Question about Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
My Oster A5 is making a loud clacking sound. The sound only happens when the blade is in motion. If the motor runs without the blade, it has a normal sound. I think it has to do with the plastic part that moves the blade getting loose or wearing out or needing grease. How do I fix it?
  • 448 Answers
This is for Clees534, with whom I have some sympathy. Terms regarding devices are all too often assumed as understood. For most purposes, these are what you have to know for the A5 Oster. The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). That gear is turned by the armature gear of the motor (which is where things get much too involved to cover here, but from that point on the device very rarely has problems). The lever, the link, and the gear can all quite simply be replaced. They are available quite inexpensively at Amazon under Oster A5 Clipper parts (note that the one speed and the two speed take different bakelite gears, but the lever and the link are the same). If you were to replace parts such as these, remember that a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear). Also, the gear shaft has a hole down its middle (and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The simple way to tell if you need to replace parts is to grip the blade end of the lever while all parts are in place and try to move it back and forth, as though it were running the blade. If there is any more than the slightest movement, replace the lever (replace that anyway if the part that contacts the blade is rounded off) link and gear.
So, hope this makes things more understandable. Good luck.
Posted on Sep 30, 2009
    Genius:
  • 1,066 Answers
Adjust the large screw on the side of the razor in or out.  Also oil it with a little WD40
Posted on Mar 13, 2009
Solution 1 by Neil647 is like greek to me. Everywhere I look on the internet I don't understand my stupid clipper ?hinge assembly, metal posts, lever, gearwheel, new body, drive lever, signs of wear, tram lines...what the heck is all that language? Even the brief instructions that came with the Oster A5 mean absolutely nothing. Why is there not an instruction manual that starts from the beginning...a diagram of parts, some definitions, some step by step instructions on lubricating and when to do it. OMG this is like a secret society for clipper people
Posted on Sep 11, 2009
  • 191 Answers
Check the two screws holding the hinge assembly on make sure they havent worked loose, if the problem is with all your blades check for excess side to side movement on the metal posts holding the lever and gearwheel into position these may wobble as the clipper gets hot if so you need a new main body. The drive lever should be replaced regulary check the tip for signs of wear if this is the fault you will experiance tram lines on larger blades slow clipping.
Posted on Mar 15, 2009
I have oster 6550 series a clippers, i installed new blades but they hardly clip any hair, when I loosen the tension the blades "move quicker" but vibrate with a loud noise
the tension should be pre set from the factory, if its more than one blade your having problems with then its likely there is a problem with the clippers.
Mar 04, 2011 | Oster Golden A5 2-Speed Universal Motor...
My oster A5 2 speed will cut for short time and than won't go though my dogs fur. It's like the blade lifts up and is not tight on the clippers. I have had these clippers for three years and have had no...
make sure the blade clicks into place and cannot be removed without depressing the release latch, secondly check the two screws are tight either side of the hinge assembly, faults in either can cause this fault.
Dec 30, 2010 | Oster Golden A5 2-Speed Universal Motor...
My oster golden A5 cliper blades are wobbling
remove the blades and make sure the screw are tight on the hinge assembly and the blade.
Nov 07, 2010 | Oster Golden A5 2-Speed Universal Motor...
Oster A5 clippers blades stop moving when put into the horses hair. checked without the blades, everything moves fine. Put new blades on, cleaned the silicone off with blade washed and have lubricated with...
How old is your clipper, Oster clippers need to be adjusted for more power and speed, also what clipper blade are you using to cut the horse hair and how long is the horse hair, Also the blade may not be sharp, some new blade are sharp maybe defective.
Feb 25, 2010 | Oster Golden A5 2-Speed Universal Motor...
Using T-84 Andis blade for horses and cutting
Check the two screws either side of the hinge assembly make sure they are tight, the problem appears to be with the clipper if all blades do the same.
Jan 16, 2010 | Oster Golden A5 2-Speed Universal Motor...
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
My A5 clipper is not clipping at all.
If the blade mover is going when you turn the clipper on than all you need to do is take the blades apart and clean them well with a Oster spray and then oil them. I would recommend cool lube.
May 12, 2009 | Oster Golden A5 1-Speed Universal Motor...
Where do I put the oil in my oster a5
across the blades were they contact each other.  WD40 works fine.
Mar 07, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster Golden A5 2-Speed Universal Motor Clipper 78005-140 Logo
827 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Gil Shultz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
