How to fix f06 error in AWO/D 43425 whirlpool washing machine.drive motor tachometer error
  • 87 Answers
SOURCE: Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
Posted on Jun 08, 2007
SOURCE: washing machine
whilpool awo/d 4305 light onclean pump can i do this myself
Posted on Nov 23, 2008
jonniewalker
  • 1031 Answers
SOURCE: fault codes f 13 Whirlpool Washing Machine AWO/D 5716
f13 is a Dispenser circuit error
If the dispenser motor is not able to be driven to it’s proper position.
Potential Causes
• Check mechanical linkage from dispenser motor to the top of the dispenser.
• Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
• Check Dispenser Motor
Posted on Jan 29, 2009
SOURCE: Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Posted on Feb 05, 2009
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
I have a 7.5 kg whirlpool front loader that is showing error F06. Can this be fixed
The F/06 is:
The tech. should check these:
Check the MCU
see this website
Appliance Repair Forums
Nov 11, 2015 | Whirlpool Washing Machines
Error code F06 and E01
Here is what the F06 code stands for
If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
Motor ControlUnit (MCU), and between the MCU and the Central Control Unit
(CCU)
• Check the MCU
Dec 14, 2013 | Whirlpool Duet Steam WFW95HEXW
F06
The F06 code will indicate a drive motor tachometer error.This means the control is unable to properly detect motor speed and the machine will shut down. If the failure occurs during high-speed spin, the door will unlock after 3 minutes.
The error code F06 is likely a loose connection in the harness between the motor and the (MCU) or between the (MCU) and the (CCU). It could also be the tachometer circuit in the motor or an intermittent internal component connection within the (MCU). Since the (CCU) has already been replaced, the failure is likely a loose harness connection or the (MCU). I recommend calling a service technician to check the connection.
Hope this helps.
Shane
Mar 15, 2011 | Whirlpool Washing Machines
Keeps stopping and saying F06?? Any program its put onto it does this after a minute
Hi F06 suggests Drive Motor Tachometer Error, this means the Tachometer on the motor cannot detect speed or motion and the machine will stop.
Check the cables from the motor to the motor control unit making sure they are connected and undamaged also check for the same from the motor control unit to the main control board.
If all the wiring checks out and is secure the fault could be with the motor or motor control unit.
Probably best to seek the advice of a local washing machine engineer.
Hope this helps.
Feb 11, 2011 | Whirlpool Washing Machines
My washing machine is giving me an error message F06, what does that mean?
F06 is Drive Motor Tachometer Error.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU) .
• Check the Drive Motor .
• Check the MCU .
• Check the Wire Harness .
Please read the below link it is an article about this error from one of the senior and best expert here
http://www.fixya.com/support/t2946429-kenmore_elite_he3t_giving_code_f_06
COURTESY:JSROCK
Mar 21, 2010 | Whirlpool Washing Machines
What is the problem when I get F06
F/06 says: Drive Motor Tachometer Error. Check Wire Harness connections between the Drive Motor/Tachometer and Motor Control Unit and between the Motor Control Unit and the Central Control Unit. Check the Drive Motor, Motor Control Unit, and Wire Harness. Hope this machine is still under warranty! Good Luck!
Dec 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F06 error with a ghw9150pw4 model whirlpool front loader washer
HI There
Here what you need on error codes.
  • Check the MCU
Hope this helps let me know. Thank you for writing to fix ya.
Dec 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hi There
  • Check the MCU
Dec 11, 2009 | Whirlpool Washing Machines
Flashing code F-6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check the MCU
Replace failed component.
Apr 12, 2009 | Whirlpool GHW9300 Duet Washer
Whirlpool washing machine really loud
hi there,
error f06 means Drive Motor Tachometer Error
for this u may
  • Check the MCU
Dec 10, 2008 | Whirlpool AWM6100 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
