Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Projection picture problem
I have a 60" Philips 9P6034C Projection tv that is about 5 years old. When I turn it on, the picture is small and oval shaped until after a few minutes then it will fill up the screen to normal size and shape. Sometimes it will oscillate from big to little size depending on the amount of light that is transmitted. ie.; a bright picture will shrink and a dark picture will return to full screen. Please can you tell me what component to change and where to get it?
  • Phil Schneller Aug 29, 2007
    Update on my problem: When I unplug the power cord and plug it back in it has a black screen for a good while then a little oval red screen and after it warms up 30 min. it pops in and out of a normal screen with good color and alignment. It is almost like the CRT's aren't getting enough power. Thanks
  • Philips Master
  • 3,459 Answers
If you have no sound or video or if your screen keeps shrinking and expanding its typicaly the opto chip. You can get the chip and repair instructions from . This is a fairly common problem.
Posted on Sep 07, 2008
I had the same problem for about 3 - 4 months, one day it just stop working, not even that shrinked image. I called a service center recommended by the manufacturer and they took the TV with them. They told me the TV was damaged by lightning. I have my doubts but curious thing is that at the same time I also had problems with a smaller TV. After two months they brought it back. I paid 843 USD and it is working good. They replaced the main board, signal board and power supply. A total of 579.95 USD just in parts. This repair was too expensive considering I initially paid 1800 USD for the TV back in 2000. Next time I just going to replace the thing.
Posted on Sep 02, 2007
I am having the same problem on my 9p5031c101, ver interested in the solution!!!
Posted on Aug 06, 2007
  • eric slagle Aug 06, 2007
    I was told by a tech tody that it may be the sweep board or the powersupply. i cannont confirm those solutions yet though.
Problem with the Philips Magnavox 9P6034C 60 in. Rear Projection Television, had TV for 16 years. Picture gradually got darker and less clairity
the projection tubes do wear out over time and there is no fix but to replace them. you might first check to make sure the lenses and mirror are clean, do not use compressed air to clean as you may force dust between the lenses. if the picture is darker at the edges or a different hue then the coolant is likely contaminated and needs changed
Dec 15, 2010 | Philips Magnavox 9P6034C 60" Rear...
Picture problem
sounds like convergence amps are bad
Aug 29, 2007 | Philips Magnavox 9P6034C 60" Rear...
Picture is small then gets large then gets small again.
Probably a voltage regulator problem. It's not something you can fix yourself unfortunately
Aug 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
When picture is showing it is like the picture is oval and the writing the green and red are seperated . The facial features are like they glow
The convergence board is bad if you cannot adjust, using your customer control through the menu. Also known as the small signal board.......Take your glasses off take two aspirins and see a tech in the morning!
Aug 13, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips 60" rear projection needs warm up time
Sounds like your regulator ic is about to go, not an expensive repair but you have a good thought about buying a new set. If your fluid has never been changed I bet it's due also. Give the choice serious thought.
Feb 26, 2009 | Philips Magnavox 9P6034C 60" Rear...
Bad picture
A 10 year old Rear Projection tv is usually at the end of its life. No such thing as "fluid". Best advice, get a new TV.
Dec 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
What are they talking about when they say you need to change the fuild in your tv. I have 60" philips magnvox that is about 10 years old
The projection TV sets have a coolant that surrounds the CRT picture tubes. It is used to keep them cool when they are lit up. After 5 or so years the fluid gets cloudy and needs to be drained and replaced. If you do it correcly your set will have the best picture you have seen in a long time. Check with the site for the fluid and a photo instruction guide.
60'' phillips pro
Easy fix....Goto and get a chip kit.
Nov 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox big screen problem
Its not the bulb.
When it comes on is it real bright?
Did you loose the audio also?
Any other symptoms prior to having this problem?
Aug 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox(model 9P6034C102 )
This is any easy fix. Goto to get a repair kit. Its a common problem on some of the older Magnavox projection TV sets.
Jul 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
154 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
