Question about LG 42LG50 42 in. LCD HDTV
Blue screen with error message
After a power surge my tv has a blue screen on 70 percent of the screen.On the blue screen there is an error [Exception By UiTask Task] there is a line of what looks like code going down the screen...I was told the main board needed to be replaced. I did that and im getting the same thing. i looked online and cant find a solution.
  • Muhammad Apr 24, 2013
    Correction i replaced the Power Supply Board and I'm still getting the same problem
    Top Expert:
  • LG Master
  • 74,136 Answers
  • 4 Answers
SOURCE: Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Posted on Jul 17, 2008
mumma_1
  • 903 Answers
SOURCE: Screen color is blue
A blue screen normally comes on in AV or EXT mode, try changing the tv settings back on the controls in TV mode
I hopethis helps
Posted on Nov 20, 2008
  • 8 Answers
SOURCE: replace main board on LG 42LC7D-UB
not sure what you're referring to as a "main board", but heres the LCD Control Board for the TV
http://cgi.ebay.com/LG-42LC7D-UB-LCD-CONTROL-BOARD-6870C-0119A_W0QQitemZ150277759127QQcmdZViewItem
Posted on Mar 13, 2009
  • 10865 Answers
SOURCE: HDMi cable hooked up, but I get an
you have to go to the input button on the remote and push HDMI
Posted on Apr 05, 2009
SOURCE: Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
Posted on Nov 10, 2009
Blue screen, no picture. What's wrong?
The board where the power button is located (same board for the other buttons too) is probably bad. It's all one board, which tells the power board to come on. If this happened after a power surge, and you're not using a surge protector, multiple boards can be bad. (You can't just plug these fragile TV and Blu-Ray players into the wall outlet. Eventually a surge will destroy them). Ps... A lot of people are suddenly making this same complaint with Vizio TV's.
Mar 03, 2016 | Vizio Televison & Video
Rca lcd tv power surge lighting
The power supply is a likely place to find what's causing the problem
Jul 11, 2013 | RCA Televison & Video
No power tv dead
Your Main Board, Power Board, T-Control Board are suspected problems at this time. Press and hold the power button for about 15 seconds, the unit should power down by itself after you have powered it on. If it does not, then do not be concerned. Let me know if the problem continues. The first link below will bring you directly to the troubleshooting guide if you need to continue forward with the same error. Additional information http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com 2 Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment.
Jan 30, 2011 | LG 50PJ350 50 in HD-Ready TV
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
KDF70XBR950 red power light belinks 6 times repeatedly
Hi.
You have a power board error, and TV is in protect mode. This had been caused by the power surges.
Try leaving the TV disconnected from power (unplug cord) for several hours, or overnight.
This will allow PSU capacitors full discharge and can fix PSU fault after power surge. If it does not correct the problem , then there is a faulty component.
In that case the TV must be tested and repaired by a technician.
Regards.
Oct 21, 2009 | Sony Grand WEGA KDF-70XBR950 70" Rear...
When I boot up I get a blank blue screen. Hard drive is working and audio is working
press alt control delete.
Hit task manager
in task manager go to process
if explorer.exe is started hit end task
go to file new task
type explorer.exe and ok
Apr 19, 2009 | Computers & Internet
The tv screen is 60% blue . . . . . .
Me too! Is this a related light engine problem that people are experiencing with the "red cloud" in the middle of the screen? I just replaced the lamp, which I thought was the problem, but nope, the blue is still there. So definitely not the lamp. I don't know what to do?
May 17, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Blue screen due to power going out?
re program it this will help you100 percent
Dec 10, 2007 | Sanyo DS32920 32" TV
LG 42LG50 42 in. LCD HDTV Logo
60 people viewed this question
Computer Repairing
Computer Repairing
