Question about Car Audio & Video
I have a 4 channel blue diamond 2000 watt legacy amp and a duel voice coil 1500 watt power plant sub how do I get the most power to the sub
3 Suggested Answers
mjap
  • 107 Answers
SOURCE: problem with LEGACY BLUE DIAMOND AMPLIFIERS LA1080
never attemp to bridge your amps specially this type of amps. this are too very complicated. you may blow your amp if you will attempt it again.
Posted on Jan 26, 2008
  • 155 Answers
SOURCE: recomended sub woofer wireing diagram have 2
check out audiobahn.com go to tech support and go to wiring diagrams type in how many speakers DVC or SVC and it will show you how...
Posted on May 11, 2010
I have 2 solo baric l7 duel 4ohm subs and a legacy la-2499 amp.What is the best way to wire it up?
Unfortunately, the amp is only 2 ohm stable, so the best option is to connect each subs voice coils in parallel (2 ohms) and connect the subs in series (4 ohms).
Oct 06, 2015 | Legacy Car Audio & Video
On a lanzar 535n 5 channel 3200 watt amp what is the best way to hook up 2 lanzar max 12 inch duel voice coil subwoofers
If your amp allows it hook the the sub's to the first two channels but bridge it and only run it on 2ohms so you don't blow your sub's
May 29, 2015 | Lanzar Car Audio & Video
To get the most power what is the best way to connect paraelle or
run them straight and dont use the cross over. One speak on right channel and the other on other channel. Then turn up amp settings 7/8 the way up and control the rest from your dvd/cd player. I recommend some monster cable which is very thick. Ground the amp directly to trunk bolts but make sure to scrape the paint off or the connection will be bad. You can also use a cap which will send battery pulses to amp much quicker.
Nov 19, 2009 | Lanzar VIBE286 Car Audio Amplifier
Sub box
it all depend on were you are putting these subs at. the dimesion on the trunk of a honda to a lincoln are vastly different
Jul 09, 2009 | Legacy (LA568) Car Audio Amplifier
Need to pick perfect amp
I suggest to use separate amps to your sub, get a 2 channel amp for your sub and 4 channel amps for your speakers.
Here are my Top 5
  • Lanzar -OPTI4000D
  • MA Audio- HK-4000D
  • JL Audio 1000/1V2
  • OPti 22.2 Power Amp
  • AudioBahn-A5100T
Apr 05, 2009 | Power Acoustik FUBAR-12W Car Subwoofer
Wiring a sub with duel voice coil
In short yes. And is very common even has its own term called bridged. Taking two channels and making them one. I would hope that you are running a cap. that's going to put out a lot of power and stress on your battery
Feb 10, 2009 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Subs
I looked up that amp, it doesn't have a listing for 2ohms x1 but it has 2 ohms x 2 and its at 250watts. For this situation, I would recommend a different amp or different subs. Right now you are getting the most you can get out of your sub/amp combo, if you only have single voice coil subs. Which is common in the mtx preloaded boxes. Either you want an mono block amp stable at 2 ohms or 2 dual 4 ohm voice coil subs. If you got the subs you would wire the voice coils in series so you could get 8 ohms then the subs in parallel so you could get 4 ohms, which would be the best for that particular amp. Good luck.
-Andrew Hawkins
Aug 23, 2008 | Legend LA1490 - American Legacy Series 2 -...
I have a 4 channel amp
This amp will not give you 1000 watts of real power. From the specs I've found, it can produce 55w RMS x 4. Bridged, that would be 110w RMS x 2. The most you could get into a dual voice coil woofer would be ~220w RMS.
May 06, 2008 | Legacy BLUE 4 X 250W CAR AMP Car Audio...
Problem with LEGACY BLUE DIAMOND AMPLIFIERS LA1080
Jan 22, 2008 | Legacy BLUE 4 X 250W CAR AMP Car Audio...
Car Audio & Video Logo
37 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
