Question about Park ing Sensor System With Four Sensors
Nikkai sender - Park ing Sensor System With Four Sensors
I have a panasonic 3d blu ray player with internet built in. I have my system wired to a hdmi switch and then onto wireless nikkai video sender to my projector this gives me a 100 hd inch screen with...
Try connecting the Bluray player directly to your projector and verify if you have the same issue. If you do not have an issue, your switch is causing the picture to freeze.
Aug 24, 2013 | Audio Players & Recorders
I have just brought a nikkai 5.8 ghz audio/video sender so i can watch my sky in my bedroom but i am having real promblems with it i am getting no picture
I assume you have a 5.8Ghz receiver in your bedroom ? Your TV will not receive 5.8Ghz so you need a 5.8Ghz receiver in the bedroom that will give you an audio out and video out, which you connect into your TV audio in and video in .Put the TV on AV in and voila.
Apr 08, 2010 | Audio Players & Recorders
Have a Nikkai A11HJ (Distributed by Maplin, UK)
I have a Nikkai A11HJ DVD Player with a problem, it plays disk for about 7 minutes and then stops playing and reverses back to the TV, can anyone help?
Jan 30, 2010 | Televison & Video
Nikkai 2727 Video sender will not send signals from my sky+ box. The scart lead is plugged into the Video out, but even when i plug it into the TV out it still doesnt work. I know the Transmitter and...
check that you have the sender plugged into the sky box and the receiver into the required tv and not the other way round. The wrong way round still allows the controller to change channels but you will see nothing also ensure that both sender and reciever are on same channel 1 to 4
Jan 24, 2010 | Panasonic Televison & Video
Nikkai driver
Hi there and welcome here
I did find this driver : Nikai Dv7000 Driver:
http://drivers.91srv.com/Nikai-Dv7000-Driver.html
You have to give me the phone model number if you need another driver
Hope it helps
IF not, then try to return here
Have a nice time over there
About where the product is coming from, I did try to search on the internet and did find only this information :
http://www.designworldonline.com/articles/183/228/NKK-Nikkais-Best-New-Performer.aspx
http://www.applegate.co.uk/who-sells-who/nikkai-1000677.htm
http://www.nkk.com/
Please rate my answer
Jan 08, 2010 | Lands Phones
I need a remote control code for my nikkai a88jb freeview box so that I can programme a universal remote control. Any ideas?
my nikkai a88jb after connected still come up with "empty data base" . no signal of anything showing and i did plug in antenas! pls what shoul i do?
Apr 18, 2009 | Televison & Video
Nikkai usb serial convertor - no driver
i got the drivers from the prolific website (the manufacturers)
http://www.prolific.com.tw/eng/downloads.asp?ID=31
Dec 06, 2008 | Computers & Internet
Can't set up my new Nikkai 5.8GHz video sender.
Could be that the Scart socket doesn't pass through the signals from the receiver. I had a Goodmans TV with Scart input which just didn't respond to the receiver. When I moved it to the Scart connector on my VCR it worked a treat.
Nov 18, 2008 | Televison & Video
I have a Nikkai A15gy mini wireless TV/video sender, connected from a Sky box, sound is OK, but picture is distorted. The bottom 1/2 inch of the picture appears at teh top of the screen. Have tried...
Hey there Merch12, I had the same issue. I turned it off, unplugged absolutely everything and reset the trip switch in the house and left it over night, the next morning it worked like a GEM hoped that helped you! The same thing happened with my
<a href="http://www.reviewprinters.net/hp-laserjet-pro-m1536dnf-review/">HP Laserjet Pro M1536DNF</a> printer, I used the same technique but it didnt work
Jul 23, 2008 | Televison & Video
Park ing Sensor System With Four Sensors Logo
21 people viewed this question
Top Park Home Security Experts
Lawrence Oravetz
Are you a Park Home Security Expert? Answer questions, earn points and help others
