What does, NOT ALWD NI. On the display screen mean?
What does it mean: unauthorized battery?
It means that the manufacturer has not approved of it.
It will not work.
Jun 25, 2017 | Computers & Internet
They said always ni signal everytime i on cpu?
No Signal message displayed on Video Screen in case of either Graphics Adapter is not working or RAM is not properly working. Try reinserting RAM (DIMMs).
Mar 28, 2016 | Biostar MCP6PB M2+ Motherboard
Can you use 18v lithium battery in old 18v drill
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
Jan 14, 2013 | Black & Decker 18V Cordless Drill/Driver
This monitor gives me a complete blank white screen when plugged in even after checking with multiple computers what part would need fixing or replacing for it to function properly?
check first any broken ribbon wire going to lcd panel or broken screen display. if those are good, the cause of white screen would be bad lcd controller board.
Dec 28, 2012 | Computers & Internet
Soyo monitor MT-NI-DYLM1998 "out of range."
Your windows 7 screen resolution is set too high and your display doesn't support it. There are 3 possible solutions to this problem:
1. Press F8 during startup and choose "Enable row-resolution video"
2. Press F8 during startup and choose "Safe mode" and change screen resolution there, then reboot.
3. You can always use another display (if you have one) to set screen resolution to lower value.
Oct 15, 2012 | Soyo Computers & Internet
Camera indicates low battery even for fully charged battery.
I have connected my PowerShot A2000IS that was doing the same thing for me and I discovered the following:
1) The unit works fine even down to 2.5V providing the supply source (i.e. batteries can deliver 500 mA for a short burst during startup, i.e. when the camera's lens is extended). The camera draws 300mA with screen on after the initial startup current has settled. This means that the camera may not work with batteries like normal alkaline as these don't normally supply large currents, like NI-MH and NI-Cd can.
2) I found that if I lowered the voltage down to (using my bench power supply) that the low power indicator come on at just under 2.5 Vs, BUT once it has indicated low battery, turning the voltage back up to 3V didn't remove the low battery indication.
3) Finally I connected my fully charged (with combined voltage of 2.7V) Ni-Mh rechargeables (old and well used) using wires to allow me to measure their voltage and I found that when I turned on the camera the voltage dipped to 2.3V, but come up after the lens was deployed.
Conclusion and recommendations:
a) Get some new high quality Ni-Mh cells.
b) Don't use Alkaline cells (even Duracell brand might not handle it).
c) Forget Ni-Cd as terminal voltage would be at best 2.6V which doesn
Oct 03, 2010 | Canon Powershot A2000 IS Digital Camera
When I depress the shutter button to take a photo the green light turns to red and will not take a photo. New battery. Help?
Red light indicates battery is out of charged.
What type of battery are you using?
the recommended battery for your camera is the AA Ni-MH batteries
now if your using this batteries Ni-Mh and charged it still id did the same thing., How long you already used this batteries more than 2 years now? If yes it means the battery or the Ni-MH is already defective it means that the chemical contect of the Ni-MH is already crystallized and for you to solve it you need to reconditioned the battery or may be purchased a new battery. Gudluck!
Nov 04, 2009 | Kodak EasyShare DX4530 Digital Camera
Cell Phone Problem
como le hago para poder descargar de mi celular a mi ordenador mis archivos si no tango el software ya que no hay ni siquiera para descargar
Aug 06, 2008 | Samsung Cell Phones
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
41 people viewed this question
 Grubhead
Grubhead
