Question about Creative Labs Audio Players & Recorders
Cambridge Soundworks FPS2000 no sound.
My remote volume cable does not work. Is there any other way to control volume.Any other conecctions ? Digital din SPDIF ?
Service center philippines
I am going to guess these are fairly old speakers. I would recommend getting a replacement system.
Mar 22, 2014 | Cambridge Soundworks Audio Players &...
Cav 2 2.1 speakers volume control is burnt
Short circuit in the board. Lcukily you can get a very inexpensive Universal Remote for almost nothing now. Shorts will smell similar to burned plastic, otherwise known as ozone. Discard the controller after removing batteries.
Sep 20, 2012 | Cambridge Soundworks Audio Players &...
Can one fix remote control for Cambridge sound model 88?
Take it to a Tv repair shop to see they can do something, solder connections become bad, and may need a touch up.
Mar 31, 2012 | Cambridge Soundworks Soundworks 88 CD...
Had my computer rebuilt and now my cambridge soundworks GCS300 speakers will not work....what do i do
Generally speakers will not need a driver, its more likely your soundcard needs the driver - have you tried anything else rather than the speakers to get sound? If you cant get any sound at all then its your soundcard so you will need the driver for it - otherwise try the link below, its the only thing that comes remotely close to a driver for these speakers -
http://www.bioticaindia.com/gcs300.html
thx, hope this helps :)
Jan 28, 2011 | Gateway Cambridge SoundWorks GCS 300 PC...
Lost Speaker Sound
It does sound like a connector issue, don't you think?
What happens if you DON"T touch the connector but move the volume control on the controller?
Have you tried looking outward toward the source?
Mar 30, 2010 | Cambridge Soundworks P200 Subwoofer
Dim display on Cambridge Soundworks 88CD
I can't find a manual for this but my guess would be there is a setting for the Display to dim it at all times unless you touch a control.
Feb 26, 2010 | Cambridge Soundworks 88CD CD Player
No volume
do they plug in with a 3.5mm audio jack?
if so, i think you need to check your drivers for laptop output socket.
have you tried output with any headphones etc? do they work on laptop?
Feb 25, 2009 | Cambridge Soundworks SWBL SoundWorks PC...
Cambridge soundworks speakers
Happy Holidays Fredonna
Well, easy task, just put a music CD, on system and if you got an headphones, put in the green connector on your sound card, pop up the PC volume, and see if you heard sound, if you do, heard sound then the problem is your speakers. if don't is your sound card.
good luck
Dec 24, 2007 | Gateway Edison Computer Speakers
Fluctuation in sound output on Cambridge Soundworks 5.1 speakers
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
Nov 25, 2007 | Cambridge Soundworks Movie Works 108...
218 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
