Question about Tools & Hardware - Others
Senco airfree 25
Will not drive brad all the way into the board being nailed.
Loringh
  • 185 Answers
SOURCE: Tr250 does not drive brad nails all the way down.
Jason,
I think this is typical of these staplers/nailers. I bought a lighter model Stanley the first time and had this problem. I took it back and exchanged it for the heaviest Stanley they had at Home Depot and had the same effect. It drove the stapler a little deeper but not all the way.
I did find that if I put all the down pressure on the stapler right on the edge where the staple comes out and then pull the trigger it would drive the staple almost all the way in. I think that there is a recoil effect (like with a gun) when you pull the trigger and the staple enters the wood. Try this. it will help.
Hope this helps Good Luck Loringh PS Please leave a rating if appropriate Thanks for using FixYa
Posted on Nov 16, 2008
rowdy45176
  • 2176 Answers
SOURCE: Senco SN4 misfiring intermittently
This is a discontinued tool by Senco but there are still parts available for it. It sound to me that the o rings and possibly the firing valve need to be replaced. I would recommend going to Senco.com and you will find a complete parts diagram in their discontinued tool section. They also have a toll free number if needed and you can talk to their air pro. I have rebuilt quite a few of these and they are not that hard just make sure to clean all the parts and use lube when replacing O rings.
Posted on Jan 01, 2009
  • 152 Answers
SOURCE: just bought a senco pro 600 framer nailer what angle nail to use
My 600 uses 35 degree clipped head and is printed on the side of the magazine.
Posted on Mar 15, 2009
  • 23 Answers
SOURCE: senco 600 framing nailer / double hitting(nailing)
double nailing is usually caused when you apply to much pressure on gun causing it to fire on the recoil lighten up just tap it on the surface to be nailed
Posted on May 11, 2009
SOURCE: Senco nail gun was working one minute and then died...
gun nails frist nail then does not set next nail
Posted on Sep 02, 2009
My senco fusion 18 nailer won't set nails
is this a air nailer or something eles. if it is a nail by air adjust the air for more pressure
Jun 10, 2014 | Senco 6E0001N 18GA Fusion Brad Nailer
I have difficulty with regular jams regardless of brad length. Thoughts?
Depending on type of work/wood the finer the nail, results in increased jams. Eighteen gauge and finer experience more jams than say 15 gauge. Fine gauge nails also suffer from square cut tip. I believe that if the nails were pointed (like Senco nails ) they would more likely drive true. Jaming can be decreased by selecting the correct nailer for particular work. Dimentional lumber and hardwoods tend to increase problems compared to quality plywood or non wood trim materials. If you experience jaming with any type of wood then time to look at driver for possible problem. Check driver for bent or worn tip. Driver blade can be dressed square on grinder. Some drivers have a slight angle/taper ground into tip on the side that faces the rails. This taper continues up the blade about 1/2 inch. The taper will prevent the driver from hitting the second nail. On really hard woods, try drilling a fine pilot hole to produce best results. Good luck
Mar 09, 2011 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
My Senco SFN1 finish nailer will not shoot a nail. When the trigger is pulled air comes out but no nail is shot. Thanks,Steve L
Not sure about Senco but most have latch you can open to expose firing mechanism. Nail sometimes gets jammed and will not allow driver to fire or if not nail push driver ****** all the way back into gun then see if gun will fire.
Oct 25, 2010 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
Looking for a diagram or schematic for a senco fp18
I have a SENCO FinishPro18 that I inherited from my son when he died a year ago. It has worked fine till now. It does not shoot a nail when depressed against a board and I pull the trigger. I don't hear air leaking, but it seems there is little pressure. Having taken apart the head, then the base, it all seems in good shape. I have not taken apart the trigger assembly, as the removal is a total commitment. Thoughts? I could use some help.
Oct 24, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
I have a Senco Accuset nailer - #A125B None of the 1 1/4 nails from Lowe's will fit, they are all a little off. The box says they fit 'any' nailer. Am I doing something wrong?
try a contractor supply, or find a senco distributor in your area, there used to be one in my hometown of Hayward, Calif. Tey carried fasteners for all models.
Sep 22, 2010 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
Senco Finishpro18 just stopped shooting nails. Took it apart put it together. Shoots a couple of nails then stops. Press the nailer against the target pull the trigger and air comes out of the handle.
I just had the same problem with mine. Exact same symptoms. My guess is that your gun hasn't been used in a while.
I called Senco and they recommended removing the top cap, removing all o-rings (one at a time) gently stretch them, put a small amount of lithium grease in the o-ring track, and replace the o-rings. This fixed my problem and I hope it fixes yours!
Senco has awesome tech support for their tools. I will not buy another brand because of their support. 800-543-4506
May 15, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
Senco Finishpro18 just stopped shooting nails. Took it apart, put it together. Shoots a couple of nails, then stops. press the nailer against the target, pull the trigger, and air comes out of the handle.
Do you regularly use air-tool oil placed in the air connection? If it gets a good workout every day, buy an 'inline' oiler that is inserted into the air line which automatically takes care of oiling. Hope this helps!
Mar 28, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
Brad nailer not firing properly
need to rebuild. the kits are about $15
Jan 15, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
Shooting two nails instead of one
i would double check the plunger to make sure its resetting after each fire.
Oct 30, 2009 | Senco FP18 FinishPro 18 - Gauge Brad...
Tools & Hardware - Others Logo
63 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
