Bartender error 1402
Information Message #1402
2 Suggested Answers
AmitGoyal007
  • 3 Answers
SOURCE: I CANNOT INSTALL ADOBE READER 9.1 ERROR MESSAGE 1402 APPEARS
Do the following solutions first of all please remove all previous versions of Acrobat, and then reinstall.
1. Choose Start > Control Panel (Windows XP)
2. Double-click Add Or Remove Programs.
3. Select Adobe Acrobat [version] and click Remove.
4. When prompted, confirm that you want to remove Acrobat.
5. Repeat the above procedure for all installed versions of Acrobat.
6. Restart the computer, and then reinstall Acrobat.
Now, perform the steps below during Acrobat Reader installation. The Administrators group listed below is the default local administrative group for Windows XP.
  1. Write down the path to the key referred to in the error message and leave the installation running. For example: HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.pdf\PersistentHandler.
  2. Choose Start > Run, type regedit in the Open text field of the Run dialog box, and then click OK.
  3. Navigate to the parent of the key referenced in the error message. For example, for the key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.pdf\PersistentHandler, open (double-click) HKEY_LOCAL_MACHINE >SOFTWARE > Classes > .pdf.
    Note: These steps may vary slightly depending on the path in the error message
  4. Right-click on the parent key and select Permissions (HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.pdf).
  5. Verify that the Administrators and SYSTEM is present and that Full Control is selected under the Allow column.
  6. In the Permissions dialog box, click Advanced.
    cid:1f55f5d78f3846839533f8a85e395973@joanne
  7. Select the Administrators group (1) and "Replace owner on subcontainers and objects" (2). Note: Select the current administrator account if the Administrators group is unavailable.
    cid:3ce74f38956e4dfcae487444ce8f86c9@joanne
  8. Select both "Allow inheritable permissions from parent to propagate to this object" and "Reset permissions on all child objects and enable propagation of inheritable permissions," (1) and then click the Owner tab (2).
    cid:be8ff9254ad94f29bec91706f67dc76b@joanne
  9. Click OK (3) in the "Advanced Security Settings" dialog box. Windows will now reset the permissions for each child object to correspond with its parent.
  10. Minimize the Registry Editor and click Retry.
    • If the error reoccurs with the same key proceed to Solution 4.
    • If the error occurs with another registry key repeat Steps 1-10 using the new registry key.
    • If the error does not occur finish the installation following the on screen instructions and exit the Registry Editor.
Please let us know how it goes.
Posted on Jun 16, 2009
Error 1402.Setup cannot open the registry kaey. HKEY_LOCAL_MACHINE\Software\Classes\CLSID\{7EA9A8FA-F5D2-49E1-99E8-C26EE07FCEEB}\LocalServer32.
The first thing you should do to fix this error is - if you're using Windows 98 or 2000 - to use the 'registry checker' facility. This is done by loading up the "Run Console" with CTRL + R and then typing "registry checker". If the registry is intact then this will not be a problem. On later versions of Windows, you should use a 'registry cleaner' program to perform this task.
If you have XP, Vista or Windows 7, you should first download a registry cleaner from the Internet and let that scan your system. It will look for any registry errors on your PC and then fix them, which should fix the 1402 error in the process. To use one of these, you need to download a registry scanner program and then let it scan your PC. It will identify all the damaged parts of Windows and should fix them. And if one of these registry errors is causing the 1402 error then a quick restart after the registry scan should enable you to install Office or the program you wanted.
If that method did not work, you should try using a different user account, or creating a new user account, to install the program onto. It's often the case that user accounts will become corrupted for whatever reason, blocking access to the registry. This causes the 1402 error because it means that the program cannot access the files and settings it needs to create when it's being installed. You should try creating a new administrator account and then installing the program on that.
Jun 08, 2011 | Microsoft Windows XP Professional With...
I cannot get Sunbelt VIPRE to install on my computer.
Mark you have posted this Question a few moment ago
Here
if you are seeing this 1402 error for install and uninstall, theremay be some corruption in your registry. If you were on XP, I would sayrun scanreg /fix to try and fix the registry,
http://kb.adobe.com/selfservic.....lId=329137
http://kb.adobe.com/selfservic.....;sliceId=2
Finally, do you have any other Acrobat products installed? I askbecause if Adobe Reader is uninstalled, and there are no other Acrobatproducts,
This Anti Virus Program (if you were downloading it From a web-site) ora Pop Window you may have just down loaded a Bot or Virus.
Sep 08, 2008 | Computers & Internet
While trying update my Adobe reader, i got the message of the updater: error 1402: could not open key: HKEY_LOCAL_MACHINE\SOFTWARE\... i have tried to uninstall the Adobe reader from the control panel,...
The error is in a registry file.....you need to repair the registry...you can use any registry mechanix for it.....try downloading registry mechanic and running it on your system.
Feb 15, 2011 | Computers & Internet
WHAT IS ERROR 1402. setup cannot open the registry key. WHENEVER i TRY TO INSTALL OFFICE 2010 ON MY LAPTOP THE ABOVE MESSAGE COMES UP.
It's a security related error. You either don't have permissions to install it because you are not an administrator on that machine or else you need to reset permissions on some registry hives.
Sep 25, 2010 | Computers & Internet
Error 1402
Hi Glenn,
As you have not mentioned the operating system that your are using. I suggest that you visit the below support website. The site has different steps to resolve issues occuring in ME/XP/98 and Vista.
If you find the information useful, please grade my answer
Apr 05, 2010 | Computers & Internet
Can't install adobe reader 9.1 - Error 1402
Hai,
Error 1402 Could not open key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run.
Verify that you have sufficient access to that key, or
contact you support personnel.
They are using Windows XP Home edition. I fear that they
have one to many viruses/ spyware apps on the machine
already and it may just be time to re-install the OS, but
wanted to make sure this was not something that someone had
ran into before...
Thanks
Jaggu
Sep 19, 2009 | Adobe Computers & Internet
Camera is not connected yet. I get the same error message. If you call logitech they say its in your registry and they cant help. Anyone got an answer on getting past this or how to fix this 1402 error...
after the driver is installed ...just try to see if the camera is recognized..into the devise manager ...you can fix it from there by cliking update driver ...sometimes it isnt rec until you locate the driver manually ..
Apr 12, 2009 | Logitech QuickCam Pro 5000 Webcam
Give the solution of my HP PSC 1402 All-in-One InkJet Printer Problem
Have you tried to download the driver form HP Support and install it?
And....are you using Vista?
Here is the support page for your printer.
PSC1402 Support
Download the correct driver for your operating system.
Uninstall (delete) the printer and start over. Make sure you disconnect the usb cable before you install the software. Don't plug it in until the software prompts you to.
Nov 04, 2008 | HP PSC 1510 All-In-One InkJet Printer
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
97 people viewed this question
k24674
jasbo
jasbo
