Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-52528 tv will turn on but will turn blue if i hit the input button and not let me do anything. how do i fix this?
    Champion:
  • 213 Answers
CALL A REPEAR MAN OR MITSUBISHI
Posted on Nov 25, 2013
premtech
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
DrGreeley
  • 3 Answers
SOURCE: mitsubishi WD-65731
Here is a link to what models have a recall for a faulty sensor... extended warranty on that part preplaceable for free by MDEA.
http://www.mitsubishi-tv.com/j/i/18312/Warranties.html?mid=125121
Posted on Dec 27, 2007
SOURCE: WD-52628 Mitsubishi - change inputs
We had the same problem. Luckily, we had a service contract, so it was serviced yesterday. The fix involved the service guy going through a "service menu" and resetting the TV that way. He was not "allowed" to tell me how I can access the service menu, however. I do plan to research this on the internet in case it happens in the future. It is basically a software/computer problem, and unplugging the TV isn't enough to clear it unless the TV is unplugged for "a long time." The technician said the length of time depends on the condition of your capacitors. Anyway, as a temporary fix, he showed me that you can go into the PIP mode. The device toggle for PIP apparently did still work with mine, so I was able to switch the device on the secondary picture and then switch it to primary, then toggle the PIP off. Good luck!
Posted on Mar 26, 2008
  • 184 Answers
If the green front panel LED blinks continuously and the TV never comes on, its an issue with the "DM" board. When these TVs are first plugged in, the green LED should blink for 30 sec. to a minute or so. This is the TV booting up, reading its software. Mitsubishi has been having problems with this circuit for several years. In may cases the only permanent solution is to have the chassis rebuilt by Mitsubishi at considerable cost and inconvience. The chassis may have to be sent back to Mits for this rebuild. Call Mits and ask for help.
michtech
Posted on Feb 14, 2009
SOURCE: Mitsubishi HDTV model wd-62525 has
It has been renamed.
Posted on Mar 22, 2009
I have a mitsubishi wd52 52528 connected to uverse.....i cannot get hd for some reason, the sbt says it is dispaying 1080i but the tv says 480i ......help????
Make sure you have it connected to the correct input---one other thing if you have not tried it unplug set and HD box from power for a short time and plug them back
The set has a soft and hard reset, the soft with the original remote is Menu, 1,2,3 enter.
Dec 08, 2012 | Mitsubishi WD-52528 52" Television
The picture quality on our WD 52528 is horrible - dark, blurry, and hard to see picture at all if not looking at the tv straight on.
Your satellit receiver should have the capability to hook to your TV either by using HDMI cable out from sat unit to HDMI in on TV. This sgould give you sound and audio, or it should have component output which is a series of three cables red, blue and green.The component cablesdon't provide audio so you have to use digital optical or composite cables for sound. Whos satellite box are you using?You should be able to press your menu and get into "system set up" and, there should be an option for HDTV. Go for the highest resoulution(1080 And a ratio of 16 x 9. You tv manual should tell you about screen set up. Let me know
Dave
Apr 04, 2011 | Mitsubishi WD-52528 52" Television
Timer light keeps blinking
you probably had a power bump, unplug tv for 1 hour turn back on and hit the reset button, if the green light quits blinking your good to go. If not you might have capacitors gone bad not cool.
Apr 03, 2010 | Mitsubishi WD-52528 52" Television
I have a mits tv 52 inch and the timer light keeps blinking. I tried unplugging it and hitting the reset button and it is still blinking and no picture will come on any other troubleshooting ideas?
your problem is in the dm module
there are caps in the supplys on this module that vent and cause the blink of death symptoms
if you have the tools and feel capable you can get a kit at www.
tv world .com
Oct 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Black screen, blinking green light, nothing happens
Hi it is the indication of error code......can you tell me how much time does light blinks......
Jun 03, 2009 | Mitsubishi WD-52528 52" Television
Tv does not turn on. Timer light blinks
Have you tried to hold the menu and input/device buttons on the front panel in together for 5 seconds to see if it will blink a two digit error code? Try that then let me know the code that the led blinked
Aug 05, 2008 | Mitsubishi WD-52528 52" Television
My picture turned blue after i unplugged the tv
did you ever fix the problem?
my tv went blue screen also
needed to charge the lamp so did but now can't get the new lamp to work
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Device Menu not working
Could have a stuck button or a corrupt e-prom, but lets try kicking this set in the head, Now these reset codes are model dependent so this code will not work for every set out there but this reset is for the WD-62525. with the set on and with the original TV remote hit the keys in this sequence, MENU-2-4-7-0 this will bring up a service menu, the cruiser should already be on "Initialize" so simply hit enter. this will reset the TV to factory defaults and may fix your problem
Sep 26, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
