Question about Sanyo DP32746 32 in. LCD Television
Want to use headset sanyo dp 26648
If i plug headset into audio doesn't work
    Genius:
  • 1,066 Answers
The headset is designed that way.
Posted on Mar 13, 2009
Motorola talkabout MR350 headset only sends audio and can not recieve
Likely not compatible. One thing to try is to make certain the transmitting unit is turned OFF when you initially plug in the headset. Sometimes if a headset is plugged into a radio when it is already ON, the headset will appear to be in VOX (voice activated) mode and will not allow the user to receive. Also, if this headset has an inline PTT, it may not be compatible with the radio and you would need to use the PTT on the radio.
If this doesn't work, you would need to use the TalkAbout headset designed for the MR350.
Best regards.
Mar 03, 2012 | Motorola MR350R Two Way Radio
No power to my DP 19649 Sanyo TV. Where is reset button? Manual doesn't mention one.
There is no reset button
The hard reset process is to disconnect power for 1 hour then reconnect
Feb 19, 2012 | Televison & Video
Headset installed but doesn't work
We used the following steps recently with a customer and it fixed his problem:
In Windows, click Control Panel / Sounds and Audio Devices / Audio tab / Sound playback box / Default device: Plantronics C620 (instead of RealTek HD Audio Output)
He also had to restart WMP (Windows Media Player) and it worked great.
Good Luck from Headsets Direct!
Jun 14, 2011 | Plantronics Blackwire C620 Headset
My ipod is just playing without the sound carrying through to the speakers. I dont know how to make it work?
Verify there is nothing plugged into the headset port, including headsets, headphones, or adapters.
Original iPhone only: While on the Home screen, adjust the volume buttons. If you see the icon below, indicating that headphones are attached, there may be debris in the headset port:
To remove debris in the headset port, try connecting a pair of headphones to the headset port and then remove the headphones. Repeat this several times.
If you have paired with a Bluetooth headset that is nearby, either use the headset or turn Bluetooth off (choose Settings > General > Bluetooth).
If that doesn't work, try restarting the iPhone. Hold the Sleep/Wake button until "slide to power off" appears. Slide to power off your device. When it is off, press the Sleep/Wake button to turn it back on.
If restarting the iPhone doesn't resolve the issue, try restoring the device.
May 28, 2011 | Audio Players & Recorders
I have a VR-407 reciever and I am unable to get my CD/DVD rear outputs to work. I am hooking up a DP-3020 and I can get it to work in the Audio L/R jacks in the front. Is there something that I need to do...
A Kenwood VR-407 is a receiver and has an INPUT pair for CD/DVD, not outputs. Plug ANY functioning audio source (except a turntable) into it and select it on the front panel.
If your DP doesn't work on either I'd suspect something is wrong with IT.
May 24, 2011 | Kenwood VR-407 Receiver
I bought a samson se50 headset microphone to go with my GTD Audio wireless system. It has the correct adapter plug to plug in to the transmitter. The plug is a mini XLR plug. The microphone does not...
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
Jul 29, 2010 | Nady Systems Nady ATM-75 Headset Mic w/...
We have a SAnyo HDTV LCD Model DP19649 and can't
I have a sanyo dp-19649 tv and it's hooked up to a panasonic sound bar model# sc-htb10,and it's hooked up to a sony blueray dvd player. the sony player works on the sound bar but the tv doesn't.
Nov 12, 2009 | Sanyo Televison & Video
Listening to t.v. with headset.
I have not solved it yet , but i do not want to pay a team of experts to to tell me if Sanyo has a headset audio jack.
thanks .
Dec 18, 2008 | Sanyo DP26746 26 in. LCD Television
Sanyo DP32746 32 in. LCD Television Logo
159 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
