Hasbro Gi Joe Sigma Six Panther Rail Logo
A
Anonymous Posted on Apr 24, 2013
Rmlaooto word jumble: Six Sigma
What adapter do I need for a Sigma AF 75-300 lens on a Canon Rebel XTi SLR?
Question edited for clarity.
You get the Sigma lens for the camera in Canon fit.
https://www.google.com/search?q=sigma+lens+af+75-300+for+canon+rebel+xti
Can you use Sigma lenses on Canon cameras?
Since Sigma lenses are made to be fully compatible with Canon cameras, they are backwards-compatible. This means that you can use a Sigma lens on a Canon DSLR camera. Similarly, the Sigma cameras are backwards-compatible with Canon lenses. Macro adapter loses the AF feature.
https://www.google.com/search?q=sigma+lens+af+75-300+mount+adapter+ring+for+canon+rebel+xti
4answers
Who all can take up lean six sigma training?
Everyone of the others who haven't, except those that don't
HOW MANY TIMES DO i HAVE TO ASK THE QUESTION
Before you can expect an answer, you have to fully specify the question. I can give you the answer to the daily jumble in my hometown newspaper, but I sincerely doubt it's the same answer to the jumble you're asking about.
How do you turn on a sigma SA-7n film camera??
I don't know about the SA-7, but the SA-5 doesn't have an on/off switch as such. Pressing the shutter button halfway activates the autofocus and turns on the light meter. The camera switches off after six seconds of inactivity to conserve batteries, though the shutter can still be released accidentally. Turning the mode dial to the "L" position will lock the shutter and prevent accidental release.
You can find a manual for the SA-5 at http://www.butkus.org/chinon/sigma.htm . It's not ideal, but it should help you get started.
Fixed capacitors but now my colours are jumbled
It should have a year parts and labor warranty with the manufacterer. Contact Akai for auth serv. you will void your warranty if you tamper with it.Check connectiond on t con board lvds cables. same on all inputs?T con board could be bad.
6helpful
Sigma 70-300 lens will not move in auto mode. makes loud motor running sound, and gets to a certain point and stops, but the motor keeps running. I can move it fin in manual mode.
It's almost certainly got a stripped drive gear. This is not a DIY repair, but if the rest of the lens is in excellent condition and not more than around five years old then it's probably cost effective to get it repaired. Sigma are normally excellent at supplying spare parts for their lenses.
Get an estimate for the work from a photographic repair specialist but be prepared for at least a four to six week turnaround time as that's what I'm currently finding for good repair outlets on both sides of the Atlantic.
Auto focus fault with 70-300 sigma
It sounds like that the drive belt has worn you need a new one
1helpful
2answers
My sigma 28-200 have problem with shutter problem my canon eos 450 cannot set more than f3.5 bcoz there are error01
All auto-focus lens have some sort of 'chip' inside .. Sigma 'reversed engineered' Canon's chip - however every time Canon brings out a new camera there is a chance the Sigma lens chip won't work (this is why you see lots of Sigma lens on eBay :-) )
IF you can prove you purchased your lens direct from an authorised Sigma dealer, Sigma will update the chip for free .. otherwise they charge about £35 .. you pay postage in both cases ..
Visit the Sigma web site for further info.
Canon powershot S400 LCD screen image jumbled
This sounds like it might be a defective CCD imager. This will get worse with time, and the pictures may be jumbled next. Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Top Hasbro Toys Experts
ZJ Limited
ZJ Limited
Jesse Walters
Jesse Walters
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
