Question about Dell PowerEdge 1400 ( pe1400/210 ) Server
How i turn off a fan from motherboard - Dell PowerEdge 1400 ( pe1400/210 ) Server
  • 22 Answers
The fans that are plugged into the motherboard are usually powered by the motherboard. To turn them off, simply unplug them as there is always a power flow going through the motherboard and even more to power the fans when the system is running. I would recommend keeping the fan in if possible to help with cooling your PowerEdge 1400 server, but if it must be removed, simply power your server down, and unplug the fan. Make sure your server is powered off before doing this, as you don't want to short anything out or cause a spark.
Posted on Mar 16, 2009
Displays momentarily and asks for CPU fan connection. I have changed 4 fans and still get the same error message and the display goes off.
You're sure you have the cpu fan connected to the correct socket? sounds like it's not connected, or is connected to a different socket. Does the fan turn?
Apr 22, 2015 | Computers & Internet
4805 fan not working, the one on the inside. Everything else works.
the new fan that you installed is a good one,but it wont turn on, because there is no electric current into the fan
something is wrong with the motherboard, the motherboard control the electric current (to the fan)
the motherboard is needed to be checked and repaired
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 09, 2014 | InFocus ScreenPlay 4805 Multimedia...
I am not hearing the fans on this computer and i notice it heats up very quickly
With the computer turned off unseat and reseat the fan connectors back to the motherboard. If the fans are still not turning on then try some other new fans. If new ones won't turn on then you know for sure at that point the motherboard is going bad because its not putting out a high enough voltage to turn the fans on.
May 21, 2011 | E-Machines eMachines Desktop PC
Remote control will not turn on fan
Do you have the correct type of fan connected to the motherboard ?
For fan control to work you must be using the type of fan that has at least three wires in the connector plug (if it has four wires that is ok too) but if it only has two wires then it will not works since the third wire is the control wire that the motherboard uses to detect fan speed and so on...
Fans that connect through a connector on the power supply will not work either must be conected to motherboard plug on the motherboard itself with at least three wires
hope this info helps
NOTE: if you are sure you are using the correct type of fan then check BIOS power/hardware monitor settings to see if the fan is connected to the correct plug on the motherboard and to verify it is being detected properly and fan speed setting is correct.
May 15, 2011 | Computers & Internet
I have problem with my fan when turn on my computer say fan failure press f1 to continued press f2 setup
You should first check to make sure the fan is working. Just open it up and turn it on and see if the fan is functioning properly. If not then you can just order a replacement fan from Dell.
Feb 18, 2011 | Dell Optiplex GX280 (99301) Motherboard
Gateway gt4010, wont power on.
The fan turning off will be the cause of the PC shutting down.
This could be caused by a faulty fan or bad connection to motherboard.
1. try reseating the fans power plug on the motherboard
2. if that doesn't help, try replacing with new fan.
3. if that doesn't work then most likely motherboard problem
Feb 11, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
Thise is Fred. A few days ago i assembled a Pentium 4
Some fans are controlled by temperature-sensitive sensors.
So, if the motherboard is "cool enough", the speed of the fan will be reduced to "zero".
Sometimes, a motherboard can enter "standby" mode.
This mode consumes only a small amount of power;
and the fan will be stopped, because the cooling it provides is not needed.
Dec 08, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
My motherboard isnt turning on
my motherboard is connected correctly but when i turn it on, the screen remains off and i put the bios_wp thing on the motherboard correctly but it still wont turn on and the processor fan turns on but nothing appears on the screen and the screen works well....same as my problem did you get then solution
Apr 04, 2009 | EliteGroup P4M800PRO-M478 Motherboard
My fans wont power up
your system shutsdown to save your hardware from damage due to hight temperature because the fan is not working. Make sure you connected everything right on your motherboard. to test if the fan is ok try putting it in another entrance on your motherboard, you can find at least two or three place to connect a fan on your board, if all fails check with a friends motherboard, if that fails replace your fans.
Mar 22, 2009 | Averatec Computers & Internet
CPU fan not turning with ATX 12V connector plugged in
With the fans on its drawing more than the PSU has.The PSU is bad. Replace it. If it still happens please let us know...It shouldnt.
Jan 06, 2008 | EliteGroup P4IBMS Motherboard
Computers & Internet Logo
618 people viewed this question
Alun Cox
