Orion 1505vt monitor - Televison & Video
Display on and off
you have a blown capacitor on the motherboard use a voltimeter to find and replace it parts are very cheap from maplin at around 70 pence each
Nov 17, 2013 | Orion Computers & Internet
Orion model 15dcl push power button monitor blinks on then goes black you can see image on screen but backlight is out
Well, most common failure in the LCD monitor is due to bad caps, worst case will be the lamp assemblies.
So look for bad caps first.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 30, 2010 | Orion Computers & Internet
The monitor will not come on. We tried different power cords but no luck.
john855, Need to know model and "date of manufacture" from rear of unit to provide you with some help. Is unit LCD or CRT type of display? Is unit powered by a wall outlet or is it connected to a multi outlet "power-strip" ?? 12fixlouie
Sep 27, 2010 | Orion Computers & Internet
My monitor sounds like it is leaking a gas?
Hello
Right click on the dersktop and go to propperties.
Now you need to adjust the frequency of the monitor.
Listen to when you hear the least noise. Hope this can help you.
Best regards
Andrea
Nov 06, 2009 | Orion 19DFLB (Black) 19 in.CRT...
Which EMC Legato products for network monitoring?
I've tried Orion, solarwinds network performance monitor and it is great, visit their site, you can dl a trial, it is worth buying for your network.
Mar 20, 2009 | Computers & Internet
Taping from surveillence cameras
the vcr has to be set to moniter the camera!...buy a cheap universal remote and push monitor in the menu screen!
Dec 10, 2008 | Orion VR213 VHS VCR
Remote codes for a orion tv
These are codes used with Orion TVs
0713, 0115, 0105
Mar 01, 2008 | RCA RCU300WBL Remote Control
Orion TV remote
my orion if you channel down below channel 2 it goes to aux.
Oct 24, 2007 | Orion1934 19" TV
Televison & Video Logo
Top Televison & Video Experts
