Question about Electrical Supplies
Arlec wiring diagram - Electrical Supplies
How do i set arlec pc 899 powerpoint time ??
Q1. How to set on / off times?
A1. Shift the red actuator pin to the desired on time
shift the black actuator pin to the desired off time.
Q2. What is the shortest time interval?
A2. 15 minutes.
Q3. Maximum switching times?
A3. One "on" and one "off" setting.
Q4. Can you override?
A4. Yes, use the override switch.
Note: If the main power is turned off the timer will need to be reset.
To set the timer to the current time you will need to turn the dial in a clockwise direction until the smaller arrow (Line) on the front face is pointing to the current time.
Regards,
Arlec Customer Service
+61 3 9982 5111
Dec 10, 2014 | Audio Players & Recorders
Diagrams schematic
arlec batterycharger diagramm for Bc2424 needet
thank you
Werner
Jan 09, 2014 | Amana PTH123B25AJ Heat Pump Air...
Arlec 24hr timer
What timer do you have?
Copy following link for possible manuals and sell sheet
http://waterheatertimer.org/Woods-timers-and-manuals.html#arlec
Gene
h
Sep 17, 2013 | Hardware & Accessories
Simple instructions on how to operate an arlec timer switch which is older style and manual. It plugs into a power point.
Timer is not identified. Read through possibles options below:
Add a comment with simple description of the timer for possible identification of product and possible instruction.
If you have analog dial timer, then open following link for instructions:
http://waterheatertimer.org/How-to-set-timers.html
Following link shows a variety of arlec timers: each timer has instruction manual that expert can access. Add a comment and say which of these timers is same-similar to your timer, and then say what part of manual is confusing.
http://www.arlec.com.au/productCatalogues.aspx?ParentCatalogueID=4&catalogueID=5&Page=1
If you already have instruction sheet for timer, then add a comment and describe timer, and include what part of manual is confusing.
If you want expert to speak with you about programming the timer, then request fixya phone assistance. Expert can ask which timer you have, and answer specific questions while you program timer.
Sep 08, 2011 | Hardware & Accessories
I need a maunal for an jackaroo outdoor pizza oven
simply email Arlec: custservice@arlec.com.au and they will help you and send you out a manual
Jan 05, 2010 | Ovens
Water stop dripping less cooling
Your aircon probably needs refrigerant recharge.
Jan 29, 2009 | Heating & Cooling
Electrical Supplies Logo
42 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
