Question about Milwaukee 6310 22 18 Volt 6 1/2 In. Circular Saw With Two Batteries, Charger And Case
Batery is dead place on charger light came on the off thanks
  • 1 more comment
  • sa13 Mar 13, 2009
    sawzall works batery dead, placed on charger light came on then off
  • sa13 Mar 13, 2009
    why does the light on charger
    comes on then off because the batery is bad and not the charger thanks
  • sa13 Mar 13, 2009
    don,t know i would have to
    buy a new batery to know
    Sergeant:
  • 320 Answers
The charger is proper the battery is bad in your unit.the charger gets power so the light comes on.but the battery is bad and totally faulty /drained so its not charging up.so the battery needs replacement.as this is common in this units.the battery gets drained and turns faulty.
Posted on Mar 13, 2009
  • 8,197 Answers
Sounds like bad battery replace the battery
  • 98 Answers
I would hook up a volt meter or at least a test light to the charger.Just to make sure it is good. then i would hook up the volt meter to the battery and see if it is charging.
  • 10,515 Answers
Change the battery.
That's the only solution.
thanks.
    Sergeant:
  • 254 Answers
Try with new battery or replacement battery and check out and confirm it first is it battery or the inner socket/.
  • 2,984 Answers
Your battery is bad....guaranteed. They do go bad...some batteries require a certain technique to continue the charging capability. Some require the battery to be COMPLETELY drained while others need to be charged before they become completely dead. Your battery is bad though.
  • Greg Bernett
    Greg Bernett Mar 13, 2009
    As I stated, your battery is bad.
    Sergeant:
    Champion:
  • 435 Answers
Hi, Could you please explain the problem in detail?
Is the saw working?
Red light flashing will not charge battery have left over night with no result
Sometimes, this is a result of a battery that is too cold (below freezing-warm it up). Sometimes it can be too hot (discharged under heavy stress-let it cool down). Sometimes there may be insufficient voltage, I have had problems in older houses, get closer to the electrical panel to plug in, or you may have to wait until you get home. Red flashing may mean https://www.youtube.com/watch?v=8rZqYmPsZycthe charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been dropped or hit the floor the coil inside could have broke loose and damaged the charger requiring it to be replaced. Below is an unconventional way to charge the battery if the charger is no good. BE CAREFUL
how to charge broken makita BL1830 Li ion battery
Mar 12, 2015 | Makita Cc300dz 10.8V Li-Ion Cordless Tile...
Mastercraft power tools parts
I assume this is a cordless device ? if so than the intelligent charging devices used to charge the battery's is sensing a defective battery pack, if the battery pack is completely dead then this is a fault, you can try to flash charge the battery pack with a power supply that has no intelligence device.
when you get a bit of a charge in the battery pack try to install it into the charger again.
this works most of the time and be car-full to only flash for several min or so and use a 12 volt light IE Brake light bulb from a car in series with the power supply to regulate current.
also make cretin that the polarity is correct plus to plus and minus to minus.
Good luck and best regards Falco Mueller
Oct 10, 2013 | Saws
Rechargeable ratchet won't charge
Sounds like your cell is dead and you need a new battery
Mar 15, 2012 | Saws
I have just brought a new dewalt dc390 cordless circular saw and it seems that the motor is running backwards?
It is possible that the motor is running backward but... first see the manual here:
http://www.plumbersurplus.com/pdf/08364.pdf Make sure the blade is installed as pictured in figure 4 page 11 of the manual.
After seeing the manual..... make sure the battery is charged correctly. The flat side of the battery should be toward the back of the charger when charging. If somehow the battery was inserted backward in the charger it is possible the battery was reverse charged during the intital charge. If you suspect this has happened.... insert the battery in the saw and run the saw until the battery is DEAD. Then insert it properly in the charger and leave it there for 9 hours so the charger will do the automatic tune up equalization of the battery.
If none of the above correct the problem, someone connected the internal battery power wiring incorrectly during FACTORY assembly. I would take it back to the retailer first... before processing a warranty claim.
You can contact DEWALT here:
call 1-800-4-DEWALT
(1-800-433-9258).
Thanks for choosing FixYa,
Kelly
Apr 30, 2011 | Dewalt DC390K 18v Cordless Circular Saw...
NOT CHARGING BATTERIES
ok you need to zap the battery, if you have a jump box or a battery charger that has at least a 20 amp or better charge selection, like a engine start feature.
the post of the cordless batter has a center post marked on the sides is a plus or minus sign.
the should also be some vertical slits in the plastic post on the corners, clamp the leads from the jump box or battery charger positive to positive , negative to negative. with the car battery charger you can probably slip one side of the battery clip in the plastic slot the other on the connection blade. plug in the battery charger and let it on for 5 or 6 minutes. if the battery charger has a auto shutoff the light will blink off and on but that is ok .
take the cables off and plug into the battery pack charger now you should get a red charge light and now can charge the battery.
if light does not come on try it in the drill or saw and see if you had any more charge than before if so you might need to repeat the procedure and leave it on the car battery charger a little longer
Jun 08, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
18volt ryobi battery charger doesnt work
try pitting battery in charge and wiggle the battery a little to see if the green light comes on, sometimes the make contact and then loose it when you let go of the battery.if still same problem charger is probbly dead.
May 17, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Looking for a 18v charger and batteries for my power tools;drill,saber saw,flashlight,rip saw
Never heard of this Brand but ebay or Craigs list is the place to look for this. If you cant find anything get a Roybi 18 vot charger and hook up external leads to connect to your batteries.
May 04, 2009 | Saws
Ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
Jan 30, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Milwaukee universal battery charger
check the voltage of the batteries before charging. Place on the charger and wait 1/2 hour or so, then recheck voltage. If it has not gone up, your charger is at fault.
Dec 18, 2008 | Milwaukee 6310 22 18 Volt 6 1/2 In....
Milwaukee 6310 22 18 Volt 6 1/2 In. Circular Saw With Two Batteries, Charger And Case Logo
101 people viewed this question
Top Milwaukee Saws Experts
Ron Sanders
Ron Sanders
Shade Tree All...
Shade Tree All...
Pieter Vleeshouwers
Are you a Milwaukee Saw Expert? Answer questions, earn points and help others
