Question about Maytag Refrigerators
Maytag mfi2568aeb The ice/water dispenser light has been out for years and no one can figure out how to fix/change. Now, the entire dispenser will not work. We get no ice, no water. Any ideas how to fix? I can't find anything in my manual.
  • Maytag Master
  • 4,655 Answers
maytag mfi2568aeb - 12200d1b-6a90-43fd-b120-a7ad4303e922.jpgI believe the wiring for the dispenser control comes out of the area near the bottom left hindge. I want you to look there for a plug that attaches to that wiring that goes up to the dispenser, Try to see if for some reason the plug is not pressed together firmly. If all of the wiring connections are together tightly the next part to have a look at is the=> 67006294 Dispenser Control Board For most people this is not a simple solution but for those that can use my assistance I will be here to answer any questions you may have, Thanks Sea Breeze
Posted on Apr 24, 2013
SOURCE: GSS25LGMF WW Will not dispense ICE or Water, lights are on
If the water does not dispense, it may be that the water line is frozen in the refrig. section. The solution is to lower the temperature setting of the refrig sect a number or two.
If the ice bin is full and does not dispense, it is probably a bad or frozen auger motor. To test it open freezer door and remove the ice bin by sliding it out. Then hold the door switch while you press the dispenser lever on the outside of the door. You should see the motor turn in the back of the fridge. If nothing happens, it should be replaced. If it just hums, it may be frozen. In that case, wait till the freezer finishes defrosting and test again.
Posted on Mar 02, 2009
  • 26 Answers
SOURCE: Ice maker has quit making ice
Lower the freezer temp. The icemaker won't come on until the temp is low enough.
Posted on Mar 10, 2009
SOURCE: Maytag MFI2568AEB- icemaker flapper keeps
Replace main control board known as the hv board part number 12920710 Ive replaced many the reprogramming code number is on the model number sticker the instructions for reprogramming are in the Tech Sheet located under fridge behind front grill rh side stuck to the top of the bottom in plastic bag new board will not work without reprograming Can you solder? replace the 2 680 microfarad caps located on the board located lwr center next to the china sticker they are side by side and the tops of these caps apear to be bubbling out. Mouser.com mouser part number 647-upw1v681mhd caps are less than a $1 a peice and new board $180
Posted on Apr 03, 2009
SOURCE: Ice and water dispenser stopped working
Welcome to the computer world. When depressed, the paddle actuates a switch attached to the bracket above. The switch sends a low voltage signal to a small circuit board mouted right behind the display. A computer chip on that small board communicates with another chip on the main control board mounted in the rear wall. Your situation could be a bad actuator switch, a broken paddle tab, possibly a bad door switch (the fresh food doors must be closed to dispense), or a bad electronic control.
Posted on Jun 05, 2009
Sea Breeze
  • 4655 Answers
SOURCE: My maytag water dispenser not dispensing water
I am sorry I can not find a model listed Maytag Email me with the correct model or visit my site to see where to look for the model numbers.email is appliancepartsse@yahoo.comsite is below, Thanks, Sea Breezehttp://servicepartstec.blogspot.com/
Posted on Jun 10, 2009
How to change the light bulb in the outside ice/water dispenser
Question about Maytag 22.6 cu. ft. Side-By-Side Refrigerator with PuriClean II Ice and Water
The light on the outside door (where the ice/water dispenser is) won't turn off. It is dimmer than when you hit the 'light' button, but it stays on constantly when the door is shut. The 'light' button works and turns the bulb brighter, but when you turn it off, it just dims and doesn't go out. The light shuts off when the door is open and turns back on when its closed. Model Number MSD2456GEB
Posted by linsdesk on Aug 31, 2011
Aparajita Batabyal
  • 3,513 Answers
Re: The light on the outside door (where the ice/water...
Hi
Reprogramming your refrigerator to only light up when the dispenser is in use saves energy and keepsyour house darker at night. The light is controlled using the buttons above the water dispenser mechanism.Press and hold the "Lock" or "Lock Controls" button for three seconds to activate the controls if they currently are locked.Tap the "Light" button to switch off the light.Press and hold the "Lock" button for another three seconds to lock the controls from further changes. The light now only comes on when the dispenser is active.
If the above procedure won't work then this will be the cause of a faulty switch. This light switch is an integrated part of the dispenser control circuit board. This will require you, or your service tech to replace the entire dispenser/ice maker control board. It will be located just behind the dispenser fascia, mounted on a bracket. the actual light switch circuit is mounted on this board.
Try this procedure:-
Shutdown the unit for five minutes. Simply unplug the unit for this length of time. This will reset the board, and possibly, fix this fault if it is not to severe. If the shutdown dose not correct the switch action, simply replace the dispenser/switch control circuit board.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Jul 25, 2015 | Maytag Refrigerators
Maytag MSD2756GE ice maker issue. makes ice fine. While dispensing water in the door, it also fills the ice tray at the same time. Water comes out ice fill tube AND door. If no water is called for at the...
This is an odd one!The water control valves has separate sets of wiring that travel through the dispenser control board. That gives an opportunity for strange things to happen as mentioned in your post. If you haven't replaced the dual water control valve and put the wires back wrong the next thing will be to test the 61005274 Dispenser Control Board
If you have a OHM meter and a voltage testing meter I don't mind helping you to test the wires and 61005274 Dispenser Control Board I can send you to a link to view the wiring diagram and walk you through the diagnostics. Let me know, Thank you, John T
Appliance 911
Contact Me Here
Apr 27, 2014 | Maytag MSD2756G Side by Side Refrigerator
My Maytag msd2556ae will not dispense water throught the door. It makes ice just fine, and will dispense ice through the door, but not water. I've replaced the filter in the fridge, but no change.
There could be a blockage of its iced up. A complete defrost might fix it.
you'll have to leave it switched off with the doors open for 24 hrs.
Sep 01, 2012 | Maytag Refrigerators
Still got a problem with mfI2568aeb water and ice don't work
I was wondering if maybe the ice box was in sabbath mode?
Sabbath Mode (SAb)
When the Sabbath Mode is on, all control lights,
interior lights, and the night light will be disabled until
the feature is turned off. Press the Door Alarm pad
for three seconds to restore the lights.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 21, 2010 | Maytag MFD2561HE Bottom Freezer French...
Slow water dispenser on mfi2568aeb
There will not be a one word solution to this but if we test the areas beginning with the water supply line we will come to a answer. You need to look at where and how the water line is connected to the water service line. Shut the water supply off at its source. remove the water line on back of refrigerator and point water line into a pan or bucket and have someone turn the shut off back on. If flow is poor then the suppline has a blockage at the tap valve that is (not recommended) or a crimp in the feed supply line to refrigerator. If that turns out to be OK then we move to the dual water control valve part number 67006322 It also may be that the valve is not opening well due to being worn out, I am ready to assist you when you are, Sea Breeze
Apr 18, 2010 | Maytag MFI2568AE Side by Side French Door...
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Ice maker wont make ice
CHANGE THE FREEZER TEMP TO -2 AND THE REFRIGERATOR TEMP TO 44 AND IT WILL START MAKING ICE AGAIN
Nov 25, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Feb 16, 2008 | Washing Machines
Refrigerators Logo
256 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
