Question about Sharp Aquos Televison & Video
Power driver ic - Aquos Sharp Televison & Video
    Top Expert:
  • Sharp Master
  • 74,377 Answers
It will be best to replace the power supply regulator board as card basis rather than get it repaired. In most cases, repair will be not successful to FTV power supplies.
Posted on Apr 24, 2013
Tip
Playstation2 SCPH 3000 - 5006 General Problems
No Power (Totally Death).
  1. Check the output regulator 12volt DC Power Supply.
  2. Check the Fuse (Voltage Security Fuse).
  3. Check the Flexible cable on switch board (reset & eject button).
  4. Check the Output Diode.
Lens Problems (Optic)
  • Optical Spull not move (up down).
  1. Check the flexible cable.
  2. Check the Optical spull.
  3. If you have SCPH - 3000 series, check the IC Driver (BA 5815).
  4. If you have SCPH - 5000 series, check the IC Driver (LA 6508).
  5. Check the optical flexible cable socket.
  • Optics spool laterally tilted or irregular jump when the engine turn on.
  1. Check the resistor on 102 block (In IC Servo Master Control area = CXD 3098 : 470-8pin,102-8pin).
  2. Check the resistor under IC Servo Master Control.
  • Optics can only read one CD/DVD format.
  1. Check the Optic Laser Diode.
  2. Check the Optic Laser Diode with Voltmeter : V3 (CD=1080 to 1260, & DVD=800 to 1300), V4 (CD=850 to 900, & DVD=1200 to 1400), V5 (CD=1200, & DVD=1400), V7 (CD=1200, & DVD=1100 to 1400), V9 (CD=1200 to 1400, & DVD=1200 to 1400).
  • Optics Lights not lit (Lens not light).
  2. Check the optics spull.
  3. Check the SP 3727 IC.
  4. Check the Amp transistor ( in IC SP 3727 socket board), Upper for CD & under for DVD.
  5. Check the IC 7805 (IC Regulator).
  • Excellent optics but won't to read.
  1. Check the mecanic gear.
  2. If you have SCPH - 3000 series, check the IC Driver (BA 5815).
  3. If you have SCPH - 5000 series, check the IC Driver (LA 6508).
  4. Check the ModChip.
  5. Check the IC SP 3727.
  6. Check the resistor (in 220 block), between IC Servo Master Control & IC Interface (CXD 9611 BR).
  7. Check the transistor (in socket optics= pin 6).
on Sep 16, 2010 | Sony PlayStation 2 (PS2) Console
One line across only...
This is failure of the VERTICAL DRIVER IC/circuit in the monitor . So what is need is to check the voltage on the vertical IC to confirm if there is a power break from the output transformer. normally there is a fusible resisitor that feeds the verticial IC and could fail if the IC or the coils fail.
Check you PC using another monitor to confirm before this is taken apart to check.
Aug 09, 2011 | Computers & Internet
In chennai free kalaignar tv sound not coming i changed sound ic an 17823a still sound not coming ples sen me the detail of this sub!!
you replaced the power amp ic before that you need investigate the condition of power ic and it's very simple when you terned on the tv set you can hear the small pop noice from the tv speaker means the power ic is good other way is just tuch the screw driver to sound if output stage you can hear the DERRR sound from the speaker
if it ok pls check the mute transistor
Aug 27, 2010 | Televison & Video
The 6306 L showing HAMMER VOLTAGE 1 ERROR WHAT SHOULD I DO
ERROR IS BECAUSE OF DRIVER IC FAULTY IN LOGIC CARD
PLZ CHANGE THE HAMMER DRIVER IC IN LOGIC CARD
Dec 13, 2009 | Tally 6306 Matrix Printer
IC POWER LAPTOP CN5560 Driver
Here is a link to download a driver for your Laptop.
Open this link:
www.yboyandrei.com/CN5560
For windows XP 32 Bit Edition, download direct:
http://www.cpuid.com/download/cpuz/cpuz_152.zip
Please rate me.
Sep 04, 2009 | AMD IC Power CN5560 Notebook
ABOUT PHILIPS TELEVISION
The 8V at pin 36 won't show unless there is oscillation, the primary voltage pin is pin 10, 8v. Don't mind me asking, you have checked the B+, right? Because the blinking LED is often because of power supply problems. And if that's okay, desolder the horizontal driver output legs and connect an LED to find if it is oscillating, if it does, forget the ic part and move on with the FBT and things. Good luck.
Jan 31, 2008 | Televison & Video
Sony TA-F210 amplifier no sound
bring data sheet of this ic from the net-check supply voltage(vcc or vdd)-check ground.apply audio signal and test if it is present in input pins after that check your signal in output pins.have a visual inspection around the ic for burnt resistors or bad capacitor. if every thing is fine replace the IC.
Oct 05, 2007 | Audio Players & Recorders
Televison & Video Logo
26 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
