Akira air conditioner
F2
My akira split unit, indoor & outdoor light keep flashing, when it is turn on but outdoor unit does not running. please don't tell me to seek the spcecialise.
The relay for the outside unit is not working. The thermostat activates bot inside and outside relays, so the outside relay is bad.
Apr 26, 2016 | Heating & Cooling
F2 on display in AC unit
could be the room sensor or pipe sensor got jacked out from the board. check if any loose connections exists.
Aug 13, 2014 | Comfort-Aire Heating & Cooling
Why won't my air conditioner change fan speeds
Having same problem...ac unit seems not to be changing fan speed and cooling level has been reduced ????
I have no solution. but we have just run into the 7 day of 95+ degrees with high humidity. do not believe the units have frozen up, just seems that the fan is in low speed mode and trying to raise it to F2 or F3 doesn't seem to help.??? Most of the time we have to increase temperature because its too cold ?? now it doesnt seem to be cooling the same ??? I await anyones solution.
Aug 06, 2012 | Kenmore 75121 Thru-Wall/Window Air...
Universal remote code for akira tv
i want the code for Akira Air conditioner
Jan 07, 2012 | RCA Universal Remote Control
Unit will heat only will not cool and how to repair
we have a split type gree aircon, with one (1) horsepower. it was just newly installed, around 6 months ago. we are just surprised that one when my wife turned it on, thru the use of its remote control, the indicator box on the aircon reads or flashes "F2". I detached the batteries of the remote control for severa hours and I also detached the power cord from the wall socket, but it was to no avail. it did not work. with "F2" on the indicator box, the aircon won't give cool air, it is just working like an ordinary fan. please help us.
May 17, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
The AC unit turns on and I can cycle through the options in order to adjust the fan speed however the fan does not start in any of the three settings. The ac unit produces cold air, however the fan does...
You say the unit produces cold air ??? where are you getting the cold air from???
If your fan does not run in any speed F1, F2 F3. and a funny smell sounds like the motor is bad
Mine works in F2, F3 but not in F1
Apr 12, 2011 | Kenmore 75085 Air Conditioner
My LG 7000 BTU Heat / Cool Window Air Conditioner does not cool and the fan speed F1 will not work. Fan runs on F2. The heat works fine. Any suggestions?
You have a control board issue. You can get a new control board by Google searching the make and the model of the unit. There are several sites that sell them
May 24, 2010 | LG Heat cool Window Air Conditioner
Buttons
F1, F2, and F3 are the strength of the fan blowing the air conditioner. F1 circulates the least amount of air, F3 the most. I generally find that if the air conditioner isn't getting the job done on F1, F2 will do it. I typically only use F3 if I just want to circulate air fast in my place for awhile. As far as what is "better" with closed vent or open, that depends on what you want to do. If you are using air conditioning on a hot day, then vent closed is better because it will cool only air circulating in your place. Vent open will allow fresh air in from outside, and if it's a really hot day, the air conditioner might have a harder time cooling off the fresh air than the circulating air inside your place (as it's continually being cooled repeatedly by your air conditioner).
Jun 10, 2008 | Goldstar M1003R Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
