Xenius LCDX37WHD88 codes for fixing the screen service mode
Service mode??? burn mode???? need codes to enter into lcd to fix the screen flashing red then blue then green
    New Friend:
Akai plazma t 47inch Basic hook up to cabl Line
Posted on Apr 24, 2013
SOURCE: code to enter service mode
hud-21b9b
Posted on Feb 15, 2008
SOURCE: Samsung LCD TV LN40A650 - Service Mode
1. Turn off the TV
2. Press "info" then "Menu" then "mute" and then "Power" on your remote (As fast as possible).
The TV will now start up in Service Mode
Breinholm / Denmark
Posted on May 24, 2008
SOURCE: No picture on Westinghouse W32701 LCD Model
Screen goes black, sound unaffected. Can be remedied by turning off and immediately back on, but it will do it again and again and again.
Posted on Mar 02, 2008
  • 188 Answers
SOURCE: TV FLASHES DIFFRENT COLOURS
The set could be in a demo mode.Wich brand is the set?
Posted on Jul 20, 2009
tvservice306
  • 458 Answers
SOURCE: red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Posted on Sep 04, 2009
How do I tune my remote control to my xenius TV
xenius tv remote code - Technical - Digital Spy Forums
forums.digitalspy.co.uk/showthread.php?t=492951
Digital Spy
Nov 30, 2006 - 24 posts - ‎12 authors
hi all, found this site trying to sort my new tv out. i am trying to set the code on my skyremote to control the volume etc on my xenius tv, but i cant ... Vestel remote control question (TOO versatile ...
Sep 2, 2010
TV stuck in standby mode. - TV and Home Entertainment ...
Feb 9, 2010
More results from forums.digitalspy.co.uk
Xenius LCDX37WHD88 - Who Makes This TV & Wheres The Customer ...
www.avforums.com > ... > Televisions > LCD & LED LCD TVs
Jul 15, 2009 - Hiya, I am having problems locating a picture of the remote control for a... hi my remote has broken for my xenius tv I have bought a universal ...
I cannot programme channels for my xenius 32" lcd - Fixya
Jan 13, 2016 | Televison & Video
Philips 40PFL7705DV Stuck In Factory Service Mode
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 22, 2015 | Philips 40PFL7705DVF7 LCD TV
Which board is it
hi this is screen burn mode, press the menu button on the remote to stop it you may have to retune tv back in, if this don't work, you will need to go into the service mode and turn the screen burn mode off,to do this press menu on the tv and menu on the remote, you should see another screen pop up, select screen burn mode to off if the first sequence don't work try ok on the tv and ok on the remote, thanks
regards
shaun
Mar 25, 2015 | LG 37LG60 37 in. HDTV LCD
My magnavox tv changes from green to red to blue and stuff and i get no picture or sound on it what is wrong with it? and is there something i can do to fix it?
Sounds like T'Con board fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 11, 2015 | Magnavox Televison & Video
Xenius 37" lcd blue light just keeps flashing
my 37" xenius tv started losing its picture to a stripe screen then started flashing red blue green .know wont come on at all .wht part do i need to fix it please
Aug 07, 2012 | Televison & Video
The word "Factory" has appeared on the screen in red
Hi.
Factory on screen means that the TV is stuck in service mode (Durabrand and more). The problem is fixed accessing Service mode and resetting to factory default settings.
On Durabrand TVs problem is fixed using a programmable remote, entering service code on remote, and accessing service menu.
Procedure is listed on TV service manual.Most durabrand use Menu and key combination 683 to access service mode.
If that does not work, calll manufacturer number to get the key sequence to enter factory menu.
Jul 06, 2010 | Televison & Video
SC546
SC541 - SC-555
These codes mean you are having a problem with your fusing unit. The section of your copy machine that has to heat up before you can make copies. It runs at a pretty high temp because it has to melt the toner and press it into the paper as the copy moves through the machine. Depending on the code, your machine is either taking too long to warm up or it is overheating.
The most common reason is a build up of hard crusty toner on the temperature sensors. This tricks the machine into not seeing your fuser warm up fast enough. Most of the time you can reset this and continue to use the machine but expect the code to come back down the road. You can also get codes if the room the copy machine is in is too cold when you start up the machine. Either a cold winter day or even a summer day in a room too cold from air conditioning.
Some machines require you to enter a service code to reset a fuser/fixing unit error. Some only require you to enter the service mode, then turn the machine off / on using the main power switch. The main power switch is the one you have to rock to the off and rock back on, not the little button you press for power to come on.
To enter the service mode press the following keys in order:
Clear modes
7
then press and hold the stop key
You will see the display screen change. At this point turn the machine off / on to reset the code.
If your machine does not have an LCD display screen you should have seen the copy quantity
display change to a flashing zero.
Some machines will need to add a step to the above instructions.
Once the LCD screen changes, select the "SP Mode" selection from the touch screen.
Enter 5810
This is the Service Program (SP) that resets Service Codes (SC-###)
You will either have to select 1 to accept or select the touch screen button to activate this SP.
After you do, turn the main power off / on to reset the code.
If you try this and the code still comes back on, you have an electrical or mechanical problem that you will need to call a service company to repair. The reason for making this code so hard to reset is a safety issue. If there is a short in your fuser unit it can cause your machine to over heat and possibly cause a fire. There are thermistors (temperature sensors) and thermostats (temperature fuses) that will keep your fuser from overheating. If either of these devices are worn out, you will not be able to reset the code and will need to have your fuser serviced.
Jun 19, 2009 | Office Equipment & Supplies
Dell monitor flashing different colours and buttons won't work!
Go into your monitors settings and select "Factory Reset" Then go to "Factory" and you will find the burn in setting. Turn burn in to off. This should fix the problem.
Jan 08, 2009 | Dell E176FP 17" LCD Monitor
Xenius 27" flat panel tv
i just got a brand new xenius flat tv on pay as you view 1 week old and watching it and it just switched it self off the power light is there but wen i switch it on the power button only flashes no picture then switches it self str8 to stand by again well not happy any 1 no wats wrong be sides its fooked lol
Feb 27, 2008 | Televison & Video
Benq monitor flashes primary colours when switch on or off
This is called burn-in mode. Used to test the monitor at the factory.
To fix this, use the buttons under the front of the monitor,
There are six buttons. Let's number them 1 to 6 from the left.
Press 6 to display menu (at the bottom in Red will say Burn in mode on)
Press 4 or 5 until Recall is highlighted
Press 6 to select
Press 4 or 5 until Recall All is highlighted
Press 6 to select
Press 4 or 5 until Yes is highlighted
Press 6 to select
Press 3 to exit
This will reset all paramaters and also turn-off burn-in mode
If you want to reset some parameters to your preferences, press 6 again to bring up menu and
see you user guide to get explanations for the different settings.
Dec 10, 2007 | BenQ FP71E 17" LCD Monitor
Televison & Video Logo
435 people viewed this question
Top Televison & Video Experts
