Health & Beauty Logo
Posted on Mar 13, 2009
My taylor digital scale is out of calibration. how
My taylor digital body fat monitor is out of calibration. how do I reset? I have changed the battery and it is till out of whack. There is no model number listed anywhere on it.
5 Related Answers
Anonymous
  • 2712 Answers
  • Posted on Aug 27, 2008
SOURCE: digital scale question
Digital scales purport to measure your body fat through a process called BIA, or bioelectrical impedance analysis. Essentially, it clocks the speed that electricity travels through you. The scale runs a low-level electric current through your body, using your feet as positive and negative electrodes. The current encounters different levels of impedance, or resistance, from fat versus muscle. The scale measures this impedance, and throws it together with other factors (age, sex, height) to come up with your BMI, or body mass index.
Anonymous
  • Posted on Jul 29, 2009
SOURCE: Taylor 5599 Tempered Glass Body Fat-Body Water
when I weight it appears error4 what does it mean?
Anonymous
  • 39 Answers
  • Posted on Jan 21, 2010
SOURCE: I need a replacement manual for my Taylor Body Fat
If you go to the taylor websupport site you should find one there, check the model numer though as I dont see a 5552 there. Once you select the product and go to the product page, you will see a link to the manual for the scale on that page.
http://www.taylorusa.com/catalogsearch/term/popular
Anonymous
  • 39 Answers
SOURCE: how do i program the taylor body fat scale
From the Taylor web site
http://www.taylorusa.com/faq-scales
The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
Testimonial: "The website does not have a manual. Using 'search' or site map produces nothing. Another problem: scale reads only in cm and kg. Won't cycle to ft/lb."
Anonymous
  • 12 Answers
  • Posted on Jan 29, 2011
SOURCE: I'm trying to find the
I just pulled my manual, as I recently started a slow carb diet and needed all my measurements. It was fun trying to find it. After finding nothing online (before my search), decided to post mine for everyone out there. It can be found under my photobucket album. Here is the link:
http://s1125.photobucket.com/albums/l587/landofnarnia/Taylor%205568%20Scale/
Amy
What does Err3 mean on taylor body fat scale?
Remove your shoes and socks and wet your feet slightly with a damp cloth if you receive the "ERR3" error. ERR3 is a contact error and your feet should ideally be bare and wet to achieve an accurate body-fat reading.
  • Step off the scale and wait for it reset. Remove your shoes and socks and wet your feet slightly if you receive either the "ERR4" or "ERR5" errors, which means your body-fat or body measurements are out of range.
  • Reset the scale if it doesn't work or you continue to receive error messages. Remove the battery and set the scale on a flat surface. Stand still on the scale for five seconds and step off. Re-install the battery and place the scale back on the flat surface. Place one foot on the scale until it displays zeros or dashes. Remove your foot and wait for the scale to turn off. Step back on the scale to weigh yourself
  • 0helpful
    How do you calibrate, it's a body fat scale, can't find model #?
    It's important to find the model number to be able to find the correct manual. Below is a link to FAQ's about Taylor body fat scales.
    If you do a google search for "taylor body fat scale" you will see a list of a few models. Examine each to see if one of them is the same as yours.
    Taylor USA FAQs Scales
    Searches related to Taylor body fat scale model number location
    taylor body fat scale model 5741 manual
    taylor body fat scale model 5761bf
    taylor body fat scale model 5731f reviews
    taylor body fat scale accuracy
    taylor body fat scale 5731 review
    taylor body fat scale athlete mode
    taylor body fat scale readings
    taylor body fat scale5758f manual
    TEC 21 SL calibration
    I have a tech sl 21 on the start up the number displays just keep flashing and it wont stop help please
    2answers
    Where do I get a manual ?
    you can purchase a manual of Taylor 5599 440 Pound Tempered Glass Body Fat-Body Water Scale on ebay or in amazon...http://www0.dealtime.com/taylor-glass-body-fat-scale-manual/products
    2helpful
    Need user manual for TAYLOR 55684102 scales.
    Here is my link, uploaded it to my photobucket album.
    Amy
    15helpful
    2answers
    How to calibrate a taylor scale 5571
    The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight,to calibrate, or some other unusual error.
    1. Remove the battery from the scale.
    2. Sit the scale on a hard surface floor.
    3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
    4. Re-install your battery.
    5. Place the scale back on a hard surface floor.
    6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
    7. Wait for the scale to turn off again.
    8. Step up onto the scale for a weight.
    If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department.You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
    3helpful
    Calibration is off
    My Weight Watchers digital scales model#ww39 has gone haywire. I put new batteries in it to no avail. You tap it and the numbers come right up then changes to 000.0 as it should, when you step on the scales the numbers flash as they should but either they weight you about 100lbs to heavy or the numbers continue to blink and the LCD goes blank. Can they be fixed? Can I fix them myself at home? Do I need to shoot them? Just throw them out in the yard? Please I need help!!
    Top Health & Beauty Experts
    Rob Hill
    Rob Hill
    ADMIN Andrew
    ADMIN Andrew
    ADMIN Eric
    ADMIN Eric
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
