Whirlpool dishwasher adp6000wh
Error 1
    Brigadier General:
  • 3,400 Answers
Posted on Apr 24, 2013
Model ADP6000WH/ADP6000IX. What is error 2?
if this is a model that flashes the clean light in blinking code for faults , then your not properly reading the flashing light , if it repeats the two - two flash rate this is an indication that its lost its communication between its internal circuit boards (most times this is a logic board problem ) but it can be the other ones as well or ive even seen a wet cable do this as well , if the flash rate is 1 flash - two flash this is an indication that there is stuck key on the keyboard (or a cable problem too )
but the Number one problem I see with dishwashers is there's water(or had been) where it should not be !! water in the wrong spot causes all sort of gremlins to show up and it doesn't take much just one drop and its chaos
Apr 13, 2016 | Whirlpool Dishwashers
Our whirlpool dishwasher make ADP6000WH/ADP6000IX runs for the first few minutes of each cycle the just kind of pauses and will not finish the cycle
Check your FLOAT... When it stops, Open the Door and see the Water LEVEL.
If the Water LEVEL is normal, then you have a problem with your Circuit Board
Apr 09, 2013 | Dishwashers
Error code 3 on my whirlpool ADP6000WH
F3 error fault code
The heating cycle is not working. The error is indicated after several electronic checks are done over a 25 minute period. Therefore if the heater heats too slowly or the heater is open circuit or indeed the electronic control PCB is defective, each of these will indicate F3. The twist is, if the NTC is fluctuating in its reading it also can indicate F3 and not F1. This is from the service manual for whirlpools dishwashers matching the model number your provided if you have any further questions message me back in order to test if the heating element is good or not you would need to perform a continuity test on the heater element with a multimeter. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks again Rick
Jul 18, 2011 | Dishwashers
ADP6000WH/ADP6000IX--Whirlpool Dishwasher.(new) My problem--Water not getting hot--i have it connected to the cold water--should it heat the water ?
9d561c5b-7c7e-4515-8a01-fbfa8f762c34.jpgerror 3 not heating..on wix6000 /or / ADP6000WH
same boards .
rip out the the main mother board with all the black boxes ,and the transformer on it,,there is 1 black box its the biggest of them all ,next to the fuse with the blue cover on it ,with care take the black cover off with a screw driver carefully, not to damage the lower half of the internals,the lower section must not be damaged all ,once the cover is off you will see a copper coil on one side and on the other a set of breaker points ,at the end of the points ,get a screw driver and push in the outter point inward just a fraction,and bingo it will work again,of coarse its a temp solution,you will need to get a new breaker box from tandy or dick smith or simlar place to keep it going long term ..
hope this helps guys and gals ,please take extream caution when working on such dangerous power sourses ,and always make sure the power cord is removed before and repairs or tweeks..
cheers
Sep 30, 2010 | Whirlpool Dishwashers
Whirlpool ADP6000WH This dishwasher does not clean and leaves soap in dispenser. Tried other products but same result leaves most of the soap in dispenser. What could be the problem, machine is 8 months...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher is coming up with a error 4. my dishwasher is a whirlpool ADP6000WH/ADP6000IX please help
I just had the same thing, same model. After cleaning the filter out, the problem remained. I then read on another forum that it helps if you tilt the machine backwards for a few minutes (which involved pulling it out of the cavity in the kitchen). Did this and it now seems to be working. Hope this helps you.
Aug 05, 2010 | Whirlpool Dishwashers
Hi, I have a Westinghouse ADP6000WH dishwasher and...
You have to check the slider rails. If you watch the there be a different slot. You can remove and place it in that area.
Otherwise remove the top rack and run as special cycle for this dishes alone!!!
May 21, 2010 | Dishwashers
Whirlpool ADP6000WH Fault Code err 2
Hi, i have had my new dishwasher for less than 3 hours and is doing the same thing. Not happy Jan!!!! I have dishes everywhere, stuff out of the sink cupboard and a open house in 2 days. Watch out retravision in the morning!!!!!!! Did you get a solution to yours??
Jan 01, 2010 | Whirlpool 24 in. DU920PW Built-In...
What does it mean whirlpool adp6000wh err 4 message code
Error 4 means" too much inlet water", turn inlet water tap down.
Aug 25, 2009 | Whirlpool Dishwashers
Whirlpool dishwasher ADP6000WH Error 3
Hi there i have found out that error 4 mean's two many soap suds and ths washer thinks there's two much water. Try less soap and clean the filters.
Jan 15, 2009 | Dishwashers
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
