0*5<br />Set dual band GSM 900/1800 - 10*0*6<br />Read band - 10*1*0 =&gt; 3-GSM, 4-DCS, 5-PCS, 6-GSM/DCS<br />User code - 32*116*1*0*0 /coded:00310032003300340000 - 1234/<br />Read imei - 32*4*1*0*0 "OK" /coded:083a05092700247709 - 350907200427799/<br />47*4*1*0*9*081A32547698103254 =&gt; IMEI=123456789012345<br />it is possible to change IMEI<br /><br />ENJOY</span>
on Jul 11, 2011 | Cell Phones
Tip
MOTOROLA CODES
>>All Motorola Secret Code<<
Motorola L6:
hold * 482896 CP
hold * 574243 NS
hold * 967678 SP
hold * 362628 IMSI
*#06# IMEI
(* hold 2 sec)
T205/T19x (ACER)
7.1 Greeting
7.2 Main VlmGain
7.3 Input Cal
7.4 Output Cal
7.5 Side In Gain
7.6 Vox Gain
7.7 Min Mic Engy
7.8 More
(a) In Vlm Gain
(b) Aux Vlm Gain
(c) Silence Prd
(d) Supp Prd
(e) In Volume
(f) Out Volume
(g) Icon
(h) Image
(i) Animation
#3370# ERF OFF
MOTOROLA 3xx
Master Reset - 18*0
Master Clear - 18*1
Read band - 10*1*0 => 3-GSM, 4-DCS, 5-PCS, 6-GSM/DCS
47*4*1*0*9*081A32547698103254 => IMEI=123456789012345
it is possible to change IMEI.........
on Feb 09, 2008 | Motorola Mobility L6 Cellular Phone
Camera turns itself on
It could be Malware/Viruses may exist that can turn on the webcam and send images over the Internet - all without your permission., just try to fix the problem with antivirus program
Regards,
Akhilesh
India
Sep 01, 2012 | FUJIFILM FinePix T200 / T205 Digital...
I have made a folder to store some messages in my phone and now i have forgotten the password to unlock it. What should I do?
Hi!Did you change the default password of your phone?If not,try to enter or type the default password (0000) or (000000) to unlock your folder.If ever the default password is not working,you may try this other secret codes for motorola.
Motorola
c350 english languge
menu
setting
1 1 5 2 6
(T190, T191, T205) master code
- 19980722
- 20010903
P2K test menu:
*#06#, menu, menu, 048263*
Test comands:
32*116*1*0*0 - read phone code
32*118*1*0*0 - read security code
18*0 - factory reset, phone code off
18*1 - master reset
54*18*1 - full phone reset
10*0*6 - select 900/1800
32*279*1*0*8 - model
32*383*1*0*0 - flex version
Hard reset MPX200, MPX220 - blue button + power on
Feb 25, 2011 | Motorola Mobility ROKR E6 Smartphone
Code manuelle
T205/T19x
*#06# -> Displays imei
*#300# OK -> List the Software & Hardware Version
*#301# OK -> Full Keypads Functional Test
*#303# Ok -> Set Default Language to English
*304# OK -> Set OFF engineering mode
#304*19980722# -> Set ON Engineering mode
*#305# OK -> Location: 1 OK
*#307# OK -> Engineering Test Mode
*#311# OK -> Phone code changed to default code
*#400# OK -> ADC, Cal val*
*#402# OK -> Adjust Display Intensity/Contrast
*#403# OK -> List the manufacturing Informations
19980722 OK -> Master Unlock code for Phone & Sim Lock
*#302# OK -> Acoustic Test*
*3370# -> Enhanced Full Rate
#3370# -> Deactivate Enhanced full Rate
*#72837726# OK -> Confirm?, Data Saved
1234 OK Phone Code Default
*#0000# OK -> Settings saved, restore set phone to default language
Dec 19, 2010 | Motorola Cell Phones
My husbands new watch Armitron water resistant Quartz alarm chronograph, two tone blue face 20/1441 T205 ( water resistant 165 ft ) it came with no instruction manual,the alarm beeps every hour , anyway...
Copy "www.armitron.com/watch_instructions.asp" into your search engine and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
Feb 23, 2010 | Watches
What to do?
hi friend,
Look at these service phone codes of Motorola mobile, may be it will help you in your mobile phone settings
*#06# imei
in permanent test mode
(* hold 2 sec)
T205/T19x (ACER)
*#301#­ OK ­ Full Keypads functional Test
*#403# OK List the Manufacturing Information's
7.1 Greeting
7.2 Main VlmGain
7.3 Input Cal
7.4 Output Cal
7.5 Side In Gain
7.6 Vox Gain
7.7 Min Mic Engy 7.8 More
(a) In Vlm Gain
(b) Aux Vlm Gain
(c) Silence Prd
(d) Supp Prd
(e) In Volume
(f) Out Volume
(g) Icon
(h) Image
(i) Animation
#3370# ERF OFF
MOTOROLA 3xx
Master Reset - 18*0
Master Clear - 18*1
it is possible to change phone's imei
or u can even try last 4 digits of ur mobile number
hope this helps u
thank u for using fixya
regards
sivaranjini
Nov 26, 2009 | Motorola Mobility RAZR V3
PCI video slot changed to AGP video slot
First, install the AGP card in the AGP slot. Plug the monitor into the new video card.
Second, power up and press the F2 key to enter Bios.
The system should default to VGA but through the new and only video card available. If this works you will be able to save the settings and exit. It will reboot as normal. When prompted use the cd for that card to load the drivers.
AGP was a short lived concept and aren't that many to chose from.
If you don't get any video at all, the problem may lie in the motherboard and not really repairable.
Good luck.
Jun 02, 2008 | E-Machines Computers & Internet
Garden Logo
60 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
