Question about Gateway Solo 5300 Notebook
Solo 5300 system restoration question
I have an old solo 5300 laptop from college. I'm trying to restore to original settings, however, when I insert System Restoration Kit Disc 2 (version 98 rev. 1.2) and reboot, select Install Windows, says it's Preparing my computer for install of windows >follow prompts for installation wizard then screen goes black (but power still on)...and doesn't come back on. I'm a bit computer illiterate - any assistance you could provide would be greatly appreciated! (And the tech people @ Gateway say they won't help b/c I'm out of warranty.) Thanks!
  • 5 more comments
  • jrolfsen5 Mar 13, 2009
    It currently has XP on it so I would have to reinstall that too. I'm trying to start with a clean slate - the computer has a bunch on stuff from college on it that I don't need / want. I don't know if there's a problem with that 2nd System Restoration Kit Cd or if it's the computer
    and now the computer's saying that it can't find the network adapter
    (it's shows the wireless but is unable to connect and can't even locate
    the LAN) so I can't get online using that computer... good grief!
  • jrolfsen5 Mar 15, 2009
    i did try to re-install the driver of wireless & configure but no luck - can't get it to connect using ethernet cable either
  • jrolfsen5 Jul 18, 2009
    can't figure out how to install driver of wireless or LAN onto other laptop ???
    Using Windows XP on that laptop (Gateway) and on this laptop (functioning one) as well. Thanks!
  • christian Abong May 11, 2010
    did you try install the driver of your wireless and configure it?
    what windows you use now? pls. give more info about your issue
Just unwrapped my bose solo 15 and the universal remote worked up until I tried to set up the tv.. Now it does nothing, can't even turn on the Solo 15. I removed the batteries for about 30minutes, also I...
Try removing batteries from the remote, pressing all buttons to unstick a stuck buttton, reinstalling batteries, and testing operation. Also, something may have gone wrong when you were setting the remote to control your TV. If no corrective action works, the remote may have failed prematurely.
Dec 16, 2014 | Bose Solo 15 TV sound platform
Can swappable drives CD and Floppy be used in external cases?
Not sure, but if you can download and copy Ubuntu on CD. It might run off disc with no install.
Aug 29, 2012 | Gateway Solo 5300 Notebook
I have an older gateway solo 5300 laptop. I turn it on and it says missing hal.dll file. I tried to boot from cd but wont. I cant seem to get to any place where I can do system restore or anything. I am...
hey
see to restore ur system would be quiet tough for u unless u dont knw abt al files thre is only oneway which u can do just take out ur hard disk from laptop and connect it to other system as the removeable device then open ur hard disk and restore ur all files from thre which is imp to u
then put back to ur laptop and format ur system and install the new windows
let me know if still ur problem not resolved
Jun 10, 2011 | Gateway Solo 5300 Notebook
Wireless switch on model solo 5300
Hi. Not enough information. Do you want a switch? Do you need to FIND a switch? Is it a Gateway notebook?
The specifications for the Gateway Solo 5300 do not indicate a wireless system as part of the original unit.
See:
http://support.gateway.com/s/manlib/Notebooks/Solo5300/8508144/8508144.htm
Most units with PC100 memory (like this one) did not come with wireless. You will likely need a wireless PCMCIA card.
Mar 21, 2010 | Gateway Solo 5300 Notebook
Don't remember password on bios of a gateway solo
Simplest is to remove the battery for a while so the password is lost.
See the TechRepublic article at
http://articles.techrepublic.com.com/5100-10878_11-1032878.html
Nov 19, 2009 | Gateway Solo 5300 Notebook
Cant restore factory settings
Format the hard-drive and do a reinstall
Oct 25, 2009 | Gateway Solo 5300 Notebook
Gateway 5300 solo fan control and heat monitering
I believe gateway locks their heat limits. But in order to change it you should be able to inside of the BIOS/CMOS/SETUP when first starting the machine.
May 27, 2009 | Gateway Solo 5300 Notebook
WHY CAN I NOT OPEN MY INTERNET PAGE
i think u delete some windows files or u install some other version of internet explorer and u remove it after that thets why it created a problem ..NO problem if u know how to restore a window then restore it else just goto to star menu and click on explorer i am sure it will open but after restoring window...
Jan 16, 2009 | Gateway Solo 5300 Notebook
PLEASE HELP GATEWAY SOLO 5300. CAN'T OPEN INTERNET EXPLORER
Hi, I can help you with this. Do you have a wireless router? Do you have DSL or cable modem? If you would like to chat online about it, I can walk you through a few things to try. There isn't enough information here in your problem description to solve it without talking to you in some way. I could also do a phone call if you don't have two machines at home. Let me know if you would like to do that. Thank you.
Computers & Internet Logo
230 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
