Question about Universal Battery Universal Digital Battery Tester - Displays the Charge
Tester will not work
I have two - the first one didn't work, so they sent me another one and I still cannot get them to work.
Curtisint com
so,i didn`t see any wrong about that sent...if youd like to hide it,go to the message settings ang un click the sent messages report
Jan 29, 2014 | Televison & Video
I have an 03 acura tl my headlight on the passenger side went out I checked fuses and the fuse was fine spent 100 for a new bulb replaced it and still didn't work and then on the same side my high beam...
check relay under the hood. also get a wire tester and check the wiring to theh eadlight and see if u have any juice going to it. if not then that is where your problem starts of tracing electric issue.
Jul 14, 2013 | Cars & Trucks
Obd2 port not recognising diagnostic tester
First I suggest to check fuses; keep in mind that the OBD-II port didn't work because the power wire in the connector corroded and didn't have a connection anymore. No power equals no OBD worked.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 17, 2012 | Hummer H2 Cars & Trucks
1994 jaguar ignition coil...my car turns over but sometimes wont start. We put a tester on the fuel pump to see if that was it, but when it didn't start the pressure was at 44lbs so it was working
Hi Kenny, The fuel pressure is on the low side. I would also check the crank and cam pickup sensors. Another point of interest should be the temperature sender unit that sends to the computer. I would suspect the igniter before the ignition coil. regards John
Apr 23, 2012 | 1994 Jaguar XJ6
Alternator was accidently shorted out, got new alternator and didn't work, when it went out naturally just put a new one on. checked fuses inside and out but couldn't find one for the alternator....
There is a problem with the connections , ckeck the plug in connector , pull on wires at connector . Check with continuity tester , or ohm meter also check wire from altenator to battery ...
Jun 11, 2017 | 1991 Buick Park Avenue
I am having problem with my network. I am wondering why the new cabling I made I having problem connecting to my assisting network. I use belden cat5e and did not even exceed 30 meters lenght. pls help..
Ethernet cables can be 100 meters in length. I would imagine you didn't punch the cable correct.
Make sure you have the wires in the correct order if they are not it wont work. Just stick to making straight through cables as most routers, switches and hubs are now smart enough to reverse logic if needed.
Here is wiring of A to A http://networkcable-tester.com/2011/05/23/cat-5-wiring-5/ You can also buy ethernet tester to see which pins are not connected correctly.
If your having trouble making cables I'd suggest just buying some from www.monoprice.com they only cost about $4 for 18' cables
Jul 24, 2011 | Computers & Internet
Not getting power when plugged in.
Hi,you may as well checked socket connecting the source.Now try to diagnose the problem.Try to connect other appliances using the source where dishwashers initially connected.If it didn't work there is a problem with your socket.If it does work.You can check the continuity of the circuit of yuor dishwasher using an ELECTRICAL TESTER/MULTITESTER.Set it to OHMS then connect both ends of the tester .If reading moves.or tester pointer moves at least to the maximum value or at least 90% of it.It means it does work.no problem with the continuityI but If it moves more than its maximum amount short circuit happened within the circuit..Continuity will test if short circuit happend, if there is a continues connection within the circuit .It tests if IC's inside the circuit has not been short circuited due to overheating..hope this helps..
Jun 22, 2011 | Dishwashers
Universal Battery Universal Digital Battery Tester - Displays the Charge Logo
76 people viewed this question
Top Universal Battery Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Universal Battery Measuring Tool and Sensor Expert? Answer questions, earn points and help others
