Question about Toshiba Televison & Video
1/4 of the screen is cut off when the set is turned on
When the TV is first turned on, approximately a 1/4 of the picture is missing from the bottom of the screen. As it warms up, the picture starts creeping down to the bottom of the screen, but anything pictured on the screen looks as if they are midgets or there legs are very short.
Toshiba TV CF3264K
  • 89 Answers
You have a bad vertical IC or leaky capacitors in the vertical circuit.
The capacitors are usually red colored and are 1 uf at 50volt capacitors and are readily available at radio shack. If you have some skill with a soldering iron you can probably fix it.
Just make sure you unplug it before working on it and that you never work on it while it is plugged in
Posted on Mar 13, 2009
Tv picture is always on full screen can not change it to wide screen or small screen. so side of picture is cut off so miss half off people at either side of screen and logos too tv channels missing like 5...
Do you use a satellite dish or cable? There are 2 different ways to control picture size. One is through the TV itself but there is sometimes also a control through the dish. For DISH network it is format on the remote. You may want to check if that setting is set to zoom or a setting like that. If it is, the TV control of the picture won't change anything. Email me back with more details if this doesn't solve your problem.
Feb 20, 2011 | Televison & Video
How come the top and sometimes the bottom of my screen are cut off
Not all bradcast are in 16:9 resolution (wide screen). Most are still in 4:3 (old TV).
Sometime the advertisements are in 16:9 letterbox to project correctly on 4:3 TV and TV logo or titles are on the bottom or top of the picture. If TV is set to project wide screen, these logos or writings will be cut off.
If you have an option to switch TV resolution from remount, you will see whole picture.
Check your TV manual for settings.
Dec 20, 2010 | Panasonic TH-42PX20U/P 42 in. HDTV Plasma...
Part of the picture is being cut off, how do i
Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
Nov 27, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
HORIZONTAL LINE THROUGH PICTURE
Defective LCD panel. I hope it is under warranty, otherwise you'll have to live with it or buy a new set, as the LCD panel costs almost as much as the TV itself.
May 20, 2009 | Sharp Televison & Video
Screen size
YOU MUST GO INTO YOUR PS3 VIDEO SETTINGS MENU AND SET YOUR HDMI TO 1080P AND YOUR PICTURE SHOULD BE OK
Nov 02, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Picture is cut off at top and bottom
I had the same problem with my westinghouse 47 inch HDTV. It turned out that someone had inadvertently hit the "format" key on my satellite (Direct TV) TV remote controller. If you have satellite TV you might want to check this out. I set it back to the previous setting and I get the entire screen. Hope this helps someone.
Oct 20, 2008 | Vizio L32 32 in. LCD HDTV
The horizontal is out of adjustment
open ur tv and find the 100uf/35v and change it.
May 08, 2008 | Hitachi 43FDX01B TV
High def picture is cut off on the sides
I have a Toshiba 50HP15 PLasma flat screen TV. Its been working tone for 2 years now. All of a sudden without warningm the right 1/3 of tghe picture is missing and is black, where as the other 2/3rd of the picture is great picture and in HD. When I press DISPLAY on the remote control is says FULL 720p. When I press the Picture Size button on the remote the message NOT AVAILABLE come on. Anyone with suggestions. Thanks
scotto
Dec 27, 2007 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Televison & Video Logo
83 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
