Question about American Pro VS-1466 Car Equalizer
Ok....well i dont exactly know why my equalizer isnt turning on......
Basically i attached the red (12v in) to the same power as my car stereo so i didnt have to make another hole in the firewall of my truck, and i put the black (ground as everybody knows) to a ground in my truck that was already there. and the light for the power dosnt come on when the stereo comes on...which is in the accesory position with the ignition switch....i dont exactly know where to put the orange (it says remote) which i know what a remote wire does...which is turn it on remotely when everything else turns on....because i have no remote wire in my truck that i have found......if anyone knows where i can find the manual for this thing or knows what im doing wrong please by all means contact me. my email is crandlemirej@aol.com...i need an answer really bad cuz my whole stereo is in pieces right now and im driving around in it w/o music. also if it helps my truck is a 1988 f150 xlt lariat. thanks
If you have an amp in your truck,try and use the same remote wire that runs from your head unit to the amp.
Posted on Aug 15, 2007
Why won't my JVC KD-HDR car stereo turn on?
Has it ever worked before? If not,this could be a basic install issue. To bench test, combine red and yellow and run to 12V positive and Black to 12V negative to see if it powers up.
Jul 30, 2014 | JVC KD-HDR50 Car CD/ MP3 Player
I replaced my ignition switch in my 98 k2 jetta and after my stereo won't turn on but will eject cds and insert them?
The red wire from the stereo is 12v signal, basically when you turn the key on it send 12v to the red wire to make your stereo come on. Everything else is fine since you can insert and eject cds. You may have pulled the signal wire loose when you changed the ignition switch, check the wires behind the radio and the wires to the ignition switch.
Dec 11, 2013 | Bosch 1998 Volkswagen Jetta K2 2.0L...
I provided 12v from car the security red light blinks, but when I attach face plate the stereo is dead?
do you have power going to both the yellow and red wires????????
yellow is constant power and red is switched power (ignition).
May 31, 2010 | Audiovox ACD-22 CD Player
Got power to cd but no display
One idea that comes to mind is,if I remmeber correctly, that model has a removeable faceplate, try this, remove the faceplate,take some denatured alcohol on a Q-tip,clean the electric contacts on the back of the faceplate and also on the front of the deck where they mate together repeatedly for about 4 to 6 times letting them dry between each time that you swab them clean, then replace the faceplate onto the deck being sure that you are seatting the faceplate completely and properly.
This has worked for me sometimes and sometimes not, its worth a try.
Good Luck !
May 02, 2010 | Sony XPLOD CDX-GT200 CD Player
I have a fairly old panasonic car stereo/cd changer. i just need the wiring diagram for it. what color equals what? i typed in the model number but nothing turns up. . . i had to replace the old system,...
Here is the Colors of the Cars factory harness
Constant 12V+ Red Switched 12V+ Red/White Ground Black Illumination n/a Dimmer Orange/White Antenna Trigger Yellow Antenna Right Front Front Speakers 3 1/2" Dash Left Front (+) Green Left Front (-) Green/Yellow Right Front (+) Purple Right Front (-) Purple/Yellow Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Brown/Yellow Right Rear (+) Blue/Red Right Rear (-) Blue/White
And Here is the Chart for the radios wiring
Red 12V+ Switched power
Grey Right front speaker +
Grey with black stripe right front-
White left front +
white with black stripe l/f -
Purple R/R +
Purple with black stripe R/R -
Green l/r +
green with stripe l/r -
Black ground
orange illumination
yellow constant power
Apr 07, 2010 | Car Audio & Video
My pioneer deq-9200 equilizer keeps resetting to default settings whenever i start my engine. What's going on here?
The EQ has two power wires on the back like a head unit. One is constant power, and the other one is ignition/switched power. This normally happens when the installer takes the switched power and applies it to both power leads going into the EQ or head unit. The EQ needs the constant power line run to a 12V source that never turns off. The constant power line is normally yellow, and the switched power line is normally red.
May 19, 2009 | Pioneer DEQ-9200 3-Band Car Equalizer
I dont know which wire in the memory to connect it to my after ma
The memory wire is usually the yellow wire in the harness - it goes to a constant 12v (battery) source. That's how the cd player remembers all of your presets. The red wire (the other power wire) is connected to a switched 12v source, so it only sees power when the key is on. That is why the cd player shuts off when you turn the key off.
Mar 27, 2009 | Pioneer DEH-1600 CD Player
Fitting a new car stereo to the old wiring
hmm, this is an old post, do u still need help??
If u do lemme know and i'll give u a few tricks u can use.
Sep 28, 2008 | 1993 Volkswagen Fox
Connect 5 piece Sony seperates stereo system
OK, this is pretty easy to do. First connect your leads from the component outputs(i.e., tape, cd, phono, etc) to the recievers corresponding input for the device. Then connect the recievers outputs to your equalizer, if it is a seperate eq. Then the outputs of that to your amplifier, then your speakers to that. Be sure all of your wires are connected with the proper polarity. These instructions may be a little different for your exact setup but basically follow the same order minus any device you dont have.
Feb 03, 2008 | Audio Players & Recorders
How do i wire an equalizer without any wiring diagrams
1. bottom right( red wire 12 v dc on/off ignition switch)
2. top right( blue wire with inline fuse to amplifires)
3. bottom left( black wire ground)
4. top left( blue wire stereo remote wire)
I have a pdf photo diagram I made just e-mail me and ill send it to ya. hope this helps
Nov 15, 2007 | Car Audio & Video
American Pro VS-1466 Car Equalizer Logo
135 people viewed this question
Top American Pro Car Audio & Video Experts
xxxxxx xxx
Are you an American Pro Car Audio and Video Expert? Answer questions, earn points and help others
