Question about Garden
Engine malfunction Tecumseh Model: TVT 691 600803A Family Type YTPXS 6912AA. Problem is motor surges at 1/2 Full throttle, "missing" and back-firing. Plugs have been replaced, Engine parts cleaned. Is this a problem with the governor, sync problem with the twin carburetors, or other? Do You have suggestions for fixing this, and where to get a repair manual for this motor?
SOURCE: need pictures of governor springs and governor
model # 12f702-1824e1 mower( that uses weedeater string) had a spring come off the carberator and I don't know where to put it back on.
Posted on Apr 19, 2009
panilling9
  • 284 Answers
SOURCE: Throttle doesn't work properly
try sears.com go to parts and enter your mod# from under your seat IE:358. and so on.
Look around for prompts and info for you mower from your entered mod#
Posted on May 25, 2009
  • 32 Answers
SOURCE: Bad governor on 6.5 hp Tecumseh engine?
did you clean the carb yet?
Posted on Jul 20, 2009
Dolfoff
  • 148 Answers
SOURCE: throttle control won't work after i cleaned the
Hi again Ed,
Starting at the carb throttle shaft, your linkage rod (with tiny spring wrapped around it) should be connected directly to the governor's arm. If there's more than one hole in the arm, connect the rod in the upper-most hole.
Now, at the base of the governor's arm is another hole (possibly on a tab jutting from the arm). The main governor spring should be hooked in this hole and then back to the sliding throttle control that moves when the lever on the dash is moved. (This one definitely has a tab and hole.)
The choke cable end hooks directly on the choke shaft and it has intuitive movement. Verify that the choke butterfly closes and opens relative to the cable control on the tractor's dash.
To insure that we only do this procedure ONCE, and we get it right the first time, let's set the internal governor to base-line at this time.
With everything bolted back up, move the throttle control lever on the tractor's dash to full throttle. Then get a 3/8 wrench and a slotted screwdriver and locate the round governor shaft coming out of the engine block. The governor arm attaches to this with a clamping-bolt. You will notice that the round shaft is slotted for a screwdriver as well.
Loosen the clamping bolt slightly with your 3/8 wrench, insert your screwdriver and rotate the round shaft clockwise until it stops. (It has VERY little travel, so turn it both ways to verify that your are at FULL clockwise position.)
Hold screwdriver there and move the governor's arm in the same (clockwise) direction until the carb's throttle is set to WIDE OPEN throttle. Still holding the screwdriver clockwise, retighten the clamping bolt with the wrench.
Next, move the throttle lever on the dash of the tractor to idle and back to full several times and observe the carb's throttle shaft, it should come down from full throttle to idle and back again freely.
Start the engine and be prepared to shut it off if it over-revs.
If it doesn't over-rev, your base-line settings are correct.
By bending the tab on the sliding throttle control (the one that has the main spring attached) you can now increase or decrease spring tension and change top speed of the engine. Do this in small increments and if you have a tachometer for single cylinder's set top speed to 3400-3600 RPM.
Sorry this is lengthy, but as mentioned above, we only want to do this once.
Hope this helps, and feel free to ask away if you need more info!
Dolf-
Posted on Oct 16, 2009
Testimonial: "thanks for the advice , i got the mower running well now. ed"
  • 78 Answers
SOURCE: I have a 9hp Tecumseh engine on my Sears chipper
I will try again here.
1 wire link from the top hole in the governor arm to the throttle on the carb. There should also be a wire link with a spring that goes from the Governor arm to the speed control handle.
Posted on Oct 22, 2009
Troy-Bilt w/Tecumseh HMSK 80-110 engine. Where can I get a repair manual covering the carburetor OR a picture showing carb linkages?
There are a couple of reasons this could be happening.
1- The throttle shaft could be frozen or gummed up where the throttle shaft sits in the carburetor body.
2 - Check the top of the throttle shaft where the shaft meets the plate, if it is loose or separated it will not allow the throttle plate to move.
3 - The governor spool may be damaged internally in the engine.
