Question about Garden
Engine malfunctioning Model TVT 691 600803 Family type YTPXS 6912AA Problem is motor surges at 1/2 full Throttle, "Missing", and back-firing. Plugs are replaced, engine parts cleaned. Is this possibly a problem with the governor,sync problem with the dual carburetors, or other?
panilling9
  • 284 Answers
SOURCE: Throttle doesn't work properly
try sears.com go to parts and enter your mod# from under your seat IE:358. and so on.
Look around for prompts and info for you mower from your entered mod#
Posted on May 25, 2009
  • 62 Answers
SOURCE: governor shaft doesn,t react to engine speed,
THE GOVERNOR GEAR MY BE SHOT IN THE ENGINE
Posted on Sep 25, 2009
vincob
  • 718 Answers
SOURCE: When put at full throttle
You can find out how to adjust governor on you -tube. give it a try.
Posted on Mar 10, 2011
canwoodjc
  • 3301 Answers
SOURCE: B &S 16hp engine on
check the fuel cap too,, it needs to be venting for better fuel flow, also,, when was the last time it got plugs,, it may be flooding out due to weak spark
Posted on Jul 07, 2011
smitty5609
  • 243 Answers
SOURCE: Diagnose 15hp Kawasaki lawn tractor engine. Engine
There is a spring on the carborator that acts like a govoner. Look to see if its streched out or missing.
Posted on Sep 30, 2011
Engine surging at idle and back firing when you accelerate on a 1994 Land Rover V8i discovery
Year make and model helps...Clean the throttle body and MAF sensor. Clean or replace the idle air control motor.(IAC)
Sep 17, 2016 | 1994 Land Rover Discovery
2011 Honda Activa surging while driving
Hi, Harbhajan and the usual suspects are:
1. Extremely lean fuel mixture.
2. Dirt, rust, water, or ethanol sludge in the fuel system.
3. Sticky throttle cables.
4. Multiple carburetors not in synchronization.
5. TPS sensor out of adjustment or faulty.
6. Wrong spark plugs for the type of service.
7. Throttle bodies not in synchronization (FI)
8. Faulty O2 sensor.
9. Clogged, stuck, or faulty IAC valve.
10. Aftermarket components not compatible with ECM.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Bike feels like its surging while riding Harley Davidson Forums
idles great surges during throttle
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda activa 2009 Owner Manual
Jan 21, 2013 | 2011 Honda Activa
1990 chevy blazer 350 ci throttle body fuel injected . the motor is flooding out u can see the injectors keep dumping fuel into the throttle body
Sounds like you have an injector leaking. Have someone just cycle the key on and off to run the fuel pump but don't crank the engine. If you see fuel dripping from the injectors, unbolt the injector cover on the throttle body, remove the injectors and replace the orings around the injectors.
Jul 22, 2010 | 1991 Chevrolet C1500
Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Jun 15, 2009 | Boating
1996 Cobra Mustang surging or loping wont run right, missing
You should check the engine coolant temprature sensor (ECT).
May 31, 2009 | 1997 Ford Mustang Cobra
6.75 Craftsman Eager1 Lawnmower, My son had this mower given to him,after cleaning the carb,plug,air cleaner etc. I noticed a black rubber tube entering the top of the motor at the back, upon starting the...
Go to parts www.searspartdirect.com and put in the model # and it will display all the parts that are supposed to be on the mower. Whatever you are missing just order from them.
May 16, 2009 | Garden
Motor surges at full throttle
The timing is not the problem if your bike is surging at top end. The timing is fixed on these models and it's not like the old days or like a car. Your problem can be one of many.
First: does the bike idle ok after it is hot?
Second: Have you changed the air filter to an after market type? Changing the filter to an after market filter will lean the motor out which will cause a "surge" at full throttle. You will need to possible jet the motor richer to compensate for the leaner filter design.
Third: Try rolling out og the throttle from full throttle by about 1/8th and see if the engine RPM's increase and the surge goes away, if so the motor is to lean.
Let me know the answers to these questions and I can help you resolve your problem.
Third: how long has it been since you have set the valves? a tight valve can cause many many problems including this one.
Nov 29, 2008 | 2005 Honda CB 250 Nighthawk
What are the diag codes for my 2005 sonata, 6 cyc. motor, the check engine lite comes on dominic.livoti@ngc.com
Hyundai Specific Trouble Codes Code Description P1100 Manifold Absolute Pressure (MAP) Sensor Malfunction (Open/Short) P1102 Manifold Absolute Pressure (MAP) Sensor Malfunction - Low Voltage P1103 Manifold Absolute Pressure (MAP) Sensor Malfunction - High Voltage P1147 ETS Sub Accel Position Sensor 1 Malfunction P1151 ETS Main Accel Position Sensor 2 Malfunction P1155 ETS Limp Home Valve P1159 Variable Intake Motor Malfunction P1171 Electronic Throttle System Open P1172 Electronic Throttle System Motor Current P1173 Electronic Throttle System Rationality Malfunction P1174 Electronic Throttle System #1 Close Malfunction P1175 Electronic Throttle System #2 Close Malfunction P1176 ETS Motor Open/Short #1 P1176 ETS Motor Open/Short #2 P1178 ETS Motor Battery Voltage Open P1330 Spark Timing Adjust Malfunction P1521 Power Steering Switch Malfunction P1607 Electronic Throttle System Communication Error P1614 Electronic Throttle System Module Malfunction P1632
Go to this page for generic codes that are for all OBD 2 systems
http://www.troublecodes.net/OBD2/Pcodes.shtml
Aug 29, 2008 | Hyundai Sonata Cars & Trucks
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
