Question about Briggs & Stratton Garden
Bolens briggs 4.5 will not run right
We bought a 2011 Bolens small wheel 4.5 Briggs & Stratton 1 run speed push mower last year new for my sister. It mowed the rest of the season good. This season it quit all of a sudden. It did not have 20 hours on it yet. I checked the gas and saw trash.I removed the air filter to remove carb and tank to clean and noticed the governor spring was missing. Replaced with another alike spring after cleaning every thing to finish. Adjusted it for proper run speed not to fast good enough to get the job done. After a while it started popping,sputtering and black smocking not allot but noticeably. I checked the spring to see if it was still their it was so I pushed on it a little to see what it would do. The problem got worse. I tilted it back so I could see the spring better and it smoothed out. I set it down problem returned. So I set it up again and played with the spring again to see what it would do the problem returned but after a little wiggling the mower revved up and started to act right. She finished mowing. The next day I decided to check it out again. It would run with the foam air filter off so I cleaned it, gave it a light mist of WD & squeezed it out. It would run but only if the idle was lower than normal. I tilted it up and played with the spring until it started to rev like it should. Then readjusted the spring for proper idle. What it going on with this mower it is not old,or run enough for this kind of problem. Carburetor is built on to tank has primer bulb no throttle has one run speed. Can't think of anything else at this time.
  • Briggs & Str... Master
  • 7,482 Answers
Hi martha4745
Posted on Apr 25, 2013
Carb float bowl has an electric selanoid on it no wires going to it how does it work and where do wires hook up
Carb solenoid and a fix, dont forget the cut off valve ...
? 10:23
https://www.youtube.com/watch?v=gQw2pQ_oa6o
Jul 16, 2012 - Uploaded by Murray Mayhem
would you advise doing this on a 2004 Bolens with a 15.5 Briggs..... I have a 15 hp Craftsman-koher riding lawn mower that won't run. ... when I put power to it, and the there is gas in the bowlwhen I take it apart. ... Rename the video "How to Bypass Carb solenoid for Temp Fix on no start" Try to edit that ...
Small Engine Repair: How to Check a Solenoid Fuel Shut ...
? 4:40
https://www.youtube.com/watch?v=Kr6UayxyVwU
Jul 23, 2011 - Uploaded by smallengineshop
When the engine is stored with fuel in the carburetor for long periods, there is a .... There is gas in the carb in the lower portion where the float is. .... Engine hadn't been run for over a year and the solenoid would not operate. .... DIY - CarburetorReplacement On Lawn Tractor With Briggs & Stratton Engine ...
Dec 01, 2015 | Briggs & Stratton Garden
Bolens 2011 briggs 4.5 torques runs bad
Something is dirty in the fuel system. Sometimes I will start the engine and spray WD-40 into the air intake and keep the engine running with the WD-40 in hopes it clears out any debris. I would spray a half can.
Feb 28, 2017 | Briggs & Stratton Garden
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
Bolens 4.5hp mower won't start
did you hit a rock? and shear the key that times the flywheel to the crankshaft check for spark the coil might have failed
Jul 01, 2012 | Briggs & Stratton Briggs Stratton...
One year old bolens push mower, 550 series B&S
How is your compression? If it is low, your piston rings and/or the cylinder walls could be damaged and pulling oil up to the combustion chamber, which will burn oil and foul the plug. If you overfill the oil you could possibly get this also. When was the last time that you changed the oil and/or put oil in it? Do you currently have proper oil level?
Sep 06, 2011 | Briggs & Stratton Garden
I have a Bolens 22 inch push mower and need to increase the running power by finding the idle increase on the spring choke.
thers a lever on the throttle plate that has a spring on it bend it a little to put more tension on the spring that should speed it up
Jun 04, 2011 | Briggs & Stratton Garden
I have a Bolens 22"
There will be a small screw near the carb with a spring around it.That is the idle screw.Turn it left to increase the speed.
Thank You for using Fix Ya.
Jun 04, 2011 | Garden
Briggs & stratton 550 / surges, gas hog
check your air filter. If it's clogged, the engine will spool up to keep from dying, run for about 15 seconds, then it will happen again. If that's it, just clean the air filter. Solved my problem
Jul 26, 2010 | Briggs & Stratton Garden
Bolens 4.5 Briggs and Stratton: I prime the carb
Be sure the fuel is fresh....meaning, fresh from the gas station. IF that doesn't fix it, replace the carb.
Oct 07, 2009 | Garden
Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Aug 04, 2009 | Garden
Garden Logo
144 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
