Question about Ovens
Whirlpool wall oven makes a spring rattle noise when cooling down
MY WHIRLPOOL WALL OVEN IS DIGITAL AND WHEN THE OVEN HEATS THERE IS NO SOUND BUT WHEN IT STARTS TO COOL THERE IS A SOUND LIKE A SPRING RATTLING TILL IT COOLS.
5 Suggested Answers
  • 4 Answers
SOURCE: installing a whirlpool wall oven
You could call whirlpool and they can email you the instructions. Or your can go on whirlpool.com and enter your model number under the upper customer support tab.
Posted on Nov 21, 2007
SOURCE: How do get access to the door hinge of my Maytag CWE4800ACB oven
In first, excuse my poor english if i make some mistake.
I hare repair the same problem. part broken in left side and the door fall.
You have to pull out the oven from the wall, use some objet to support the oven,small table or plastic box if you dont want to put down completely.
You have to unsecure the electric wire connection in back if you whant to pull out enough for remove the left cover. You have to remove some parts in front for acces to screws on the side cabinet.
In my case the hinge was broken, i have soldered and fix again.
If hard to replace the spring in the mecanism, you better to do this on the bench before put all in the side of the oven.
I think the maytag oven have the same problem.
Other problem also is the timer alarm sound in the night went you sleeping, prob whit switch sensitif pc board. Now i turn off the breaker in the back of oven all night, and i sleep good.
Bye..
Posted on Jun 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: E2- F3 Error code, what does that mean??
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!^!^!
Posted on Sep 29, 2010
SOURCE: I need instructions on how
how do i get the griller to work
Posted on Jul 02, 2011
I have a wall oven that is 15 years old and it's making a loud noise, after it's turned off. This has never happened before.
Don't burn your house down! Get a new wall oven. FYI Sears no longer sells Whirlpool.
Nov 10, 2017 | Whirlpool Ovens
Whirlpool cooling fan will not turn off ovens
There is a thermostat usually on the top or back of the oven which controls the cooling fan. When it cools down, the fan is supposed to turn off. I would say this thermostat has failed. Locate the thermostat and if its cool, the thermostat should be open circuit. If not, you will need a new one. Most spare parts centres should carry these. A generic or common oven cooling fan thermos will suffice if you cant get the genuine one. make sure the oven is off at the wall or the fuse box before you go into it.
Nov 19, 2016 | Whirlpool Ovens
I have a whirlpool accubake wall unit oven Took out door to clean glass now I cannot put door back together
you have a couple of hinges you have to pull out at about 45 degrees then slide door down on them and shut door
May 05, 2016 | Whirlpool RBD245PRB 24-inch Double Wall...
Can I disconnect the cooling fan as it has become very loud. Whirlpool TrueTemp wall mount oven
Hi, it sounds like you need the fan bearing renewed or the fan unit. If you disconnect you will have to revert to just having an ordinary oven and adjust the temperature for cooking food accordingly for a oven without a fan.
Mar 09, 2016 | Whirlpool Ovens
Vibration/rattle and digital lights flickering
could be the fan,i've seen dust get in there and there's a screen that the fan blows air through to cool down the electronics,so if the fan is bad it's not cooling down your board and that's why the light flicker,how old is the unit,sounds like the board is damaged from over heating most likely from the fan and i looked up the model number and you can't get that board anymore,if the board is bad you could get it rebuilt,i just helped someone else with the same problem the board is discontinued,you have to have the board taken out,draw up a wire diagram and send the board out to have it rebuilt,when they send it back you reinstall it,and wire it.
https://www.appliancetimers.com/appliance?model=gbd307pdt7
maybe if the fan motor gets changed out the board won't over heat anymore and won't give you a problem but it doesn't sound good.i think the board will also be an issue
Nov 21, 2017 | Whirlpool GMC275PD Electric Double Oven
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
Whirlpool built-in double oven model# RBD305PDB12
the humming sound is coming from the "squirrel cage" fan in the back of the unit, there may be some resonance vibration from the fan this issue should be addressed by a qualified service tech, the whole wall oven needs to be pulled out, i would have him check the fan.
Aug 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool wall oven model rbs245pdq12
Adjusting circuit board settings for oven size.
Apr 27, 2009 | Whirlpool RBS275PD Electric Single Oven
Whirlpool oven
There is a fan in the oven, it is behind a panel at the rear.It will be a loose fan or worn bearings, or fan catching grill
Nov 09, 2008 | Whirlpool RBS275PD Electric Single Oven
Installing a whirlpool wall oven
Oct 23, 2007 | Whirlpool RBS305PDS Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
