Question about Remington Polesaw Wizard
Need plate that secures saw to pole
It is a remington ten inch
5 Suggested Answers
SOURCE: Remington Pole Saw
go to www.desatech.com that what i found my manual it the same one you have
Posted on Sep 16, 2008
  • 188 Answers
SOURCE: Remington Pole Saw Model # 106890-020 - Chain Oil Cap broke
Call Master Parts at 1-800-446-1446, or go online at www.masterparts.net. They have the part (107512-01) you need. I hope this helps...
Posted on Apr 27, 2009
SOURCE: what type of oil do I use for a Remington Electric Pole Saw?
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
Posted on May 25, 2009
dontbother10
  • 2220 Answers
SOURCE: chain fell off chain saw remington 10
Look from the side of the saw the motor/engine to left and the bar nose to the right. The thinnest part of the chain (sharpened edge) on the top of the bar is to the right.
Posted on Sep 27, 2009
  • 4088 Answers
SOURCE: Am I wise to purchase a Remington Pole Saw or
Remington Saws have ceased operations and, unless you like to make your own replacement parts, they are prone to failure. The gearbox is sealed and the motor brushes are not available anywhere. Look elsewhere!
Posted on May 11, 2010
How do you attach the chainsaw to the pole?
You simply mount the saw between the two metal plates.
There are two screws holding the plates together.
Look in the owners manual and it will guide you how to attach the saw.
Once the saw is attached, plug in the power cable that is on the end of the pole. One word of advice....there is a large locking collar ring that enables the two poles to extend and lock together. There has been numerous reports that the locking collar ring splits due to overexersion. You can add a stainless worm clamp (similar to a radiator hose clamp) around the rind and tighten it securely. Be sure it is a heavy duty wide clamp. This will help to keep the ring from splitting under pressure.
Jun 25, 2014 | Remington Electric Pole Saw
Need brushes for a 111409-01 branch wizard
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
May 03, 2014 | Remington Electric Chain Saw
Trouble starting
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Apr 19, 2014 | Remington Electric Chain Saw
Extremely weak motor model 108526-01 remington
Feb 12, 2014 | Remington Garden
Are brushes available for remington 106890-02
Nov 06, 2013 | Remington Electric Chain Saw
Am I wise to purchase a Remington Pole Saw or should look for another manufacturer? Which Remington Pole Saw would you purchase: a. 18V Cordless b. 10" Electric
May 11, 2010 | Remington Electric Pole Saw
I need a new 10 inch bar 097567-01 It is for a remington pole saw
I went here:
Remington.com
http://www.desaparts.com/index.htm
Typed in the part number you provided, clicked search and found Part #: 10SB Price: $13.98.
The parts Gods just smiled on you.
RemingtonPower has stopped production and most replacement parts are NLA. I suggest you waste no time placing your order. HTH
Lou
Nov 10, 2009 | Remington Electric Pole Saw
What is the part that you need to secure the electric pole saw to the pole? I know it is a black plastic piece that I have lost. Please advise.
An IPL for 3 different types of Remington Pole Saws can be found here:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/RPS96/RPS96_BD.pdf
RemingtonPower has ceased production. Parts availability is limited to what is on hand.
If these aren't your saw provide the correct model number and we'll try again. HTH
Lou
Oct 18, 2009 | Remington Polesaw Wizard
I NEED PLATE that covers button and secures chain saw to pole (10inch pole saw)
Remington has ceased production. Parts availability is limited to what is on hand. This is last site I have for anything Remington is here: GL
Remington.com
http://www.desaparts.com/remington-chainsaw.html
Please remember I'm only the messenger, not the guy that that closed the factory, and we are not affiliated in any way. HTH
Lou
Oct 17, 2009 | Remington Polesaw Wizard
Pole Saw RPS96 - - Saw 108526-01 - - The outer clamp/nut that holds the pole at the selected length has split. I guess I could use a clamp to secure it, but I'd like to replace with the correct part. Can...
Your pole saw is at the bolttom of the page here:
The parts list that appears is a chainsaw. Please phone them @ 1-800-475-5660, ask for assistance and explain this little glitch. Thanks HTH
Lou
Oct 03, 2009 | Remington Electric Pole Saw
Remington Polesaw Wizard Logo
71 people viewed this question
Top Remington Garden Experts
EugenesDIYDen
EugenesDIYDen
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Remington Garden Expert? Answer questions, earn points and help others