Added a couple of Tecumseh manuals below.
http://www.barrettsmallengine.com/manual/tecumsehcarburetormanual.pdf
http://www.barrettsmallengine.com/manual/tecumsehlheadmanual.pdf
Jan 29, 2016 | Garden
How do correct RPM surge on a LH 195 Tecumseh engine
Hi you're governor gears inside the motor could b the problem ...good luck
Aug 11, 2015 | Tecumseh Garden
I have a 10 hs tecumseh motor on a riding mower i need an explode view of carb and linkage when start-up engine it goes wide open
Hi and welcome to FixYa, I am Kelly. I understand you have a 10 HP Tecumseh engine. There are service manuals available on line for your engine but without your engine model number it is difficult to pass you the correct one: Here is the link for the service manuals:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals
Somewhere in the list is your manual.
This is my best guess without your engine model number:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals/TECUMSEH_SERVICE%20_REPAIR_MANUAL_OHH50-65_OHHSK50-130_OHV11-OHV17_OVM120_OVRM40-675_OVRM120_OVXLC120_OVXL120_OVXL125_695244A.pdf
^-Make sure you read about Adjustments in section 1 also.
Running wide open causes:
1. Broken throttle control plate spring
2. Governor spring problem
3. Internal Governor flyweight has departed the governor gear.
4. Throttle plate (butterfly) attached to the throttle shaft in the carb throat has come off the throttle shaft.
5. Broken / missing linkage
6. Someone loosened the governor shaft bolt at the base of the governor arm and allowed the governor to get out of adjstment.
Thanks for choosing FixYa,
Kelly
Aug 12, 2011 | Tecumseh Garden
The tecumseh engine surges from medium to full throtle
If it is at full throttle and the engine speed lowers then raises again to full throttle - back and forth, this is a sign that the engine is starving for fuel. The most common area is the lower jet in the carb. has trash in it or it is gummed up. You would have to remove the bowl on the carb. to have access to it. Check with Tecumseh's website and see if they offer any info "parts breakdowns" to see if the jets come out of the carb. some are fixed in the body and you cannot remove. Good Luck.
Dec 07, 2010 | Toro Garden
Need replacement spark plug for 4.5 hp Tecumseh; model number YTPXS
In my shop, I use Autolite brand plugs. Your engine would have come originally with a #255 or equivilent. Most shops will upgrade that plug to a #458. It is slightly hotter and gives a more efficient burn. You can also use a Champion J19LM or an NGK B4LM.
Oct 08, 2010 | Tecumseh Heavy Machinery
I can't locate the timing marks on engine model YTPXS 185 BB / 143.003504 it is a tecumseh 4hp craftsman
what timimng marks do you refer ? the crank and cam are marked on the inside at the gears internally? the flywhell has a key? searsparts.com has exploded veiws
Aug 26, 2009 | Garden
6.75 Craftsman Eager1 Lawnmower, My son had this mower given to him,after cleaning the carb,plug,air cleaner etc. I noticed a black rubber tube entering the top of the motor at the back, upon starting the...
Go to parts www.searspartdirect.com and put in the model # and it will display all the parts that are supposed to be on the mower. Whatever you are missing just order from them.
May 16, 2009 | Garden
Tecumseh hm80 snow blower motor linkage
below is a web site for you to check out the parts at. Hopefully this helps you out. If not, let me know and I will try to get you a better diagram. thanks.
http://www.outdoordistributors.com/pdf/Tecumseh/TECUMSEH-MODEL-HM80-155315N-PARTS-LIST.pdf
Mar 23, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Motor surges at full throttle
The timing is not the problem if your bike is surging at top end. The timing is fixed on these models and it's not like the old days or like a car. Your problem can be one of many.
First: does the bike idle ok after it is hot?
Second: Have you changed the air filter to an after market type? Changing the filter to an after market filter will lean the motor out which will cause a "surge" at full throttle. You will need to possible jet the motor richer to compensate for the leaner filter design.
Third: Try rolling out og the throttle from full throttle by about 1/8th and see if the engine RPM's increase and the surge goes away, if so the motor is to lean.
Let me know the answers to these questions and I can help you resolve your problem.
Third: how long has it been since you have set the valves? a tight valve can cause many many problems including this one.
Nov 29, 2008 | 2005 Honda CB 250 Nighthawk
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
