Question about Garbage Disposals
Intermitant clanking noise when switch is turned on
It sounds like something is loose - can it be repaired without removing the whole thing It didnt happen when I was using it, but there was a guest in our home who used this sink often, but never told me about the problem. does it sound like something is broken or just needs to be tightened, I hope.
How to remove plastic cover from Kenmore disposer model 17567540
Usually, disposals are not a repairable item.
The loose shredder plate is integral with the motor shaft so they cannot come loose unless the disposal needs replacement.
Following link has part resources, manuals, and installation tips.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Kenmore is serviced by Sears, and you can order parts from Sears, and view some parts sheets online at their site.
Gene
Water Heater Timers Save Money
Aug 02, 2014 | Garbage Disposals
How do you fix a flywheel seal in a garbage disposal?
I'm not sure what a flywheel seal is but I'm going to tell you to just remove the unit. I know it seems intimidating but these things are so super easy to remove you'll be amazed. From there you can dismantle it or replace it. There really isn't a whole lot to them. You'll see : )
Jun 08, 2014 | Garbage Disposals
It will work but it sounds like metal is grinding in it.
Use vacuum cleaner to see if something is loose.
Otherwise, a noisy disposal that works is functional and not dangerous... but annoying.
Life of disposal is probably shortened since the bearing seal could have failed letting water in, and bearings could be rusted.
Replace disposal if noise bother you.
Gene
May 06, 2014 | In-Sink-Erator InSinkErator Badger 3/4-HP...
Motor just hums,grinder wedges are free, no leaks apparent,motor turns free in both directions.
yes there is start capacitor on each motor, connected to start winding.
There are two windings on each motor: start winding and run winding.
Both windings receive power at same time. If the start winding is bad, or capacitor is bad, then motor hums as the run winding receives power but there is not enough torque to get the motor rotating.
If motor is humming instead of rotating, then quickly the motor overheats and looses speed after repair or melts and fails.
The problem with disposal repair is getting the thing apart... finding replacement capacitor, or replacement parts, and then reassembling without a leak.
http://waterheatertimer.org/Color-codewire.html#motor
http://waterheatertimer.org/Color-codewire.html#Motor
Gene
h
Nov 15, 2013 | In-Sink-Erator Garbage Disposals
Reset button not working
Try reset button on bottom of disposal.
Following link has full troubleshoot resources:
If reset will not restore functionality, check that unit is getting power, and then check that unit is receiving 80% rated voltage. Replace disposal.
Add a comment
Jun 20, 2013 | Whirlaway Garbage Disposals
Our garbage disposal won't turn off. batch feed
Turn off circuit breaker, and replace switch
Copy following link to repair, troubleshoot and replace disposal:
Add a comment as needed, or repost question with detail
Sep 03, 2011 | KitchenAid Batch Feed Garbage Disposal...
Garbage Disposals Logo
Top Garbage Disposals Experts
Gene Haynes
Gil Shultz
ray gallant
Are you a Garbage Disposal Expert? Answer questions, earn points and help others
