Question about Technics SA-DX940
Problem with subwoofer and one off the speakers.
I bought the Technics Receiver SA-DX940 about four years ago. I have used only about eight times. When I used it before, the sub woofer sound wasn't coming on. I have tried everything I knew without opening the system and it could not be resolved.Couple of days ago the sound on the right speaker stopped coming. It is more or less a new receiver because I don't use it much. I don't know what to do. Does anyone has an idea of what should be done?
  • rexdike Mar 13, 2009
    What is IC, and do I have to open the system? The right speaker stopped coming out also.
    Is the same IC346JC responsible for he right speaker not coming on?
  • 10,515 Answers
First of all, tried to use another set of subwoofer.
If the sound is comming from both speakers, either connection is not correct /weakened or there is an issue with that particular sub woofer. You need to replace it.
If the sound is not comming from 2nd speaker on the other set, issue is with system ( Which seems to be a rare case )..
Do rate the solution.
Thanks for using Fixya.
Posted on Mar 13, 2009
    Sergeant:
    Champion:
  • 435 Answers
Hi, Does it have warranty?
Try switching speakers connections to check if the problem is with the speaker or the unit.
Check if the speakers were compatible with the unit. I mean the ohms and watts ratings.
    Genius:
  • 1,550 Answers
First off all remove all connections and connect it once again to check it is not due to loose connection .
Secondly in receiver test all speaker is working if it doesnot indicate your speaker . Mostly hardware fault . Need to open the speaker to check which component is burnt .
    Brigadier General:
  • 8,619 Answers
Hi
Kindly check the wiring on the back of the system. Also try to swap the speakers just to check the speakers.
  • 583 Answers
Just check if the wires are cut off somewhere or the internal connections loseened up.check this out.
    Sergeant:
  • 254 Answers
Check out the amplifier ic in the receiver unit of subwoofer as the number of ic is IC346JC this has to be replaced.
HOW CAN I CONNECT A MIXER TO A TECHNICS SA-DX940 AV
I used the manual downloaded from http://www.manuals365.com/technics/sadx940.html
Try using the final stereo output of the mixer as the input to the CD or Tape or VCR inputs.and use the switches on the fromt of the DX940 as necessary.
The specificatios state input sensitivity is 27 mY so your mixer needs a low output..
No reason it shouldn't work.
Sep 18, 2014 | Technics SA-DX940
I moved and cannot find manuel for sa-dx940 need instruction on how to reconnet wire to t.v. and speaker
The Technics SA-DX940 is made by Panasonic. The manua as a PDF is available here: http://service.us.panasonic.com/OPERMANPDF/SADX940.PDF . The directions for connecting the speakers start on page 14. The connection to the TV is on page 10. To use the SA-DX940 as just external speakers for your TV, connect either the digital audio out from the TV (if it has one) or the RCA audio out from the TV to the matching TV audio in on the SA-DX940.
I hope this helps.
Jun 30, 2011 | Technics SA-DX930 Receiver
I want to buy a Technics SA-DX940 reciever
ebay cheap as chips just keep your eye out for them there always about look for the sa-ax730 aswell more or less the same
Jul 23, 2010 | Technics SA-DX940
Technics Receiver SA-DX940 subwoofer
Make sure subwoofer button is pressed and registers that sub is set on, the check dB level adustment for sub channel with remote.
Mar 16, 2009 | Technics SA-DX940
Surround sound very quiet - technics amp receiver
darn, that was one of the best receivers ever built for the money! all the new receivers these days have 7.1. i would rather have more power in only 5 channels. puppy **** and electronics just don't mix do they? here is the link to get a new one if you like: http://www.google.com/products/catalog?q=SA-DX940&oe=utf-8&hl=en&cid=9395541207809312385&sa=title#ps-sellers
Feb 28, 2009 | Technics SA-DX940
SA-DX940 recently stopped recognizing digital formats
Make sure you are using a digital connection, optical or coaxle cables must be connected, setting on receiver must match cable being used
Dec 18, 2008 | Technics SA-DX940
Probleme with my home theatre...technics..av control stereo receiver- model SA-G76
just an idea maybe check the position of speaker select switch some models have
a or b
or a+b
Apr 24, 2008 | Audio Players & Recorders
Technics SA-DX940
Ratnesh, I have this same receiver and the fan only comes on at certain volume levels. Unfortunately I now live in an apartment and can very rarely listen to it that loud. I had the same problem for a little while until I thought about moving the receiver to the lowest shelf with nothing on top of it. This seems to have worked so far although it does still get quite warm. Good luck!
Aug 04, 2007 | Technics SA-DX940
Technics SA-DX940
overload, usually means that is overloaded. i've had the receiver for about 4 or 5 years now and never had problems with it. It was sitting ontop on my tv for those 4 or 5 years, and i haver noticed it untill just recently, (when i bought a new tv and i had to get a stand for it, and i had to stick the receiver in it)that is runs very hot, very quickly; Maybe that is the problem you are having now, that the thins is older and maight be able to handle it as it id b4. Maybe you made some changes to your set up: new speakers, etc.
Jan 25, 2007 | Technics SA-DX940
Technics SA-DX940 Logo
198 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
