Question about Maytag Washing Machines
My maytag washer keeps filing with water!Never shuts off.
  • jjncec Apr 21, 2009
    Cold water never shuts off. I have to use an egg timer. UGHHHH
  • Maytag Master
  • 3,361 Answers
Does it continue to fill if you unplug the machine?
If so, replace the water inlet valve.
If not, Replace the water level switch.
Posted on Mar 13, 2009
My maytag neptune front load washer keeps shutting off during the wash cycles. Any idea as to what is wrong and how to fix?
my matag neptune front load washer keeps shutting off durning the wash cycles,and the letters LP keep appearing.Any idea as to what is wrong and how to fix it?
May 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag topload washer overfilled,
It isn't a sensor problem, it sounds more like your water level tube has pulled loose. This is attached to the outer drum itself. You can see it when you remove your front cover to the right of the outer tub. This tube uses the pressure generated from your tub water level to push air up to your water level selector, which has a rubber membrane that flexes and closes 2 contacts as the water level makes the rubber expand. If that tube is off, the water will just keep running.
Mar 18, 2010 | Maytag MAV3905EWW 13 Cycle Washer
Maytag washer does not stop running water; it keeps filling up with water even if I push the bottom to shut down the washer
Sorry if you can't get the automatic valve to close or the float switch unstuck, the only other option is to call in a repairman BTW what happens if you just pull the plug, does it still keep filling?
Dec 08, 2009 | Kitchen Appliances - Others
Maytag washer stopped working at the rinse cycle
do you have the machine set for cold water rinse? if so, the solenoid that allows the cold water to come into the machine may be malfunctioning. try to see if it will fill in the rinse cycle with hot water? if so, you need to change the water inlet valve.
Oct 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My machine is not aggetating it just keeps filling with water
if the water is not over flowing on the floor.make sure your washer is off,then pull the drain hose up to the level of the back control panel you should here water flowing out once this stops.keep the hose up for aminute and restart your waher and it should fill up to the proper level and shut off and start washing
Sep 26, 2009 | Maytag Legacy Series Top Load Washer
Water keeps flowing into my washing machine even if it is off. I have to turn the water to the machine off at the valve or it just keeps running.
ITS THE WATER INLET SOLINOID ITS NOT SHUTTING OFF AND ALLOWING THE WATER TO PASS THROUGH REPLACE IT PROBLEM SOLVED
Jun 11, 2009 | Maytag PAV2300 Top Load Washer
Cold water doesn't shut off and keeps pumping into washer
Replace the water valve where the hoses connect to the washer.
Mar 24, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
My washer will fill up, but will not spin or rinse. The belt also keeps slipping off
it sounds like the bearing on the back of the drum have worn out and warped the belt wheel,does it make a loud noise in spin?let me know what you find-mike
Jul 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Washer keeps running water and won't stop.
regardless of machine being on or not???sounds like a faulty water inlet valve youll need to replace the valve..
If the water level just overfills and floods over the top of washer but turns off when the unit is shut off, then it sounds like a bad fill switch.
May 10, 2008 | Washing Machines
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
