Question about Apple MacBook Pro MB991LL/A 13.3-Inch Laptop Notebook
Macbook PRo Taking 20 mins to boot up and also after booting up,Its very sluggish and impossible to work on as after one click it takes 7-8 sec or more to respond.I checked hard drive was ok.Please suggest what to do ?
    President:
  • 485 Answers
At times, the boot-up is slow and the computer is slow/sluggish because the disk is not "clean" or there's a shortage of storage space remaining. If you have already tried using the Disk Utilities and/or other tools (e.g. Onyx) to fix/clean up the disk, and it still doesn't make any difference, and you still have a good amount of disk space remaining, and all your memory (RAM) is still working, there may be something else going on ... e.g. another process taking place behind the scene (e.g. downloads/uploads) and using lots of resources.
Posted on Oct 27, 2013
craigjamesbt
  • 65 Answers
SOURCE: APPLE MACBOOK WOULD BOOT. THE BOOT CD IS
unfortunately on the newer mac computer including the macbook you cannot boot to open firmware but there are other options
option 1)simply try holding down the mouse button or track pad button during boot after the first chime is sounded this will instruct the computer to eject the cd through the firmware
option 2) you can bypass the cd boot by holding down the option key after the first boot chime another simple solution this will allow you to choose a startup disk during...startup after which you can try the eject button on the keyboard or select the disk in finder and eject via trash can or eject symbol(symbol located in the open folder view of finder)
option 3) there is also a manual eject button though it may be harder to locate as they have change placements of it over the years however it can usually be found by probing the top center or far right of the cd slot with a paper clip just be gentle you don't want to damage an expensive piece of equipment by just carelessly jamming metal in it
you may want to try searching apple with your particular model and search for manual cd eject
best wishes, Crash
Posted on Apr 26, 2009
plettdoctor
  • 121 Answers
SOURCE: My Macbook Pro wont boot - stays on the blue screen
The fact that the "BONG" sound (or better known as the MAC CHIME) does come on and nothing further means that the computer cannot find your hard drive or (sometimes worse) cannot find the operating system. This means that you will have to remove the hard drive... then insert it nice and firmly again. Try now to boot. If nothing happens then your drive has gone faulty and it could mean that you may have lost your data... NOT NECESSARILY though.... What I mean by that is that you may still be able to access the dat when you connect the "faulty" drive to another computer via USB with an external casing and then get your DATA off it.
Posted on Jul 06, 2009
SOURCE: Macbook pro screen boots to black.
Try pulling the battery out then holding the power button for 10 seconds. Put the battery back in.
If not search macbook pro recall apple has extended the warranty on some models due to a bad graphics card.
Posted on Feb 03, 2010
djlaplaya
  • 74 Answers
SOURCE: When I booted my Macbook Pro today, I could hear
yes this happens. you can try doing this: power down then power up whilst holding down command, option P and R all at the same time. press these after you hear the chime. hold until you hear the chime a second time.
Posted on May 06, 2010
  • 13 Answers
SOURCE: white screen of death on Macbook 13". when turning
You may need to reset the PRAM.
Start your computer and hold down the option, command (apple), P and R keys simultaneously until you hear the second chime. Then release.
This will reset the perimeter RAM (PRAM) and may allow your system to start, which it will do immediately if it capable.
If this is not the case and you have already tried removing the RAM and the HD, you may need to have the motherboard tested.
Posted on Mar 10, 2011
Track pad will not click
Hi There,
I hate to say it, but you might have one the MacBooks whose battery has swelled, and interferes with using the click function of the keyboard.
If that is the case, you can take your laptop to an Apple Store and quietly, but sternly, raise hell with them so that they will replace your battery free of charge.
Hope this helps & good luck!
Apr 05, 2014 | Apple MacBook Pro Notebook
Macbook pro dark screen
Close the lid, attach an external monitor, reopen lid.
Your display should now show on that monitr. If it is, your display on the MacBook Pro may be bad. I would try resetting the PRAM and the SMC before going to an Apple store. The SMC controls the MacBook's power founcts (see below)
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jan 12, 2014 | Apple Computers & Internet
Can not click on icons
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Dec 25, 2012 | Apple MacBook Air
Hi My laptop "MacBook Pro" first
First insert the CD you wish to boot to. Then let the mac start up all the way. Go to system preferences, then click startup disk. From there select the drive you wish to boot to. then select restart, and it will restart to that disk or CD.
Jan 28, 2011 | Apple MacBook Pro A1189 17
How do you turn off DOS mode on a 13" MacBook Pro?
Is this a trick question? There is no "DOS mode" on a MacBook Pro.
Do you have WIndows installed as part of Boot Camp, and your machine is booting into Windows? To boot back into the Mac, either use the Boot Camp control panel in Windows, or hold down the Option key after you hear the startup chime and select the OS X partition to boot from.
Nov 14, 2010 | Apple 13.3 MacBook Pro Notebook Computer ...
My macbook pro OS 10.6.4 either freezes or crashes on startup. Crashed when trying to startup with Drive Genious 3, TechTool Pro 5, System Disk or Disk Warrior. Not sure what to do next. Tried holding ...
Restart your mac. As it's restarting/booting up, hold down the command, option, R and P keys simultaneously. As it's booting up and you're holding these keys, you should hear the startup chime, continue to hold the keys down, it will cycle and you'll hear the startup chimes again. Let it go thru this cycle 7 (seven) times before you let up on those keys. Once it's cycled 7 times, let it boot up normally.
If that doesn't work, then reinstall the original system software that came with the Macbook. You may have to reformat the hard disk and do a clean install.
Jul 05, 2010 | Apple MacBook Pro Laptop Computer with...
The computer is taking too much time to process
Check programs at startup menu. There should be some programs whis downs computer speed after boot
Apr 12, 2010 | Intel Motherboard
Apple MacBook Pro MB991LL/A 13.3-Inch Laptop Notebook Logo
97 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
